Meizu m2 note
Pozdrav svima.
Mozda je neko vec napisao u ovoj temi (mada sam je prosao celu i nisam video) resenje za sinhronizaciju kontakata na novom telefonu sa Google kontaktima na serveru.
Na nekom stranom forumu sam procitao resenje koje je kod mene upalilo:
Na telefonu kreiras jedan bzvz kontakt i potom odes na Accounts->Other accounts-> Tvoj google account i potom pokrenes sinhronizaciju Contacts. Posle nekog vremena se na telefonu pojave svi kontakti iz Google Contacts.
Biće to lep flyme 5, ako i sa bete budu ubačene sve stvari koje planiraju za m2 note.
^na sta tacno mislis
i imas li neku info kad bi mogli dobiti 5icu
Changelog:
Red assistant
Normal mode: enabled by default, plus voice prompt window through suspension, so the message is more eye-catching red. Click the floating window or shake the phone, you can quickly enter the red list of sessions.
Speed ​​mode: Open “Settings - Accessibility - red assistant - Speed ​​grab a red envelope”, bright screen state, received a red envelope message automatically jump to the session list; lock screen, you can jump to just unlock the session List.
Tone settings: Go to “Settings - Accessibility - red assistant - new red tone”, the old white, Yang Yan, Li Nan, a customized version of the tone of any election!
Information
Bulk Assistant: When sending text messages can be sent with its address information based on the recipient’s name.
SMS Card: Smart SMS upgrade automatically extract key information SMS notification class generates beautiful clear “message card”.
Floating notice: Supports quick reply message and copy the code in the floating notification.
Smart SMS: Update Smart SMS service menu, more powerful.
System
Optimization: Optimization of system application support for Talkback.
Desktop
Floating Notification: Notify new float, to avoid the operation is interrupted.
Multitasking: new card multitasking list, long press to lock individual applications.
Split-screen mode: Multi-screen mode to create a list of tasks while using two applications, you can adjust the window proportions.
Batch finishing icons: Long press the desktop select "sort icon 'batch select the icon to move to a different desktop or folder.
Shake finishing the desktop: Go to “arrange icons” mode, shake your desktop tidy Fast Recovery.
Folders are automatically named: Create a folder, depending on the application type for the folder name is automatically.
Lock screen
Music Locker: New music lock screen, lock screen display directly covers and lyrics.
Lock screen notifications: Settings - notification and status bar, select whether to display the notification in the lock screen to notify whether the new bright screen.
Phone
Floating notice: New calls Floating notice.
Dialpad: Suspended dial plate design, support slide switch contacts, call records, the Yellow Pages.
Online Yellow Pages: New independent online Yellow Pages, online services, one-touch access.
Yellow Correction: Yellow Pages for online identification number, the error correction can take the initiative in the contact details.
Number Tags: against harassment calls, support for online marking the contact details.
T9 search: T9 search optimization, support for searching a strange number in the call log and local Yellow Pages numbers.
Flyme communication
Switching numbers: support changing the network telephone number bind.
Set up
The new design: for interaction and functional grouping adjustment.
Search: New search function, support for the use of text and voice search settings.
Suspension Ball: The sliding gesture Add "button to open the menu 'options.
Energy management: Optimizing power ranking, classification display hardware power consumption.
Default Application: Settings - Application Management - default applications, support for different categories to set the default application.
Map
Added “map” APP.
Photo navigation: Support 360 degree panoramic display navigation, add custom navigation Categories.
Sidebar: support slide in the map from the left edge of the screen sidebar to experience more personalized features.
Route Planning: support car, walking, bus route planning and navigation.
Subway map: subway lines provide detailed information, including first and last time at each site.
Reading
New “reading” APP.
Individuality Columns: All columns can freely subscribe to become your personal library.
Reader: from simple to complicated, supporting features such as night mode.
Importing books: supports importing EPUB, txt, mobi and other text formats.
One yuan yield sections: one yuan Jiashu Daily Catch.
Free limit: six daily limit free download.
Input
Search Legend: Pinyin state, for the search box on the Lenovo support input screen instantly.
Transcriber: New full-screen handwriting keyboard input more casual.
Symbol Keyboard: New independent symbols keyboard, keypad lock symbol support continuous input symbols and expression.
Vibration sense switch: to enter the input settings screen, select whether to open the key vibration.
Skin: Increase dark skin switch.
Wink: Optimizing emoji expression form.
Mobile butler
Start each other: freedom to wake each other permission settings, intuitive view each other wake recording application to eliminate family bucket Applications.
Desktop shortcut: Added “desktop shortcut” management function, to avoid compulsory third-party applications to generate a desktop shortcut.
Garbage clean white list: application cache, redundant installation package, application uninstall remnants supports adding white list, to avoid false cleanup.
Regular cleaning: regular cleaning new “scan and clean” option rubbish more peace of mind.
Notification bar traffic information: traffic management - setting, the new “Notification bar shows the flow of information” switch.
