Mislim da za 4k igranje 4gb HBM je "dovoljno"za sada.
Naravno kada vidimo koliko u teoriji moze da se klokuje sve ce biti jasno ... ovako stock objektivno gledano je najbolji GPU za igranje do, a i u 4K. Naravno ljudima alergicnim na crvenu boju ce mozda negodovati na ovu konstataciju 🙂
Kako si to izracunao ?
Ocigledno je i bez racunanja da testovi nisu ujednaceni.
https://i.imgur.com/oxQaUWJ.jpg
Ovo je odlicno, samo jos da vidimo potrosnju.
Jel ima poredjenje u 1080p i 1440p?
sto potrosnju? nemas pare za struju? razlika izmedju danasnjih GPUova je max 60W ... iskljuci jednu sijalicu i to je to ....
Imam pare za struju, nemam pare za Fury. :d
Cisto me zanima, a i ovo sto kaze Exodusbgd.
I po hiljaditi put, nije poenta u parama za struju (nismo u Svedskoj, Danskoj ili gde vec) nego u neophodnoj snazi napajanja za takvu kartu.
to je kao da se vlasnik Vejrona zali sto mora godisnje da da 35000e na gume 😉
Dobro napajanje ce nadziveti skoro sve ostale komponente (osim procesora verovatno).
Maxwell is an overclocking beast both on core and memory.
Fury you can't clock the memory full stop and on stock voltage Fury does not clock well at all.
So it will all depend on how much more headroom Fury gets from some extra voltage but right now voltage is locked.
For example a stock Ti which AMD compare against is 1000/1075/7010 clocks. Your extremely unlucky if your Ti can't run stable at say 1200/1400/7600 which gives a drastic performance boost.
Example the fastest card on the market right now is the 980Ti G1 by Gigabyte, it's a Titan killer as my one out of the box boost at 1377MHz OUT THE BOX! It can run stable at 1300/1500/8400 and the performance is absolutely insane.
I foresee G1 will be the fastest single GPU card on the market until end of year and this is simply because Maxwell is an overclocking king.
Only cards I can see beating that this year are also Maxwell such as KingPin, HOF etc.
What I like about Fury the most, it runs so cool it's crazy, sub 40c at all times, complete silence and it looks absolutely awesome, also zero coil whine as well.
But yes the card is very cool, so I can't see why voltage won't become unlocked unless of course core voltage could potentially damage the HBM, but I doubt that.
Fury X launch is 24th at 13:00 so just wait, go in eyes wide open.
In the meantime I shall try to get voltage unlocked and pester AMD for updates, Fury is a brand new technology and the card could have huge amounts more performance to come from both driver updates and overclocking.
It is also surprisingly quick at 4k, infact the higher the resolution the better it performs, which has to be the HBM.
I can confirm AMD have cards doing 1200 on stock volts.
