Sygic navigacija i mape
  • Začetnik teme Začetnik teme TosaNS
TosaNS
Odlična navigacija koju možeš da se koristi na telefonima sa android platformom kao i na iPhone. Kao korisnik iste veoma sam zadovoljan tako da možda nekom ovaj topik bude od pomoći u izboru navigacije moru različitih ali ništa manje vrednih. Više informacija možete pronaći na njihovom zvaničnom sajtu. http://www.sygic.com/en/gps-navigation
Join over 60 million satisfied drivers all around the globe Sygic GPS Navigation guides you to your destination with accurate directions and reliable routing.
High-quality offline maps work everywhere, anytime. Internet connection isn’t required. Easily find where to eat or stay with powerful search and millions of points-of-interest (POIs).
The World’s most installed
offline GPS navigation app
First-ever navigation for iPhone
& second for Android
Top 5 Navigation app
in more than 80 countries
Enjoy Sygic GPS Navigation for free
Download the app and get these great, forever free features. No strings attached.
Offline Maps for over
100 countries
Free Map Updates multiple
times per year
Route planning with
3 alternative routes
3D Maps with Realistic
Buildings & Landscape
Multiple waypoints
& easy avoids
Powerful offline search
& Millions of POIs
Turn-by-Turn Navigation with automatic rerouting
Our Premium navigation will satisfy even the most demanding driver. Sygic GPS Navigation will guide you to your destination with turn indicators and distance to each maneuver. For a comfortable driving experience the app immediately recalculates if you miss a turn and finds the fastest way to get where you are going.
Voice Guidance with Spoken Street Names
Don’t take your eyes of the road. Instead focus all your attention on driving with spoken turn-by-turn instructions. And with the Spoken Street Names feature based on text-to-speech synthesis these precise instructions tell you the names of streets and cities, as well as the direction and distance.
Speed limits & Safety warnings
Protect your wallet form unnecessary fines with speed limit warnings. If your foot gets too heavy on the gas pedal get audio-visual warnings. For increased safety and a smooth driving experience, Sygic even shows the upcoming speed limit change before it becomes effective and warns you if you approach a sharp curve at a dangerous speed.
Lane Assistant & Junctions Views at complex intersections
Don’t worry when navigating a complicated junction, our Lane Assistant moves as you go and clearly shows the right lane to be in. On the most difficult highway intersections, realistic Junction View provides you with a clear look ahead, showing you which lane to be in so you won’t miss the next exit.
Travelbook
Travelbook with Statistics and Altitude Profiles keeps track of your trips. See statistics for all your outdoor activities as well as business trips, including distances, altitudes, time and speed.
    11.7 KB · Pregleda: 496
    18 KB · Pregleda: 552
Odlično radi navigacija isprobao sam je danas lepo me navodila od ns do obrenovca. Zanima kako da već određenu rutu promenim tj da uradim najjednostavnije rerutovanje. Prstom pomerim zastavicu ali kada pustim ona nestane? Tj ne ostane tu gde bih zeleo da bude.
Samo treba da držiš na ekranu mesto gde bi dodao 'checkpoint', nema potrebe ništa da pomeraš, Sygic sam prilagodi rutu.
edit: Gledam sad, nisam najbolje razumeo, možeš i zastavicu za cilj da pomeraš po ekranu, kod mene najnormalnije prihvata izmene. Imam ovaj novi Sygic od pre nekoliko dana, ne znam da li ti koristiš tu verziju.
Fala na inf ja sam kupio na popustu kada je mogla da se kupi. Da mislio sam na to da ubacim jos jednu tacku izmedju starta i cilja.
Stigao update. Kada izadjem iz aplikacije ostane mi u gornjem uglu simbol kako da to iskljucim ne mogu da provalim.
Kod mene stoji pri izlasku na home screen, i isključi se posle 1-2 sek. Tako je bilo i pre.
Jedno pitanje kako da podesim kod ove nove verzije da me ne vraća na rutu? Ne mogu nikako da pronađem jer sam ponovo reinstalirao celu aplikaciju, a ne vidim gde mogu ovo da podesim. Ne bih da me navigacija vrti u krug 😀.
