Taj ključ je OEM i isti ključ ima jako puno računara - moraćeš imati SLIC u biosu da bi to radilo, daz loader to radi za sedmicu preko grub-a. Ključ nije dosta.
hvala na odgovoru. nego, imao sam na nekoliko računara problema oko aktivacije(gde su prijatelji instalirali sve moguće apdejtove) pa sam upotrebio drugi metod "Vista7 Slic Ldr" crack, koji je sve rešio. mogu da okačim skrinšot od njega, da pogledaš ili da ti "bacim " u pm, pa da mi kažeš mišljenje.
edit: uputstvo za upotrebu lekića:
Vista7 Slic Ldr
Activate your copy of windows 7 / Vista/ Server 2008, all edition or uninstall all types of crack (bootmgr,bootloader or key/cert) from any loader in one click.
Ensure you login as admininstrator.
It will work in
Windows 7 Ultimate x86 & x64
Windows 7 Professional x86 & x64
Windows 7 Home Premium x86 & x64
Windows 7 Home Basic x86 & x64
Windows 7 Starter x86
Windows Server(R) 2008 Standard x86 & x64
Windows Server 2008 R2 Standard x86 & x64
Windows Server(R) 2008 Enterprise x86 & x64
Windows (R) Small Business Server 2008 x86 & x64
Windows Vista Ultimate x86 & x64
Windows Vista Business x86 & x64
Windows Vista Home Premium x86 & x64
Windows Vista Home Basic x86 & x64
Windows Vista Starter x86
Mode of Activation :
* OEM (Certificate & Key) install only where bios already (or modded) contains slic 2.1
* Add slic 2.1 to Bootloader (0.97 grldr customised by Zsmin for me) with option (Default,Alternative, Low Memory, Debug, Forceful)
- default option allows auto-detect best method where possible
- alt method relocates SLIC, RSDT, XSDT and RSD PTR to low memory
- low memory method relocates SLIC to low memory
- forceful mode tries to activate on systems where some checks don't complete successfully, may cause problems.
* Add Security to bootloader (Read Access Only)
* Add slic 2.1 to Bootmgr (No grldr means less time to boot, not recommended).
* Certificate install where you want to replace certificate only.
* Key install where you want to replace key only.
Advantage :
* Fast Install (since based on WMI script).
* Single file.
* Much smaller in size (since based on .NET Framework 2.0).
* Slic can be added in bootmgr (Not recommended).
* Cert & Slic option are together for OEM install.
* Cert can be installed/replaced only.
* Key can be replaced only.
* Option to add your customised OEM info and logo.
* Option to backup and restore your licence (useful for retail and mak key users).
