Od jutra do sutra je upaljen, toplota se osjeti samo do 10tak cm od ekrana.
nego, koji titl ide uz SBS ili OU 3D filmove na ovom TVu?
probao sam sa 3D subtitler, ali nisam uspeo. koliko vidim, ako strimujem film preko Media centra - prevodi ne rade.
probao sam i da pustim sa USBa, ali nisam uspeo.
imam i trecu opciju sa WDTV playera, ali nisam jos probao.
any idea?
Quote from: 3D Calibrated Settings
HDTVtest.co.uk 3D Calibration Settings for Panasonic TX-P42ST50
Viewing Mode: True Cinema
Contrast: set to FULL and then reduce by 8 clicks
Brightness: set to ZERO and then increase by 30 clicks
Colour: set to ZERO and then increase by 24 clicks
Sharpness: 0
Vivid Colour: Off
CATS: Off
P-NR: Off
Advanced:
White Balance: -12 3 4 16 7 -25
Colour Management: -11 -5 0 14 1 0 6 0 0
Gamma: 2.4
Intelligent Frame Creation: Off
3D Refresh Rate: Auto (see the notes in our review regarding this for bright rooms)
16:9 Overscan: Off
Pixel Orbiter: Auto
Quote from: 2D Settings
2D Settings for Panasonic TX-P42ST50
hdtvtest.co.uk
Contrast: set to max then reduce by 14
Brightness: default
Colour: reduce by 2 from default
Sharpness: 0 or 1 click from the left
Vivid Colour: Off
CATS: Off
P-NR: Off
Advanced Settings
White Balance: 3 -2 4 0 -5 -4
Colour Mgmt: -9 -2 0 11 -6 3 0 0 5
Gamma: 2.4
24p Smooth Film: Off (for Blu-ray)
Intelligent Frame Creation: Off, Min if you have trouble with double images on 50hz
16:9 Overscan: Off
Pixel Orbiter: Auto
2D Postavke
Contrast: 48 (60 za maksimalan kontrast ali uz gubitak detalja)
Brightness: default (tvornicke postavke)
Colour: umanjite za 2 klika ulijevo od defaultnog (tvornickog)
Sharpness: Po izboru (Preporuka: 5 za SD, 8 do 10 za HD signal)
Vivid Colour: Off
P-NR: Off
Advanced Settings
Gamma: 2.4
24p Smooth Film: Off (za Blu-ray)
Intelligent Frame Creation: Off, Min ako se pojavljuje flickering na 50hz
16:9 Overscan: Off
Pixel Orbiter: Auto
3D postavke za Panasonic TX-P50ST50
Contrast: 60
Brightness: +30
Colour: +24 klika
Sharpness: 10
Vivid Colour: Off
P-NR: Off
Advanced:
White Balance: -9 4 3 14 7 -21
Colour Management: -12 -5 1 12 0 0 6 0 1
Gamma: 2.4
16:9 Overscan: Off
Pixel Orbiter: Auto
Da li neko ima problem sa Viera Connect?
Connection test prolazi bez problema ali ne mogu da uđem u aplikaciju javlja mi "The application server encounter an error. Please try again later."
I tako već par dana.
Isto sam prelistao malo te aplikacije ali nista mi se nije svidelo. O tv browser-u da ne pricam 🙂. YT nije nesto praktican, sporo sve to ide i search je cudan. Svejedno mi TV sluzi za sve sto pustam preko pc-a, pa i YT.
Zanimljivo mi je bilo povezivanje mobilnog i stream videa na tv (i korisnje kao daljinski), ali i to nije nesto upotrebljivo.
Stavio sam da bude duplicate these device pa da kako upalim tv i prebacim na hdmi tu bude slika. Ali imam problem sa zvukom. Ranije sam stavljao show desktop only i onda ugasi monitor, prebaci sliku i stavim da bude zvuk sa tv-ea. Problem sa zvukom je sto kada sam na kompu zvuk ide preko linije i takav je raspored zvucnika da nije nikako prikladno za slusanje dok se gleda tv pa sam iz tog razloga kada prebacim sliku na tv stavio u control panel > sound da zvuk sa tv bude primarni. Sada pokusavam tako da uradim ako je nekako moguce tj. da li je moguce u isto vreme i sa tv-a i sa linije da pustim zvuk? Time bi resio problem, tv je iskljucen dok koristim komp a kada prebacim na tv dobio bi kao neki sorround. Ako budem ostavim duplikat slike onda ce mi to biti isto zezanje kao i sa show desktop only gde cu morati da odredim odakle cu da primam zvuk.
Drugo pitanje bi postavio posto imam u planu da kupim digitalni audio resiver, drug prodaje, ali imam sada problem. Mislio sam na ploci da imam digitalni ulaz za zvuk ali nemam.
http://www.msi.com/product/mb/770C45.html#/?div=Detail
Onda mi je jedino resenje da kupim novu plocu?
Blago tebi. Nemam zbog čega da se ljutim. Znam i ja čega generalno ima od podešavanja u servisnom meniju, ali se nikad nisam udubljivao u njega, jer mi je ulazak u servisni meni poslužio samo da proverim broj radnih sati panela.
Sve ostalo sam podesio u "klasičnim podešavanjima", te nije bilo potrebe za dodatnim avanturama po servis meniju.
Ja lično nemam problem ni sa jednom bojom, pošto sam posle razrade panela ubacio postavke s HD portala, promenio par sitnica i to je to.
Nemam nikakvih krupnih zamerki na rezultate, generalno sam zadovoljan.
Tek uz neki calman bih verovatno dobio bolje rezultate, ali to i nije toliko primetno pri svakodnevnom korišćenju, osim ako neko ne pilji po ceo dan u test pattern-e i sl.
Meni smetaju neke druge stvari kod ovog TV-a, kao što su false contouring, posterisation, line bleed, quick onset IR-a itd., ali ne bih više da se ponavljam.
Sve u svemu, i pored svojih mana, kad se čovek navikne na iste, ovaj TV ume malo da nervira, ali generalno izuva s kvalitetom slike.
Ja sam ljubitelj plazme ali ovaj ST50 ima tako izražen IR da sam već polako rešio da idem na LCD.Ne samo što ima izražen IR već je uniformnost panela očajna,kad gledam fudbal i kad je nešto zumirano DSE se vidi jako puno.
Na svu ovu muku na RTS-u se pojavio onaj četvrtasti prozor sa onim što maše rukama pa mi posle njega ostane taj prozor neko vreme na ekranu da me nervira.
Line bleed je katastrofalan ali sva sreća njega primećujem samo na kraju filma kad krenu ona slovca koja inače niko i ne čita.
Sve u svemu kad padne mrak i kad gledaš neki 1080 film sve je super ali kad krene sve ono što veli kobajaši dođe mi da ga bacim kroz prozor.Stoga ako neko ima savet koji je to danas LCD tv koji ima savfšenu uniformnost ekrana i pokrete neka javi.Ono što sam ja pronašao je najnovija Sony 8 serija u vidu 829 modela koje je po testovima dosledan naslednik plazme.
