LG Nexus 5X
Ne vidim šta je problem sa pozicijama kamere i senzora.
Bijeli sigurno neću uzimati, a na crnom se to svakako ne vidi sve i kada bi mogao biti problem.
Ne ocekujem ja ni ta kamera na lg nexusu da ce spektakularna da bude...to je uobicajeno za nexus familiju
Pa neće, ali biće bolja od Huawei nexus telefona...
LG G4 PRO se čeka za dobru kameru :)
http://www.gsmarena.com/lg_g4_pro-7305.php
With all these leaks, there is also a rumor that we may see the Nexuses launched by the end of September, or start of October, though, this one is far from being confirmed. As far as what kind of hardware you should expect from the new Google smartphones, reports suggest QHD (1440 x 2560) resolutions, 3 GB of RAM, rear-mounted fingerprint scanners, a set of front-facing stereo speakers, and USB Type-C will be toted on both phones. The Huawei-branded Nexus will have a 5.7" screen, whereas the LG Nexus 5 (2015) will sport a smaller, 5.2" one. Under the hood, the Huawei Nexus will have either a Snapdragon 810 or Snapdragon 820 SoC, while speculation suggests that the LG Nexus will bear a Snapdragon 808. That's what we know so far – not much, but conflicting reports are everywhere, probably no small thanks to the fact that dual-device production is causing a bit of confusion among sources.
^ i Nexus S je ima kameru u rangu SGS I (najbolje na androidima u to vreme) ali nije snimao 720p video (namerno su limitirali), Gnex je takodje ima odlicnu kameru u to doba, izuzetak je samo Nex4 jer ima i los, mali senzor (1/4'') a i softver nije bas najbolji. N5 vec kida u odnosu na hardver, i sestica se dobro pokazala.. ne sumnjam da ce ovaj LG imati odlicnu kameru, za huawei nisam siguran.
Dizajn ova dva telefona kao da je stigao direktno iz Googla. Ne bi to LG na svoju ruku nikada tako odradio.
Sto se ocekuje da lg nexus ima bolju kameru od huaweia? Zbog g4, iskustva ili je potvrdjeno?
Ocekujem pocetnu cenu oko 420, a huawei negde oko 500 dolara. Mada mislim da ce taj lg brzo da spadne na razumniju cifru (razumniju za nas, puste Srbe) :D Moraju napraviti nekako jaz izmedju njih. Ako oba budu imala qhd bice im "teze" da opravdaju vecu cenu huaweia. Bez obzira na alu kuciste. Tako da iskreno ocekujem 1080p ekran (sto za mene nije neka posebna mana, ipak ce biti brzi i manje trositi baterije).
Ima li ko info kolika ce baterija biti? Da ce biti mesta za velike bat, hoce.
5.2-inch full HD 1080p P-OLED display ili QHD
Qualcomm Snapdragon 808 processor ili Qualcomm Snapdragon 820
Up to 4 GB RAM
Up to 64 GB of internal storage
3180 mAh non-removable battery
802.11ac Wi-Fi, NFC, and Bluetooth 4.2
Front stereo speakers
Rear power button with integrated fingerprint sensor
13 MP rear camera
4 MP front camera with iris detection
USB Type-C connector with QuickCharge 2.0
Ram aluminijum, leđa plastika ...
meni su te spec ok, bio bi najbolji midrange fon, taj 620 bi trebao biti veoma dobar racunajuci da ima bolje rezultate od 810. a i bio bi kao n5 best bang for buck
Ja mislim da će biti Snapdragon 808 ili 820 i 3GB RAM-a, displej QHD rezolucija :)
808 garantujem. Uvek google igra na siguricu. Kakav je tom 808 gpu?
mislim da je fake taj test, a i pise da je tu rezolucija 1080
Test je fejk i mislim da je star par meseci. 99% je s808 sto moze da bude i dobro
A ako bude alu ram to verovatno nece biti ispod 500$
When it comes to specs and features, the LG Nexus should run on the newest Android 6.0 Marshmallow, feature a Snapdragon 808 system chip with 3GB of RAM, and a 13-megapixel camera with optical stabilization.
5.2” LG Nexus dimensions: 146.9 x 72.9 x 8/9.8mm
We've also earlier heard that the LG Nexus might have a metal frame, but a plastic back, and this image seems to play along with this assumption.
front-facing dual speakers, a fingerprint reader on their back, and a USB Type C connector.