Ne vidim da ima takva opcija. Ima samo da se bira koji putevi da se izbegavaju, i tip rute najbrža/najkraća/najekonomičnija.
to sam i ja video pa me zanima kako su to rešili jer uprošloj verziji si mogao da odštikliraš tu opciju, a ovde ja to ne vidim. I kada kreiram rutu ne vidim tu opciju da me ne vraća na tu rutu nego da mi pronađe novu u odnosu na to gde se nalazim.
Automatski bi trebalo da računa novu rutu.Samo to malo kasni u realnom vremenu.
Kako je moćan ovaj novi UI, baš osvježen i moderan, uklapa se i u UI Androida, a ne da odudara ko iGO npr. Konačno da su ubacili slajder sa strane. :happy:
E ako je moderan onda super, onda nema veze sto te kad ukucas Bulevar Z.Djindjica 67 umesto u blok 29 vodi u blok30.
...a i ti ucis polako, za koju godinu bices pravi trol a ne vise samo trol u pokusaju. 😉
Čovek je iz Istočnog Sarajeva, čisto sumnjam da mu je Bul.Avnoja 67 bitna destinacija u životu. Realno, osim Durmitora i Ponča, i nema nekih bitnih lokacija u toj ulici, a njih svakako možeš naći i bez navigacije. 😉 Ti za profi potrebe imaš i profi zahteve. Meni je za tri paljenja godišnje kad putujem negde dovoljna bilo koja navigacija, a poslednje što mi treba je da razmišljam o mapama za Igo. To je prednost Sygica.
Kad kupis igo ne razmisljas ni tamo o mapama,cisto da se razumemo 😉
Bitna reč je ovde ''kada kupiš'' i slažem se u potpunosti sa tom izjavom 🙂. Iz tog razloga sam i ja kupio Sygic da bih imao obezbeđen apdejt mapa, što mi je jako bitno u celoj priči VS. Lep je novi UI pojednostavljeno deluje i zadovljan sam time kako izgleda.
I sta sad ne valja navigacija jer tu ulicu ne prikazuje ok. Taman ko da mu je iGO bezgresan i savrsen. Govori nekome troll, a upada u svaku temu i ishejtuje sve sto nema veze sa iGo. Ko da nista ne smijes reci da ti se svidja za druge navigacije 😀
Platili ili ne platili sygic navigaciju skidanje mapa ne moze biti jednostavnije bilo navteq bilo teleatlas. I ne samo mape vec i voice i ostalo. Sve u jednom downloaderu direktno sa sygic servera.
Za sygic navigaciju mi treba 10 minuta da sve skinem i da je odmah operativna, dok sa iGom dok sve to pohvatas i podesis to nije slucaj i opet nisi siguran da li ce raditi.
I UI je zaista prelijep i pojednostavljen. Kako za ostale app, to je bitno i za navigacije takodje.
Potpuno razumem to što pišeš i potpuno su mi razumljivi i tvoji razlozi i izbori kao što vidim da i ti razumeš moje. Ono s čim se ne mirim, a zbog čega eto čak trpim da me zovu iGO fanboy-em su postovi poput Stjepanovog iz kojih izvire samo pežorativno pisanje o iGO-u i to bez ijednog jedinog validnog argumenta. Ne sporim ja da nekome može biti prijemčivija neka druga aplikacija sem iGO-a, ne sporim ni da je neku drugu lakše koristiti, da je lepša ili štogod drugo od subjektivnih faktora - jedino ne dozvoljavam da na IT forumu neko kaže da iGO u tehničkom smislu nije znatno bolji od konkurencije. Jer on npr. nema taj ozbiljni nedostatak koji Sygic ima, koji se tiče lošeg algoritma pretrage a koji je direktno kriv za pogrešno vođenje. Dakle nisu mape krive nego Sygic jer je korisnika, onda kad nije znao gde je adresa, po svom nahođenju odveo na drugu umesto da prizna da ne zna. Ovo je jako jako bitno i uopšte nije mali propust a to što sam ja naveo samo jednu adresu iz koje se to vidi ne znači da on tako ne postupa uvek. I postupa a to možete proveriti na bilo kojoj novijoj adresi u okolini BG arene a ne samo na B.Z. Djindjića 67.
...kada se sudarite sa problemom koji je proistekao iz te definitivno ozbiljne greške Sygic programera onda će vam biti jasnije zašto toliko akcentiram kvalitet same aplikacije u odnosu na njen šarm.
