Ethereum [ETH] (Ethash)
Za koji pool ste se odlučili?
  • DwarfPool
    Glasovi: 106 17.5%
  • Ethermine
    Glasovi: 279 46.2%
  • ethpool
    Glasovi: 26 4.3%
  • Coinotron
    Glasovi: 71 11.8%
  • Nanopool
    Glasovi: 122 20.2%
  • Ukupno glasača
    604
i eto opet svi cute i mudruju, a posle se bune ako se placa miner
ne kazem da treba, a i trenutno ne znam o cemu se radi, trenutno je najisplativiji eth za kopanje pogotovo sto mu pada dif, ali se i dalje kopa x11 (ali sa onim w0lf-ovim binovima koji daju oko 17 mh za 7950)
Jel se meni cini ili je Suprnova pocela da zakida na ETH???
mene su malo pre kontaktirali i izvinjavaju se i kazu da rade nonstop da im eth wallet proradi sto pre
Koliko je isplativost u odnosu na XMR..da li se isplati da se zezam i namestam taj ETH na 280x grafikama..koliko mu daje btca jedna 280x sad dnevno
Nema potrebe da toliko peglas karte .
Nije pitao kako da spali karte :d
ne peglam ih, al pitao čovek
koliko dobijas ETH dnevno po jednoj 280 karti ..gledam ovaj tutorijal sad i spansko mi selo na prvi pogled
Edit ..vec sam se spotako na prvi deo tutorijala
DISPLAY: 'cpp-ethereum' TYPE: DOWNLOAD STATE: ERROR
PRIORITY: NORMAL FILES: 0 / 1 BYTES: 0 / UNKNOWN
Unable to complete transfer.
ERROR FILE: https://build.ethdev.com/builds/Windows C++ develop branch/Ethereum (++)-win64-lates
ERROR CODE: 0x80190194 - HTTP status 404: The requested URL does not exist on the server.
ERROR CONTEXT: 0x00000005 - The error occurred while the remote file was being processed.
'C:\Users\Johny\AppData\Local\Temp\eth++.exe' is not recognized as an internal or external command,
operable program or batch file.
edit ..skinuo sam rucno al sam se zaglavio ovde
C:\Program Files\Ethereum 0.9.41\Release>dir *.exe
Volume in drive C is Win 10 SSD
Volume Serial Number is 76E3-E483
Directory of C:\Program Files\Ethereum 0.9.41\Release
08/19/2015 10:40 AM 554,496 abi.exe
08/19/2015 10:41 AM 8,818,688 alethzero.exe
09/06/2015 10:20 AM 0 dir.exe
08/19/2015 10:42 AM 10,441,728 eth.exe
08/19/2015 10:43 AM 3,488,256 ethconsole.exe
08/19/2015 10:43 AM 1,536,000 ethkey.exe
08/19/2015 10:43 AM 657,408 ethminer.exe
08/19/2015 10:44 AM 1,234,432 ethvm.exe
08/19/2015 10:44 AM 7,639,040 mix.exe
08/19/2015 10:13 AM 12,288 QtWebEngineProcess.exe
08/19/2015 10:44 AM 373,760 rlp.exe
08/19/2015 10:44 AM 2,192,384 solc.exe
12 File(s) 36,948,480 bytes
0 Dir(s) 34,215,280,640 bytes free
C:\Program Files\Ethereum 0.9.41\Release>eth -a <coinbase> -b -i -j
The system cannot find the file specified.
i ako je tu fajl kaze ne moze da ga nadje
pa imaš uputstvo na početku teme, sve je x puta napisano.
Ukratko :
1. Skineš ovo, http://d-h.st/rbnt, tu ti je samo ethminer, ostalo ti ne treba, osim ako oćeš da kopaš solo
2. U arhivi je bat za shift, ti napravo svoj, npr na nanopool, nešto ovako :
ethminer -F http://eth1.nanopool.org:8888/0x6111......08 -G --cl-global-work 8192 --cl-local-work 128, ovo 0x6111....08 je moja adresa na poloniexu, samo ubaciš svoju i teraj
Ukratko :
HVala ..jel ce automatski da pohvata sve GPUove u masini ili treba neki parametar
zasto meni dok kopa svakih 5 sekundi prekida i napise worker stopping pa opet kopa...gde je problem??? kopam na coinotronu 280x karte
ATI Radeon 5970 2gb koliko daje?
naso, oko 10Mh, gledah dal da kupim pa pitah ali se ne isplati
Jel postoji neki nacin da iz parrametara minera disablujem jednu grafiku,to jes ukljucim sve osim jedne
Ja sam probao sa opcijom --opencl-device 1,2,3 ali mi nije dalo rezultata uvek mi radila samo jedna karta, pa sam umesto toga ubacio komandu -t (broj GPU-eva) i radi mi odlično.
Nego ne mogu da nadjem gde se nalazi DAG? (negde sam i pročitao ranije al ne mogu da nadjem ni to :S🙂
Nemožeš sa to da kopaš to je dual kartica sa po 1gb vram po gpu, eth jedino radi na min 2gb vram a ima raznih starijih kartica 5850/70/6950/70/6990... samo je pitanje koliko to ima smisla 6970 daje 8Mhs malo je to za 200w potrošnju, bolje kupi polovnu 7850/7870/270 za slične novce duplo manja potrošnja i 2.5x brže....
tacnije radi na 1.5gb Vrama preciznije koliko se secam kada sam probao 5970 tako neki info je izbacio a toliko vrama imaju samo neke starije nvidie tako da je to nebitno, nista bez 2gb u principu sve sto je sad zanimljivo je papreno tako da moras malo vise da se otvoris nesicu...
