MaxCoin [MAX] (SHA-3)
I ja imam nesto tako nakopano oko 1200 maxa....al sam uzeo 200 komada za shortovanje...nije puno al ako ubodes pravi trenutak isplati se....jedan dan kopanja umesto dva ;)
Iz nekog razloga konstantno raste, valjda su ljudi prestali da ga dampuju. Sigurno ocekuju da se prepolovi nagrada za blok.
Al ce da se istresu ako se to ne desi...:)
bacio sam oko na richlistu bas su se lepo dopunili prvih 5-6..sa 5-6k na 9k...La Prestige ajde ako ti nije tesko da bacis dijagram od proslog puta kako se kretao coin..kao sto rekoh nov sam i interesuje me...dok sam jos normalan...
Odmah.
15.3
#1 ???129439.02941779
#2 ???64057.35821658
#3 ???55504.32749823
#4 ???50271.92445451
#5 ???50003.57164858
#6 ???47020.40828678
#7 ???43079.79572545
#8 ???39815.13204119
#9 ???39400.66491776
#10 ???37548.86988819
#11 ???37216.18523906
#12 ???36775.48540043
#13 ???36124.73753419
#14 ???33749.97592977
#15 ???33081.53162763
#16 ???31713.97992988
#17 ???30241.17348631
#18 ???27542.93614708
#19 ???26843.0316304
#20 ???26393.25229444
#21 ???25071.68482973
#22 ???24314.01028798
#23 ???24000.7078935
#24 ???23919.62435122
#25 ???23871.87515259
17.3
#1 ???146098.59522889
#2 ???113572.50755971
#3 ???90767.61718913
#4 ???67694.02380974
#5 ???64072.1752889
#6 ???50283.55282567
#7 ???47658.20887845
#8 ???46706.6035233
#9 ???42696.80402768
#10 ???41885.34962658
#11 ???39410.85794926
#12 ???37557.55529654
#13 ???37255.74129231
#14 ???36783.99191763
#15 ???36133.09352733
#16 kczuse34611.10941999
#17 ???34269.19680925
#18 ???33757.78261807
#19 ???33089.18369851
#20 ???32028.34428419
#21 ???31721.31567304
#22 ???30248.16855542
#23 ???27985.31199979
#24 ???26849.24067725
#25 suncty26315.23956341
20.3
#1 ???152233.79504536
#2 ???105488.78070519
#3 ???90527.20484766
#4 ???90011.52992694
#5 ???82700.51293209
#6 ???67751.20056583
#7 ???64089.94463451
#8 ???61750.41071396
#9 ???52960.50163224
#10 ???50297.49812747
#11 ???47166.09532042
#12 ???43445.96761619
#13 ???42783.52846956
#14 ???41896.9658273
#15 ???39423.214494
#16 ???37567.9712559
#17 ???37388.68549585
#18 ???37261.45261177
#19 ???37001.33233756
#20 ???36143.11443601
#21 ???34273.73143612
#22 ???33767.14477406
#23 kczuse33620.69547874
#24 ???33098.36042975
#25 ???32963.56852143
Mnogo bre ima novčića 11 milki, na ovoj listi prvih 25 nema ukupno 1,5 miliona.
Da ima nekog sa 300+ hiljada pa da kažeš da je kit, ovo je sve beda.
Ovaj sa 150 hiljada ima po trenutnoj ceni 22,5 btc-a, iako je uložio više u kupovinu, a sad ih ne bi za toliko mogao da proda.
Ne znam koliko ima LaPrestige, ali nešto mislim da se nalazi na listi, a opet je malen i čeka ostale.
Što će reći novčići su negde drugde, i nadajmo se na manjem broju lokacija pa da se tim ljudim kroz neko vreme isplati da naduvaju ovo čudo, do tada blaga minerima koji skupljaju jeftine novčiće.
Ma ta lista uopste nije merodavna. Ona samo pokazuje top 25 na mcxnow.
Pravi kitovi ne drze tek tako pare na menjacnici odnosno menjacnicama.
Online walleti, offline walleti, nekoliko menjacnica, ne moze se znati ukupan broj pojedinca na osnovu rich liste jedne od menjacnica.
Ja garantujem da ima njih par sa preko milion novcica.
Vest sa tvitera:
MaxCoin ‏@maxcoinproject 5m
We will be reducing the block reward for MaxCoin from this time next week. The new block reward will be 48, with ~100M coins in total.
Ajde vi iskusniji, šta ovo znači?
Nisam iskusan, ali mogu da pogledam. :D
Ako je isto kao sa Doge, to može da znači da će cena skočiti ili da će pasti. A možda se ništa neće dogoditi. Bilo kako bilo, manje Max-a će se kopati.
Ako je ovo što si napisao iskustvo, onda ja ne želim da budem iskusan...
ma *****ava corvus :)
inače jako neozbiljno od njih... ili proračunato-prevarantski? ništa me ne bi čudilo
Vest sa tvitera:
Po pravilu, to bi trebalo da znaci skok cene.