Tebe Stjepane ne bih komentarisao jer si napisao da sam upao u temu hejtujući Sygic iako su i svi drugi a i ti svedoci toga da si neargumentovani hejt ka iGO-u počeo ti u postu:
...isto postupaš i na temi o Here maps i android navigacije i mape. Ja postupam slično iz suprotnog ugla ali uz argumente koji se odnose na tehničku komponentu aplikacija i mapa o kojima pišemo a to je velika razlika.
EDIT:
@wwwz a da li bi bilo smaranje da sam napisao i sve druge adrese iz tog kraja? Bre ne radi se tu o jednoj adresi nego o feleričnom pristupu programera, na svakoj adresi koju ne zna algoritam će postupiti isto - odvešće te na prvi njemu poznati broj a koji može biti ko zna gde. A to ne radi ozbiljna navy aplikacija.
Opušeno samo, šta si se sav primio, u raspravljackom duhu, nema potrebe da s eunosi nervoza zbog nekog *ebenog softwarea i sl. 😀 Akad vec pricas o tim algoritmima pretrage vidim da se razumijes. Mene zanima kakav je taj algoritam medjusobno ih poredeci, tj. na koji nacin radi jedan, a na koji drugi. Ne moras mi u detalje, samo povrsno, pa cu prosuditi nekako, a valjace i drugima 🙂
U detalje ne bih ni umeo da zađem jer nisam programer ali mi je princip jasan pa ću pokušati da objasnim gde je catch. Ovako, na osnovu tvog unosa aplikacija pravi zahtev bazi (mapama dakle, GIS elementu kod navigacije) i u zavisnosti od dobijenog pozitivnog ili negativnog odgovora prelazi na sledeći nivo obrade dobijenog podatka ...ako je pronađena adresa u bazi onda sledeći nivo može biti printanje određene slike na displeju koja tebi kao korisniku nudi novi detaljniji izbor ili nešto slično ...ali to sa pozitivnim odgovorom od baze nas u ovom slučaju ne interesuje, nas interesuje negativan odgovor ...dakle aplikacija od GIS komponente dobija negativan odgovor - nema adrese u bazi npr. ...e sad, algoritam kod Sygica kaže AKO već nema tražene adrese ONDA izaberi najbližu postojeću po tom i tom kriterijumu ...kako to izgleda u praksi - ti si ukucao B. Z. Djindjića 67 koji ne postoji u bazi a usled ovakvog Sygicovog algoritma budeš odveden na broj 68 koji postoji u bazi ali je udaljen 500m i u sasvim je drugom bloku od tražene adrese. E sad evo razlike između iGO-a i Sygic-a ...u situaciji da u iGO aplikaciji pokušaš da napraviš unos za adresu koja se ne nalazi u bazi ti to nećeš ni moći jer ti neće biti dostupni simboli za unos nepostojeće adrese. Dakle kod iGO-a tebi je skrenuta pažnja da on ne zna da te odvede na traženu adresu i što je još važnije tebi prepušta odluku da li da te vodi do prvog ili n-tog, parnog ili neparnog, većeg ili manjeg broja koji postoji u bazi. Nadam se da sam bio dovoljno jasan i da možeš zakljuučiti koliko je za korisnika bolji iGO-ov pristup od onoga koji je primenjen u Sygic-u. E sad, za kraj da objasnim i razlog zbog koga toliko hvalim iGO-ovu mogućnost rada i sa Contrastovim mapama - jedino one u ovom delu grada imaju dobar deo adresa u bazi pa će te iGO uz Contrast mape stvarno odvesti na pravu adresu. Ovo polje oko BG Arene je samo moj primer a na temi o Android navigacijama i mapama su ljudi iz drugih krajeva Srbije izneli još puno podataka koji potvrđuju da je iako je najbajatija, Contrast mapa Srbije i dalje po pitanju pokrivenosti adresama u Srbiji ispred ostalih provajdera a pošto je iGO jedina aplikacija koja radi sa Contrast mapama onda je to dodatni motiv za njeno korišćenje barem u Srbiji i barem dok drugi GIS provajderi dovoljno kvalitetno ne isprate Contrast u ovom segmentu.
