djurkash
Pozdrav svima,
posto se kolicina N9002 koji nam dolaze iz Kine,a preko Rusije, ne smanjuje, cena postepeno pada (trenutno je na oko 250-260), a i da ne smetamo kolegama sa N9000/5/6 itd, red je da otvorimo zasebnu temu...
Dakle, radi se o modelu radjenog za kineskog operatera China Unicom, koji se razlikuje od klasicnih Note 3 modela u tome sto ima 16GB interne i nema podrske za LTE. Naravno, postoje i druge razlike, ali su manje znacajne.
Ukoliko koga interesuju detalji, evo i spec.liste:
Samsung Galaxy Note III Duos SM-N9002 Samsung Galaxy Note III Duos SM-N9002 Samsung Galaxy Note III Duos SM-N9002
Physical Attributes
Dimensions
(width x height x depth): 79.2 x 151.2 x 8.3 millimetres
3.1 x 6 x 0.3 inches
Bounding:Volume: 99.4 cubecentimetres
Mass: 168 grams (battery included)
Software Environment
Embedded Operating System: Google Android 4.3 Chinese
Operating System Kernel: Linux 3.4.0
Microprocessor, Chipset
CPU Clock: 2265 MHz
CPU: Qualcomm Snapdragon 800 MSM8974
Width of Machine Word: 32 bit
CPU Core: 4x Qualcomm Krait 400
Level 1 cache: 16KiB data cache / 16 KiB instruction cache
Level 2 cache: 2048 KiB
Instruction Set: ARMv7
Memory, Storage capacity
RAM type: LPDDR3 SDRAM
RAM capacity: 3072 MiB, 2440MiB accessible
ROM type: Flash EEPROM
ROM capacity: 15258 MiB, including 12215MiB user-accessible non-volatile storage
ROM capacity in bytes: 16 GB (billion bytes)
Graphical subsystem
Display Type: color Super Active Matrix OLED display
Display Color Depth: 24 bit/pixel (16777216 scales)
Display Diagonal: 5.7 " (144.3 millimetres)
Display Resolution: 1080 x 1920 (2073600 pixels)
Viewable Display Size: 2.79 " x 4.95 " (70.74 x 125.77 millimetres)
Pixel density (dot pitch): 387.8 pixel/inch (0.0655 millimetre/pixel)
Graphical Controller: Qualcomm Adreno 330
Video out: 3840x2160 (2160p) 4K UHD resolution
USB Series Micro-B (Micro-USB) with MHL connector
Audio Subsystem
Audio Channel(s): stereo sound
Analog/Digital Converter
(Recording): 24 bit nominal quantization
192000 Hz sampling frequency
Digital/Analog Converter
(Playing): 24 bit resolution
192000 Hz holding frequency
Microphone(s): stereo sound
Loudspeaker(s): mono sound
Audio Output: 3.5mm plug
Cellular Phone
Cellular Networks: GSM850, GSM900, GSM1800, GSM1900, UMTS850 (B5), UMTS900 (B8), UMTS1900 (B2), UMTS2100 (B1)
Cellular Data Links: GPRS, EDGE, UMTS, HSDPA, HSUPA, HSPA+
CellularAntenna: Internal antenna
Call Alert: 64 -chord melody (polyphonic)
Vibrating Alert: Supported
Speakerphone: Supported
Phone Controller: Qualcomm MSM8974
Secondary Cellular Phone
Dual Cellular Network Operation: Dual standby
Secondary Cellular Networks: GSM850, GSM900, GSM1800, GSM1900
Secondary Cellular Data Links: GPRS, EDGE
Secondary Cellular Antenna: Internal antenna
Secondary Phone Controller: Qualcomm MSM8974
Control Peripherals
Positioning Device: Multi-touch screen
Primary Keyboard: Not supported
Directional Pad: Not supported
Scroll Wheel: Not supported
Interfaces
Expansion Interfaces: microSD, microSDHC, TransFlash, microSDXC
Supports High Capacity (SD 2.0/HC) memory cards with capacity of up to 64GB
USB: USB 3.0 host/client, Hi-Speed (480Mbit/s), USB On-The-Go 1.3 compliant
USB Series Micro-B (Micro-USB) connector
Bluetooth (802.15): Bluetooth 4.0, Internal antenna
Wireless LAN/Wi-Fi (802.11): IEEE 802.11a, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Internal antenna
Infrared Gate: Supported
Multimedia Broadcast
Analog Radio: No information
Digital Media Broadcast: Not supported
Satellite Navigation
Built-in GPS module: Supported
GPS Protocol: NMEA 0183
GPS Antenna: Internal antenna
Complementary GPS Services: Assisted GPS, QuickGPS, Geotagging, Simultaneous GPS
Built-in Digital Camera
Sensor Type: CMOS sensor
Resolution: 4128 x3096 pixels (12.78MP)
Autofocus (AF): Supported
Optical Zoom: 1 x
Macro Mode: Supported
Built-in Flash: Supported
Camcorder: 3840x2160 pixels , 30frame/sec
Recordable Image Formats: JPG
Recordable Video Formats: 3GP, 3G2, MPEG4
Built-in Secondary Digital Camera
Resolution: 1920 x1080 pixels (2.07MP)
Camcorder: 1920x1080pixels , 30frame/sec
Recordable Video Formats: 3G2
Power Supply
Battery Technology: Lithium-ion battery
Battery Build: removable
Battery Capacity: 3200 mAh
Additional Details
Built-in accelerometer: Supported
Additional Features:
capacitive touchscreen
Corning Gorilla Glass 3 screen
built-in digital compass
GPRS Class 12
EDGE Class 12
HSPA+ 42Mbps
HSUPA 5.76Mbps
S Pen
active noise cancellation
Samsung TouchWiz UX
SoundAlive
Touch Focus
OIS
Panorama Shot
2160p 30fps
video recording 720p 120fps video recording
1080p 30fps video recording
Bluetooth stereo audio profile (A2DP, AVCRP)
WiFi Direct
HT80
WiFi Mobile Hotspot
proximity sensor
light sensor
gyro sensor
barometer
temperature sensor
humidity sensor
Hall Sensor
Brand: Samsung
Manufacturer: Samsung Electronics
Expected Release Date: October, 2013
Physical Attributes
Dimensions
CPU Clock: 2265 MHz
Graphical subsystem
Audio Subsystem
Cellular Phone
Control Peripherals
Interfaces
Internal antenna
Optical Zoom: 1 x
Power Supply
Additional Details
GPRS Class 12
EDGE Class 12
HSPA+ 42Mbps
HSUPA 5.76Mbps
S Pen
Samsung TouchWiz UX
SoundAlive
Touch Focus
OIS
Panorama Shot
2160p 30fps
WiFi Direct
HT80
WiFi Mobile Hotspot
proximity sensor
light sensor
gyro sensor
barometer
temperature sensor
humidity sensor
Hall Sensor
Brand: Samsung
