D
Deleted member 46590
Guest
E i to je isto što i insider verzija 10240 stara jedno mesec dana. To je nešto što moraš sam da probaš, mišljenja idu od oduševljenja do očaja.Mislio sam na ovu verziju puštenu 29. jula
Pa verovatno je nisi dobio... primetio bi je sigurno.gde se nalazi ta Windows ikonica u task baru? Win7 ultimate. Hteo bi da nadogradim na Win10.
Jel moze link odakle da se skine ta verzija da se malo testira!
Additional Windows 10 editions specially destined for the EU, Switzerland, and South Korea (though South Korean editions have "KN") have the letter "N" (for Not with Media Player) suffixed to their names (e.g. Windows 10 Enterprise N) and do not have media-related technologies like Windows Media Player or Camera. There are N editions for all Windows 10 versions except Mobile, Mobile Enterprise and IoT Core. Microsoft was required to create the "N" editions of Windows after the European Commission ruled in 2004 that it needed to provide a copy of Windows without Windows Media Player tied in. The cost of the N Editions are the same as the full versions, as the "Media Feature Pack" can be downloaded without charge from Microsoft.
Kako se tebi dopada ova http://www.theregister.co.uk/2015/08/04/windows_10_start_menu_replacements_hot_cakes/ vest?Evo kome je smetao start meni u windowsu10...nista vise im se nece dopasti ni ova vest.
http://forum.benchmark.rs/showthrea...-IDSA-nagradu-za-dizajn&p=4309076#post4309076
Pronadji na google en_windows_10_enterprise_2015_ltsb_n_x64_dvd_6848316.iso to je orginalni ISO sa MSDN-a Microsofta , postoji i verzija bez N ali ovu sa N vise hvale , bukvalno nema nista u startu store i slicno.
en_windows_10_enterprise_2015_ltsb_x64_dvd_6848446.iso
Nasao sam ove dve verzija, koja je sada bolja ono klot do balceka u fazonu windows 7 ali sa dx12.
Imam jednu masinu na kojoj bi mogo da se igram pa da ne radim dva puta instaliranje reinstaliranje nego da jednu od ove dve verzija ubacim i da je podesim za rad.
Ako su klot kao sto kazu onda bi trebalo da rade jos bolje i jos brze od win 7 a da imaju dx12 koji je bitan za tu drugu masinu zbog igrica jer ce u nju uskoro da ide neka r9 3xx kartica.
N verziju uzmien_windows_10_enterprise_2015_ltsb_x64_dvd_6848446.iso
N verziju uzmi
Proguglaj , baci koju sliku kad instaliras , un-pinuj iz starta Search i Contact Suport i bice kao Windows 7![]()
I koliko uzima memorije kada se ukljuci komp? Pitam jer mi je win 7 na toj drugoj masini tosio skoro nista, kada se ukljucio i podignu svi programi uzimao je oko 1.1- 1.3gb memorije.
Evo da se vidi da nema problema sa store i otvaranjem aplikacija...
Snimano bandicam-om za nijansu je brzi bez.
Jel' MS Office 2007 radi na Win 10? Posto od office 2013 po "narodnoj ceni" nema ništa, onda da instaliram Office 2007, pošto njega imam free.
Za sada ono sto vidim mi se mnogo svidja, nema gluposti po windows-u koji zauzimaju nepotrebne resurse. Jos samo da nadjem neki activator da aktiviram ovo cudo I bice sve tip top.
O cemu pricas? pokazao sam da store radi I otvara normalno, da aplikacije rade..Kad si sve već iskeširao u memoriju, nemoj te dečije windows fazone...
Imam problem sa igrama (AC Unity, pisao par puta na raznim temama) da mi iskljucuje igru posle tacno 15min, to se nije desavalo na 8.1, vec samo na 10-tki, a to se desava I na Dying Light narodnoj verziji igre, takodje posle 15min se ugasi igra ili izbaci stopped working... Pisao sam Ubisoft support-u za ovaj problem I oni su mi dali soluciju da skeniram system fajlove preko cmd-a tj da ukucam sfc/scannow i da vidim dal ce mi izbaciti neku gresku i naravno izbacio je ovo "[Windows Resource Protection found corrupt files but was unable to fix some of them. Details are included in the CBS.Log %WinDir%\Logs\CBS\CBS.log.]" I oni su mi rekli ako ovo izbaci da se obratim Microsoft-u, a od toga nema nista, pa jel postoji neki fix, posto sam probao i reset kompa, tj onaj recovery, kao da izbrise sve apps I vrati sve na default, ali da ne dira personal files I ne vredi, I dalje izbacuje istu gresku u cmd, I I dalje gasi igru posle 15min, I stvarno vise ne znam sta da radim... EA igre sa Origina rade kako treba, kao i Alan Wake sa Steam-a, ali ove dve koje najvise i zelim da igram nema teorije da prorade, tako da ako neko ima neku soluciju molim ga da mi kaze, bicu veoma zahvalan![]()
Pa jesi li isprobao compatibility mode? Meni je to donekle resilo problem u Crossfire, tj. glavni deo problema je resilo.
Sta pise u CBS.log-u? imas poruku da detalje mozes pronaci tamo.De nisam, ali ne pomaze, stavljao i sedmicu i osmicu, al ne vredi...