Nadam se da se nisam uludo trudio pišući ovoliki post i da jesam bio informativan (te da će ga neko i pročitati do kraja 😀 ).
To je glupost koju developeri brzo isprave, no oni podrazumjevaju da je to logicno po svim gradovima. U jednoj ulici bliski brojevi da su blizu jedan drugom. Pa racunaju ako nemam taj broj, dovescu te najblize njemu. U Srbiji, Beogradu i sl. sve nakaradno uradjeno, nigdje veze sa logikom. Gdje prestaje logika tu pocinje Srbija (Bosna i slicna boranija) - kaze ona narodna 😀
Ako ti je to jedini razlog i smatras iGO-a boljim od Sygica samo zbog toga, nidje veze 😀
A to za Contrast, mozda kod tebe, npr kod mene (TopMap mape te, iz 2012 kad bjese) cijelo naselje nije ucrtano, pa sta bih ja trebao reci onda 😀
Isto tako sumnjam da su u njoj ucrtani dijelovi oko mosta na adi pa i sam most i sl. (edit: sad sam procitao da ima most ipak) 😀 A to ne gledas tebra, nije bitno aaa 😀
1. To nema nikakve veze sa Srbijom, Bosnom ili bilo kojom drugom zemljom. Brojevi su ređani kako su ređani i GIS komponenta treba da prati stvarno stanje na terenu a navy app ne sme imati *****ne algoritme jer evo npr. u BG imaš Bulevar Arsenija Čarnojevića što je u stvari autoput na kome postoje adrese, sasvim logično neparni brojevi sa leve strane idući ka periferiji a parni sa desne ...ako me Sygic zbog neimanja neke neparne adrese u tom bulevaru (autoputu u stvari) bude bacio na parni broj ja ću onda imati ogroman problem jer uključenja i isključenja na autoput su retka i ja ću potrošiti i puno vremena za ispravljanje njegove greške a i preći ću veliko rastojanje ispravljajući ga. iGO te nikad neće dovesti u takav problem i to nije mala prednost.
2. Nije jedini razlog i ti to znaš, veliku listu iGO-ovih prednosti nad konkurencijom sam izneo na temi o android navigacijama i mapama i ti si je pročitao. Znajući da si upoznat sa svim prednostima iGO-a ne mogu a da se ne čudim razlozima zbog kojih postavljaš ovo pitanje.
3. Contrast ne radi mape za Bosnu i ti to znaš ali ipak u diskusiji o Contrast mapama izmeštaš fokus na Bosnu - nefer postupak.
4. Most na Adi jeste ucrtan i neka izdvajanja sa njega. Manje nego kod ostalih provajdera svakako ali to nije ni sporno jer kadgod smo ja ili neko drugi isticali kvalitet Contrast mapa uvek smo vodili računa da preciziramo da se ta prednost odnosi na bolju adresnu bazu a ne na bolju iscrtanost saobraćajnica. Svakakao da svako pravi izbore u skladu sa svojim potrebama pa će oni u Srbiji kojima je važnija adresna baza poverenje pokloniti Contrastu. Oni kojima je detaljnost iscrtanih saobraćajnica bitna ali i adresna baza takođe, biraće TomTom a oni kojima je bitan samo položaj saobraćajnica i to posebno u ruralnim područjima izabraće Here mape.
Sve je bitno i sve gledam, na tabletu uvek nosim mape svih provajdera (fala iGO-u što JEDINI nudi mape čak 3 provajdera) a 80% vremena koristim Contrast zbog prirode posla kojim se bavim. I evo, kako ne bi izgledalo da hejtujem ili da temu guram u offtopic ja ću se povući a ti budi fer pa nemoj praviti ta nekorektna poređenja između drugih navy apps i iGO-a ...jer ću se u suprotnom vratiti 😛 :d
Ne znam jesi li promjetio, ocigledno nisi. Sygic ako nema broj ulice koji trazis, on te baci na neki najblizi tom, ali ti prikaze koji je u pitanju pa vidis da nije to to, i ako hoces nastavis ili odustanes, a ti pricas kao da ne mozes odustati moras ici na taj broj. 😀 A stvarno velike razlike ne prikazao ti broj odma' kao iGO u ponudi, ili ti prikazao broj blizak tom a svjesno vidis da nije taj. 😀
A da ne govorim koliko je Sygic optimizovaniji na ARTu (samim tim i battery friendly), radi Extended Screen, koliko brze radi kretanje na mapi (HW ubrzanje), kroz menu i sl, za razliku od iGO-a sa dizajnom iz praistorije, em neprakticniji od Sygicovog em ruzniji 5x.😀
Ne znam, meni je smjesan iGO (mores pricati sta ho''s), nekako mi zakrzljo sav, gdje sam ga ostavio 2011 godine, tu sam ga i sad nasao :d Prevod pola na srpskom pola na engleskom 😀 Iskljucim ton na telefonu, pokrenem igo opet vrati, ko kad je povezan volume telefona sa njim.