To je to - nema tu šta mnogo da se promeni :)
Samo je pitanje da li je displej 1920x1080 ili 1440x2560 i koji je kapacitet baterije ...
U svakom slučaju saznaćemo 29. septembra :)
Kapiram da ce biti 1080 i zbog toga neka razumnija cena.
Izgleda da neće :)
The Nexus 5 (2015) is expected to carry a 5.2-inch, 1440 x 2560 resolution screen. That works out to a pixel density of 565ppi. A Snapdragon 808 chipset should be under the hood, carrying a hexa-core CPU and the Adreno 418 GPU. 3GB of RAM is inside, and the 13MP rear-facing camera includes OIS. Android 6.0 is pre-installed.
Taj QHD je nesto najgore sto je moglo da se desi telefonima
Mogu oni da mašu sa tim brojevima, dok ne ispeglaju OS. Bice to za mozda za 5 godina tj. jedno 5 verzija. :p
Softver je odličan - daleko bolji i sa više funkcija od konkurencije ;)
Mene više brinu baterija/kamera/cena ovih nexus telefona, izgled i ivice sam prežalio :)
To back up his point, he lists dozens of new features that are coming to Marshmallow that should have Android users excited. Here they are:
• Now on Tap
• Permissions Management
• SD Cards can be “merged” with internal storage
• Android Pay
• Native fingerprint authentication
• Automatic app data backups
• App Links (you’re going to see less of those “what do you want to open this in?” prompts)
• Doze and App Standby
• Multi Window(currently hidden, uncertain future)
• Theming support(currently hidden, uncertain future)
• Dark theme(removed, uncertain future)
• Customisable Quick Toggles along with other UI tweaking
• Visual Voicemail Support
• Redesign of the Clock Widget and Music Identification Widget
• New “Memory” Section in Settings(it was there before, but hidden)
• Support for deleting screenshots directly through the notification centre after they’ve been taken
• Landscape mode available for the Google Now Launcher(feature will likely be backported to older versions of Android)
• New app and widget drawer with scroll bar support and vertical scrolling
• Built-In File Manager receives a bump in functionality
• Native tap to wake support
• Ability to disable “heads up” or “peeking” notifications
• Native 4K output support
• Stricter APK validation
• MIDI support
• USB Type C support
• New boot animation
• Introduction of a “voice interaction” API to allow better interaction with voice actions in apps
• Toggling battery saver by voice
• Ability to undo and redo text changes with bluetooth keyboard shortcuts
• Multi-selection to merge, delete or share has been added in the contacts application
• Faster text selection along with a floating toolbar for text actions
• Default apps UI
• Direct share can allow you directly share stuff with contacts through the share menu
• Much more granular app info
• Native bluetooth stylus support
• Split-screen keyboard
• Mobile radio active bug will be fixed
• Better do not disturb along with repeat caller exceptions
• Bluetooth scanning to improve location accuracy
• Native flashlight API
• Easier access to Multi volume controls(ringer, media, alarm)
• Smoother volume scrubbing
To su neke od novina u Marshmallow v6.0 android sistemu koji će doći na ova dva Nexus telefona ...
Ne znam samo kako da bude 820 koji treba da se pojavi u smartfonima u martu 2016-te? :trust:
Nije glupost, nego budućnost.
Apple duže od 3 godine razvija sličnu tehnologiju, u međuvremenu su kupili izraelsku kompaniju Linx Imaging koja se specijalizovala za multilens tehnologiju, obezbedili proizvođača, tajvansku kompaniju Largan, i nešto slično spremaju za ajfon 7 sledeće godine.
Budi siguran da će i Samsung uskoro usvojiti sličnu tehnologiju (ako već nije).
Pošto je opšti trend smanjenje debljine telefona, ovo će konačno omogućiti telefone bez "grbe" na poleđini uz očuvan (unapređen) kvalitet fotografija
Ti imaš proveren info ? :)
Piše se po netu tako, a i LG je uvek imao najbolje odnose sa Qualcomm-om...
Moguće i da će Huawei nexus ili LG G4 PRO da dođu sa S820...
Tesko. Tipujem na lg g4 pro i xiaomi mi5+ ali u varijanti predstavljanje u decembru a pocetak prodaje u feb.
Nece s820 pre toga
99% su s808 i s810 u novim nexusima. ***