Camera
Shooting GIF: GIF new shooting mode, easy homemade face pack.
Time Watermark: Camera - set new time watermark switch.
Voice camera: Camera - setting new voice camera switch.
Manual mode: increase saturation, contrast and white balance adjustment option.
Scan code: Cancel camera scan code mode, the new “sweep the” independent APP.
Sweep
Add “sweep the” APP.
Scan code: supports two-dimensional code or barcode scanning identification.
Cover: supports scanning to identify music album covers, book covers and posters.
Card: Support business card recognition, you can add contacts directly.
Local Photos: Support add the local image scanning recognition.
Gallery
Map Mode: Gallery - set, display photos in a map, generate personal and exclusive travel map.
Scene Category: Photos - menu - click “classification by content,” according to the picture content intelligent classification.
Pictures: Favourites favorite pictures quickly browse in the collection folder.
Custom Cover: Press folder covers, replace favorite picture as the cover.
Filter Small size: Gallery - setting, the new small-size image filter switch, gallery cleaner.
Silent backup: Gallery - setting new silent backup switch, turned on by default.
Is hidden: Press the folder displayed directly hide unwanted folders.
Photo Week view: two-finger zoom, free to switch month and week views, more convenient management.
Photo Editor: Optimize photo editing features, free to adjust the level of the filter and mosaics.
Set Wallpaper: Set wallpaper function optimization, support for custom fuzzy level and overlay pattern.
Calculator
Rates search: When Conversion Rates support direct search by country name.
Unit operation: When the unit converter supports direct operation.
Uppercase conversion: Press the calculated results can be directly converted to uppercase digital.
Currency Update: ‘conversion’ Update Rates increase shake function.
Clock
Weekday Alarm: Alarm repeat support legal working time.
Batch delete: Supports long press batch delete alarm and world clock.
File
Design: Optimizing directory structure, file classification provides entry.
Remote management: new FTP remote management capabilities, the same Wi-Fi environment, no data line management phone files directly on the computer.
Hidden folders: Documents - setting, the freedom to choose whether to display hidden folders / directories.
Storage space display: Docs display remaining storage space, click to jump to store information page.
Display: adjust the length of the file name is displayed, you can view more detailed filenames.
Cloud Storage
Capacity View: New cloud disk to use capacity for the function.
Search: cloud disk support search.
Online Preview: no download, support more document formats and Open Source Online Preview.
Find the phone
Loss reporting mode: Added a key report the loss, report the loss will temporarily restore the phone to factory state, seal all private data (images, video, etc.), to ensure that the loss of phone, private data will not be disclosed.
On-line reminder: When the phone is lost without waiting for the phone line, on the line after reporting the loss as long as the message will immediately notify the owner.
Intelligent alerts Alert: When a lost handset without knowing the exact location in the vicinity of the time, intelligent alerts using the Alert feature, the phone automatically sound.
Send a message: Find mobile phone service built dialogue channel, even if the missing cell phone SIM card is not inserted, you can still carry on a dialogue with each other.
Notes
Switching topics: new theme switching capabilities, built-in themes four different layouts and fonts.
Search notes: Add notes searching for a more convenient.
Text Share: Add text form of sharing notes.
Graffiti: Graffiti support directly into the drawing board.
Automatic numbering: support number automatically created when editing notes.
User Center
New Independent User Center App.
User level: New user rating system, to enhance the level to get more privileges.
Supplementary Information: Support Extended user details.
Integral Center: new integration center to support exchange gifts, earn points, points sweepstakes.
Order management: new “My Orders” page, easy to manage account Order.
Weather
Interface: The new weather interface, you can see more content in the home.
Weather widget: new 4 * 2 weather clock widget, click plug-enter the clock and around the region were weather applications.
Urban management: direct display of weather information in different cities in urban management interface.
Weather warnings: New weather warning function to support and friends to share early warning information.
Calendar
Constellation almanac: Support Calendar Home View constellations and almanac information.
Event Suspension Ball: New event suspension ball, quick to create a new event.
Calendar projection device: New Calendar projections, supports date projections, interval estimation and public Lunar conversion.
Interval Display: Click on any date, the number of days in the calendar left corner Quick View.
Notification: Permanent cancellation notification bar notification, slide cancel.
APRIL 2016 za nas
Ko sme da proba evo link za betu:
https://meizufans.eu/forum/topic/4354/flyme-os-5-6-2-1-test-firmware-m2-note
Da li jos neko ima problem kada zakaci zvucnike na telefon? Sa slusalicama nemam problema ali bilo koje zvucnike kad naka im na telefon, muzika staje.
Meni normalno radi, sluške, prenosni zvučnik, zvučnici 2.1, 5.1...
Ne znam sta bi moglo da bude, sa slusalicama radi sve ok. Do sada sam probao jedno 5-6 razlicitih zvucnika(tj. bilo sta a da nisu sluske) i ni na jednim ne radi. Tj. radi par sekundi i onda se prekine jer se navodno dzek izvadi. Prvo sam sumnjao na svoje zvucnike i da dzek iz nekog razloga ne odgovara ali kasnije sam probao na jos par komada i ne radi.