Brojevi u određenim delovima Srbije su paradoksalno besmisleni. Ko se muvao npr. po Limanu 3 i 4 u NS, može da predpostavi o čemu pričam. Proizvođači mapa ne bi trebalo da unose brojeve sem ako neko ko radi mape nije baš baš stao pred ulaz ili objekat sa određenim brojem i tek tada ga uneo.
Mene je i iGo vrteo po Novom Beogradu jer su brojevi unešeni onako, odokativno.
Voleo bih da se javi taxista da vidim sta ce reci na sve ovo. Sad mu ona teorija o brojevima koja je ko fol bila presudna pada u vodu, a napisao sam i zasto. 😀 Ne samo da ne vidim prednost igoa nad sygicom, vec ozbiljne nefostatke a napisao sam koje. 🙂
Sto se mapa tice oba imaju pidrsku i za tomtom i za here. Te topmap praistorijske ne uzimam u obzir neces ih vazda koristiti i to zbog brojeva oko arene (a brojevi generalno ljudima najmanje bitni, i sto kaze covjek barem da su ok uneseni), dok ulice i naselja se ne ucrtavaju, ono najbitnije :d
Edit: Ne moze se gledati situacija od prije 5 godina. Isto kao sto je nokia bila sinonim za telefon danas je svi prestigli 🙂
igO u tom periodu nije ni UI osvjezio, dok su ostali mnogo napredovali, narocito Sygic.
Meni dovoljno govori i to koliko je Sygic u zadnje vrijeme zazivio po forumima, dosta se pise o njemu, dosta se koriati itd. Mnogi danas koriate iGO iz razliga jer su culi od ovakvih kao taxista da je najbolji i nema dalje, a ni sami pojma nemaju sto niti ih interesuje 🙂
Ne zivi se od stare slave, vremenom te svi pregaze ako ne nastavis, to je pravilo u zivotu 🙂 Konstantan rad i rad na unapredjivanju...
Ne znam jesi li promjetio, ocigledno nisi. Sygic ako nema broj ulice koji trazis, on te baci na neki najblizi tom, ali ti prikaze koji je u pitanju pa vidis da nije to to, i ako hoces nastavis ili odustanes, a ti pricas kao da ne mozes odustati moras ici na taj broj. 😀 A stvarno velike razlike ne prikazao ti broj odma' kao iGO u ponudi, ili ti prikazao broj blizak tom a svjesno vidis da nije taj...
Dok ti nisam ukazao na taj Sygic-ov propust ti ga nisi ni bio svestan i išao si baš tamo gde te je aplikacija i bacala ni ne obraćajući pažnju na taj detalj gde ti ona i pokaže gde je namerila da te IZGUBI ...da ogromna je razlika između vođenja na pogrešnu adresu bez mogućnosti da TI intervenišeš i između vođenja isključivo na aplikaciji poznate adrese i to je naravo OGROMNA prednost iGO-a i ti možeš da se uvbatiš za uši i skakućeš okolo ali to nećeš promeniti.
...A da ne govorim koliko je Sygic optimizovaniji na ARTu (samim tim i battery friendly)...
Gde se gasiš čoveče? Pored one stare eno ti i nove verzije iGO-a koja radi na ART-u, na temi android navigacije i mape imaš tačnu verziju ...btw koliko ljudi sem sebe znaš da su na ART-u?
radi Extended Screen...
