TosaNS
Odlična navigacija koju možeš da se koristi na telefonima sa android platformom kao i na iPhone. Kao korisnik iste veoma sam zadovoljan tako da možda nekom ovaj topik bude od pomoći u izboru navigacije moru različitih ali ništa manje vrednih. Više informacija možete pronaći na njihovom zvaničnom sajtu. http://www.sygic.com/en/gps-navigation
Join over 60 million satisfied drivers all around the globe Sygic GPS Navigation guides you to your destination with accurate directions and reliable routing.
High-quality offline maps work everywhere, anytime. Internet connection isn’t required. Easily find where to eat or stay with powerful search and millions of points-of-interest (POIs).
The World’s most installed
offline GPS navigation app
First-ever navigation for iPhone
& second for Android
Top 5 Navigation app
in more than 80 countries
Enjoy Sygic GPS Navigation for free
Download the app and get these great, forever free features. No strings attached.
Offline Maps for over
100 countries
Free Map Updates multiple
times per year
Route planning with
3 alternative routes
3D Maps with Realistic
Buildings & Landscape
Multiple waypoints
& easy avoids
Powerful offline search
& Millions of POIs
Turn-by-Turn Navigation with automatic rerouting
Our Premium navigation will satisfy even the most demanding driver. Sygic GPS Navigation will guide you to your destination with turn indicators and distance to each maneuver. For a comfortable driving experience the app immediately recalculates if you miss a turn and finds the fastest way to get where you are going.
Voice Guidance with Spoken Street Names
Don’t take your eyes of the road. Instead focus all your attention on driving with spoken turn-by-turn instructions. And with the Spoken Street Names feature based on text-to-speech synthesis these precise instructions tell you the names of streets and cities, as well as the direction and distance.
Speed limits & Safety warnings
Protect your wallet form unnecessary fines with speed limit warnings. If your foot gets too heavy on the gas pedal get audio-visual warnings. For increased safety and a smooth driving experience, Sygic even shows the upcoming speed limit change before it becomes effective and warns you if you approach a sharp curve at a dangerous speed.
Lane Assistant & Junctions Views at complex intersections
Don’t worry when navigating a complicated junction, our Lane Assistant moves as you go and clearly shows the right lane to be in. On the most difficult highway intersections, realistic Junction View provides you with a clear look ahead, showing you which lane to be in so you won’t miss the next exit.
Travelbook
Travelbook with Statistics and Altitude Profiles keeps track of your trips. See statistics for all your outdoor activities as well as business trips, including distances, altitudes, time and speed.
100 countries
times per year
Route planning with
Multiple waypoints
& easy avoids
& Millions of POIs
Travelbook