Isključi u muzičkom plejeru koji je instaliran dirac HD opciju. To se i meni desilo kada puštam muziku a da nije iz fabričkim plejera.
meni se desavalo isto, kao da iscupam kabl,samo stane muzika... pustao sam preko spotify...
Ja preko deezer. Pošalji mi poruku kako da aktiviram spotify. Probao na par načina i neće. Mislim da ni plaćanje nije moguće iz Srbije. Deezer mi je preko telenora i radi odlično.
Na apkgalaxy skini modovanu aplikaciju. Onda preko vpn-a (recimo tunnelbear) se uloguj i to je to...
Drage kolege po telefonu (ili koji ce te uskoro postati) da posle tri nedelje koriscenja m2 note kazem i ja nekoliko impresija.
Telefon je kupljen preko Telenora i koristim dve SIM kartice (16 gb mi je sasvim dovoljno za moje potrebe) i to jednu za razgovore a drugu za INTERNET.
Telenorov sistem sam podigao na najnoviju veriju i sve je proslo bez problema.
A sad ono najvaznije. Telefon pored razgovora, vibera, emaila, navigacije i citanja vesti, prevashodno koristim u poslovne svrhe tj. administraciju udaljenih mreza pomocu VPNa, Remote Desktopa, WEB pristupa servisima, ruterima i sl.
Dovoljno je reci da tablet i laptop gotovo i ne nosim sa sobom kada sam na putu. Naime, 2 gb RAMa, 5,5'' ekran i velika rezolucija omogucavaju mi izuzetno lako odradjivanje hitnih poslova i resavanje problema u mrezama i servisima. Baterija izdrzi dan pod vecim opterecenjem (tu je za svaki slucaj i ekserna baterija) i sto je najvaznije telefon jos ni jednom nije ni stucnuo niti se zakasljao.
Sve u svemu za ove pare dobio sam i vise nego li sam se nadao.
Topla preporuka.
Jedno pitanje za korisnike ovog telefona ako su imali/koristili i LG G2:
kakvi su ekrani kvalitativno poređeni jedan sa drugim?
Koliko ste zadovoljni kamerom(kvalitetom fotografija,brzinom)?Dvoumim se da ga kupim,nasao polovan sa garancijom za 150 eura,pa me zanima kakav je za net,kakva je baterija i koliko je realno generalno bolji od Nexus 5?
Nije bolji od Nexus 5, a što se tiče kamere tu su negde, mrtva trka.
G2 ili ovaj ekran ja mislim da je ovaj svetliji, sad *** nemam jedan pored drugog, ali su slični. Za ove pare dosta kvalitetan.
Topla preporuka.
Bravo, svaka cast za recenziju. Da cujemo konacno i biz korisnike! ;)
Nije bolji od N5? Hm, ne znam bas, ekran je na M2 note za tri dimenzije bolji od Nexusa. Meni makar subjektivno,.
Jedino gde je bolji M2N je baterija i kamere su tu negde, sve ostalo je na strani Nexusa negde više, negde manje.
Ekran na M2N je samo svetliji, ali nije toliko precizan kao na N5 u bojama. Gledam od prijatelja N5 i pokušavao belu da namestim i nema šanse. Ili je hladna ili topla.
A ekran sam poredio sa G2 kao što piše, ne sa N5.
Bolje je od operatera jer imas 2 godine prave garancije a ne neke divlje iz divljih radnji. Mozda gresim dusu i te garancije se bolje ostvaraju u malim radnjicama ali ja licno mislim da tim radnjama nista ne znaci da se pozoves na bilo koji zakon jer i oni sami vesto izbegavaju isti
Ne znam bas koliko je bolje kod operatera s obzirom na to koliko su tek oni zakerala sto se tice svega. Kod njih maltene nista ne podleze garanciji i sve je fizicki kvar koji dolazi od strane korisnika.
Uostalom, mozda je i taj telefon koji je polovan kupljen preko operatera. ;)
Ja sam imao dobra iskustva sa ovlašćenim Samsung servisom (BG electronics), pošto je i Meizu njihov ovlašćeni, miran sam.
Divlje radnje daju "garancije" 6 meseci i godin dana,kod njih ni zvake ne bih uzeo.dve godine je prava,nosis u ovlasceni servis i mirna backa.
Meizu. Bolji ekran (i to dosta), vise internog storagea, 2 GB RAM, lepsi je, jaca baterija...
Da li je kvalitet izrade na ovom modelu zadovoljavajuc? Ja sam imao prilike da testiram samo mx4, a pretpostavljam da ima male razlike izmedju ta dva modela
Dobar je kvalitet izrade. Nikad ne bih rekao da spada u telefone ispod 200e.
Da li vama nije nezgodan za obavljanje poziva, navikne se covek vremenom?