Pa šta? Šta se njime dobija po pitanju kvalitetnog navođenja? Oćeš li u toku vožnje na drugom delu ekrana slagati pasijans? Strašno s kim ja diskutujem 😀
...koliko brze radi kretanje na mapi (HW ubrzanje), kroz menu i sl, za razliku od iGO-a sa dizajnom iz praistorije, em neprakticniji od Sygicovog em ruzniji 5x.😀
Ne znam, meni je smjesan iGO (mores pricati sta ho''s), nekako mi zakrzljo sav, gdje sam ga ostavio 2011 godine, tu sam ga i sad nasao...
Laž na laž! Nemaš pojma Stjeeeepaneeeee 😀
...Prevod pola na srpskom pola na engleskom 😀 Iskljucim ton na telefonu, pokrenem igo opet vrati, ko kad je povezan volume telefona sa njim.
Au čoveče koliko ti ne znaš 😀 ...pa jel ti palo napamet da defaultni prevod koristiš za defaultnu aplikaciju a da prevod određenog skina koristiš uz taj skin? 😀 ...Joooooj ni ton nisi umeo da namestiš??? Legenda si ti, stvarno 😀
Znaš kako Stjepane, razočarao si me ogromnom količinom neznanja i ja više ne bih da gubim vreme na tebe ...mislim, ako se ne ljutiš? ...Znaš, ipak sam ja gospodin taxista koji bar navigaciju ume da upotrebi ...za razliku od tebe koji ni to ne znaš a pritom i ne želiš da naučiš. Aj zdravo Stjepane, nađi nekog drugog da te krsti dok ti prdiš a ja odo na neke druge teme, po mogućstvu one gde je manje takvih kakav si ti :wave:
Odlično, hvala! 🙂
Nego, Sygic je apdejtovao svoju aplikaciju samo za Android 4+? Vidim da mi se na tabletu (4.4) apdejtovao, dok je na telefonu (2.3.6) i dalje stara verzija.
Nisam to ni primjetio prije, jer nisam trazio brojeve, bitne su mi ulice i POI prije svega, POI mi je najbolji orijentir. Ako ti vec prikaze pogresan priblizan broj KOJEG VIDIS, je l' to ne mozes odustati od operacije 😀 Opet govorim kakva je prednost da mi ne nudi taj broj, ili da ponudi problizno neki i ja odustanem ili vozim bas do tog broja. Mislim opet nidje veze. Eto nek bude prednost jer ustedis 2 skeunde, a da je OGROMNA jasta je 😀
Nisam rekao da ne rade pojedine verzije, a sta mislis jesu li optimizovane za ART i iskoristavaju taj runtime. Pogledaj kako traljavo skroluje u iGO-u bez hardwareskog ubrzanja, a kako glatko bukvalno sve klizi na Sygicu. ART je defaultni runtime na Lollipopu, ne koristim ga samo ja, nego i mnogi na ovom forumu, samo ne zalazis ti u teme sem navigacije. Vidjeces kad se iGO biti optimizovan za ART, dok Sygic vec ima odlicnu podrsku i za ART i za Android LP 😀
Dobijas vecu povrsinu ekrana, tj navigacija i bez status bara i bez navigacionog bara. Nekome znaci, veci prikaz.
Najlakse je reci laz. Bas je praktican iGO-ov UI, a lijep da ine spominjem,nesto poput Samsungovoh TW-a.
Sta ima da znam. Kopirao ko fol prevod u potreban folder, ne koristim nikakve skinovi, defaultni, a ono prevod nidje veze. Nesto prevedeno, nesto nije, dosta mijesanja i slicno. I da, sto mora vezati ton u navigaciji za navodjenje sa tonom zvonjenja na telefonu. To je isto nidje veze. Nekad hocu da mi telefon ne zvoni a da imam ton navigacije. 🙂
Znaš kako Stjepane,...
Hajd opet se fataj Neveninih glasova, i ostalih stvari, sto stavlja iGO kao sto kazes no1 😀 Ja ne tvrdim da je Sygic najbolji i mozda bolji od iGO-a po pitanju navigacije, ali nije ni losiji i to je cinjenica koju jos dokazao nisi. 🙂 Za mape, eto nik ti bude bolji iGO jer ima podrsku za 3 proizvodjaca, dok Sygic ima podrsku za 2 proizvodjaca. Ali prije svega smo komentarisali rad navy aplikacije i algoritama kao sto kazes :d
