Zeha
... ispod radara ...
- i5 13600K, Deepcool AG620 - CPU hladnjak
- Asus ROG MAXIMUS Z790 HERO
- Kingston DDR5 32GB (2x16GB) Fury Renegade KF564C32RSK2-32
- Asus TUF-RTX3070-O8G-V2-GAMING
- Sasmung NVME 990PRO 1TB, Sasmung NVME 970EVO plus 2TB, Seagate hdd 16TB IronWolf Pro, Seagate Archive HDD 8TB
- Zvuk
- Sound Blaster Z, Sennheiser HD 599SE, Logitech X-230
- FSP Hydro PTM PRO Platinum 1000W
- Fractal Design Define 7, 4x Be Quiet SILENT WINGS 4 140mm PWM high-speed
- Monitor
- Dell Alienware AW2723DF
- Miš & tastatura
- Logitech MX Master 4, Logitech MX Keys S Graphite
- Ostale periferije
- HP LaserJet P1006
- Laptop
- Lenovo Legion 5 (82JN003EYA)
- Mobilni telefon
- Samsung Galaxy S25 Ultra
- Pametni uređaji
- LG 43UM7600PLB LED
- Optički internet
Ne mogu da pokrenem cd od ploce sa drajverima.
Juce sam mogao, danas ne mogu...
U medjuvremenu sam stavio zvucnu kartu u komp, povezao prednje portove kucista sa mic i slusalica sa tom zvucnom, deinstalirao drajvere od te zvucne i instalirao ih ponovo.
OS W7/64 je stari prenesen sa ssd-om na novu masinu.
Zanimljivo je da je juce kad sam stavljao drajvere od ploce sve radilo a danas nece.
Evo sad ne mogu ni da uhvatim prozorce sa greskom, samo se gasi, ne mogu da stignem prekopirati tekstualnu poruku o gresci u prozoru sto pise...
Nasao sam resenje koje preporucuju:
https://www.google.rs/url?sa=t&rct=...3EHOlU&usg=AFQjCNEsa3KaFxFcgT-P4qriAB0germP2A
i
One solution I researched is as follows:
"right click on my computer
go to properties
click on advanced system settings
under performance, click settings
click the Data Execution Prevention tab, and then click Turn on DEP for all programs and services except those I select.
click Add, browse to the executable file for the program and add it."
Pokusao sam upravo kao sto ovde pise da postupim sa DEP exeption i kao sto video prikazuje ali dobijem poruku:
"This program must run with data execution protection (DEP) enabled.
You cannot turn off DEP for this program."
Sta mi je ciniti a da ne moram frisku instalaciju win10 ili win7 raditi?
i
go to properties
