BEX error
Zeha
... ispod radara ...
CPU & Cooler
i5 13600K, Deepcool AG620 - CPU hladnjak
Matična ploča
Asus ROG MAXIMUS Z790 HERO
RAM
Kingston DDR5 32GB (2x16GB) Fury Renegade KF564C32RSK2-32
GPU
Asus TUF-RTX3070-O8G-V2-GAMING
Storage
Sasmung NVME 990PRO 1TB, Sasmung NVME 970EVO plus 2TB, Seagate hdd 16TB IronWolf Pro, Seagate Archive HDD 8TB
Zvuk
Sound Blaster Z, Sennheiser HD 599SE, Logitech X-230
PSU
FSP Hydro PTM PRO Platinum 1000W
Kućište
Fractal Design Define 7, 4x Be Quiet SILENT WINGS 4 140mm PWM high-speed
Monitor
Dell Alienware AW2723DF
Miš & tastatura
Logitech MX Master 3S, Logitech MX Keys S Graphite
Ostale periferije
HP LaserJet P1006
Laptop
Lenovo Legion 5 (82JN003EYA)
Mobilni telefon
Samsung Galaxy S21 Ultra
Pametni uređaji
LG 43UM7600PLB LED
Pristup internetu
  1. Optički internet
Ne mogu da pokrenem cd od ploce sa drajverima.
Juce sam mogao, danas ne mogu...
U medjuvremenu sam stavio zvucnu kartu u komp, povezao prednje portove kucista sa mic i slusalica sa tom zvucnom, deinstalirao drajvere od te zvucne i instalirao ih ponovo.
OS W7/64 je stari prenesen sa ssd-om na novu masinu.
Zanimljivo je da je juce kad sam stavljao drajvere od ploce sve radilo a danas nece.
Evo sad ne mogu ni da uhvatim prozorce sa greskom, samo se gasi, ne mogu da stignem prekopirati tekstualnu poruku o gresci u prozoru sto pise...
Nasao sam resenje koje preporucuju:
https://www.google.rs/url?sa=t&rct=...3EHOlU&usg=AFQjCNEsa3KaFxFcgT-P4qriAB0germP2A
i
One solution I researched is as follows:
"right click on my computer
go to properties
click on advanced system settings
under performance, click settings
click the Data Execution Prevention tab, and then click Turn on DEP for all programs and services except those I select.
click Add, browse to the executable file for the program and add it
Pokusao sam upravo kao sto ovde pise da postupim sa DEP exeption i kao sto video prikazuje ali dobijem poruku:
"This program must run with data execution protection (DEP) enabled.
You cannot turn off DEP for this program.
Sta mi je ciniti a da ne moram frisku instalaciju win10 ili win7 raditi?
Probaj upgrade na win10.
Uradi rollback drajvera za sata kontroler.
Uspeh uhvatiti sta ispisuje za gresku:
Problem signature:
Problem Event Name: BEX
Application Name: Instv2.exe
Application Version: 1.0.0.1
Application Timestamp: 558cc59f
Fault Module Name: StackHash_837d
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 00000000
Exception Offset: 0030005f
Exception Code: c0000005
Exception Data: 00000008
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 9242
Additional Information 1: 837d
Additional Information 2: 837d2f2ff972633a7951c1ec612b18ca
Additional Information 3: 62af
Additional Information 4: 62af870543974c454a52d23963e9c055
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Inace stavljam najnoviji drajver sa sajta proizvodjaca (SBZ_CD_L13_1_00_28), za W7 jer sam jos uvek na W7 (sto i izaziva problem jer je citav OS stari sa starog kompa).
Inace vratio sam Acronis-om se u 9.2.2016. sve radi, ubacivao drjavere za plocu (nova ploca, novi komp, samo ssd, zvucna, hdd-ovi i OS (W7/64) su stari i preneseni na novi komp i krene normalno, otvori se cd, obelezim sta cu od drajvera i na 83% stane instaliranje, BEX greska ali evo svi drajveri rade, nema upitnika u Device Manager.
BEX ne da pokretanje cd od ploce sa drajverima... WOT radi, vidim ja da cu 9.3. (pach za wot tad izlazi) stavljati novi OS na komp, pa nek se usudi da me zeza ako sme...
Istrazivao sam po kompu, restore win pravio nekoliko puta, pojedinacno instalirao drajvere sa cd i onih sa sajta ASUS-a i otkrio sam kada instaliram drajvere za USB3.0 se desi i BEX.
Bice nova instalacija WIN-ova W7/64 i W10/64, beckup-i pa cu da koristim onaj koji bude bolje radio i moje potrebe zadovoljavao...
Mozete zamisliti da mi ovaj bex nastavi se javljati nakon friske onstalacije, a nova masina, zverka opaka, meca C klase i da ima falinku ... puf, odma konopce pa o gredu. :d
Post ispod toga - drugi link. Klikni na download.
http://www.station-drivers.com/inde...ory&Itemid=353&func=startdown&id=1341&lang=en
Što se tiče USB drajvera, nemoj ih instalirati sa CD-a. Ploča ima na download sekciji na ASUS sajtu sve što treba, čak i firmware update za USB 3.1.
https://www.asus.com/Motherboards/MAXIMUS-VIII-HERO/HelpDesk_Download/
USB sekcija.
Možeš probati i ovaj driver, možda podržava tvoj USB kontroler:
https://downloadcenter.intel.com/download/25687/USB-3-0-Intel-USB-3-0-Driver-for-NUC6i-x-SY