Manje novcica ce se proizvoditi dnevno, tako da ce samim tim biti i manje lokalnih dumpera jer nece moci tek tako da se istresaju. Inflacija novcica ce biti duplo manja sto znaci da nece biti konstantnog pada vrednosti kao sto je i sad slucaj.
Ocujem blagi skok cene cim trgovci procitaju ovu vest a tokom sledece nedelje bi trebali biti barem na 0.0003.
I mislim da ce ovo privuci rudare pa ce dizanjem diff-a naknadno podici vrednost novcica. E u tim situacijama je pump dobar, nadam se da ce ici tom logikom. Da ga sledece nedelje napumpaju na recimo 0.002, pocelo bi masovnije prelazenje na novcic jer bi bio mnogostruko isplativiji po kalkulatoru. Tako bi podigli diff i verovatno zadrzali ciljanu cenu. To bi bas znacilo novcicu da se probije. Videcemo, daj boze da bude ovako.
Btw, kad bi se diff vratio na ~150k, na BR 48 bi kopali oko 2 - 2,1 Max dnevno sa 280x. Da li ce se onda isplatiti prodavati i po 0.001? :)
P.S Zasto mesate Doge? Klasicna sprdnja od novcica i napravljen sa namerom da privremeno zaustavi penjanje diffa na litecoinu. To ce vlro brzo umreti i jos je skript algoritam. Hmm...
eno doge eksplodirao sa cenom posle polovljenja...
Kao što reče Vojkan, šalim se malo. :) Problem je što se ne zna šta će se dogoditi. Kada se "polovljenje" dogodilo kod DOGE, cena je prilično pala. Ovde će se možda odigrati po scenariju koji je napisao Prestige, pa će cena MAX-a skočiti.
neko na to moze i da gleda ovako, blok je pre bio veci i nakopali su se i nakupovali po bagatela ceni, sad smanjuju blok teze se kopa a oni imaju gomilu novcica kupljenu/iskopanu po bagatela ceni, i kdc je forkovan, doge, izgleda to sad postaje popularno
Znaš kako kažu... u svakoj šali ima i malo šale :).
Ne vidim kako ovaj novčić može da se poredi sa doge, osim što stoji ozbiljan marketing iza oba novčića.
Takođe, mali offtopic, nemojte da potcenjujete doge i marketing oko njega. Mislim da je sve iznenadio već nekoliko puta... nema razloga da to ne uradi opet.
PS. Dok mi ćaskamo ovde, cena MAX-a ide gore... 0.00019 u par sekundi :D
Mislim da je student lepo opisao u temi BTC / LTC [cena, menjačnice, kupovina i prodaja] zasto nekad cena raste a nekad opada sa polovljenjem nagrade.
Uglavnom, za podizanje cene ka gore, novcic pre svega treba da ima dobru podrsku i zainteresovanost a zatim i neki solidno-velik buy volume da bi se to odnosilo. Eno i Qbit je imao block halving pa mu se i vrednost prepolovila.
I ne desava se to instant, nego posle nekog izvesnog vremena.
A mi ne mozemo znati sta ce tacno biti sa maxcoin-om. Omnik je pitao sta ovo znaci, ja sam napisao sta bi po nekom pravilu trebalo da znaci ali posto ovde to bas i ne vazi, ostaje nam da vidimo. Ali po meni male su sanse da ce ovo padati.
Pa kao sto sam i rekao, sacekajte da procitaju vest i cena ce instant skociti.
Ima dosta njih koji veruju u novcic i malo im fali da ih vrati nan ivo gde je bio sredinom Februara.
P.S I mislim da je sada vec rizicno za shortovanje jer se cena mozda ni ne vrati na ~0.00015 nivo!
Daleko je sledeca nedelja, mada treba ocekivati sad malo oscilacija, pa kome se rizikuje trebalo bi da profitira ili propadne. Ja ga cekam da se vrati na 16 bar, sa prvim buy orderom, a imam i jedan nizi pa ce vidimo
Pa bilo bi lepo kad bi svi alt novčići bili na svim berzama...ovako jedan levo, drugi desno, treći....na 10 berzi 10 različitih novčića ko će ih saVatati sve :d
Eno ga Max Kajzer na mcxnow chatu, cim se pojavio cena skocila sa 0.00018 na 0.00021 u sekundi. :) Ali dumpuju ga zestoko, sad bi vec bio na 0.0003.
Neka dumpuju, lakse ce posle stici do 0.005 :p
Bolje da sad prodaju hiljade i hiljade nego tamo na 0.001.
Sad sa jednim btc-om mozesk upiti 5500 max-a, dok ce im na 0.001 trebati 10. ;)
Usput, ko je Alex Jones? Pominje se na chatu da on ulazi u maxcoin i da kupuje ogormne kolicine?
Cenim da ovo neće preko 0.00023 sada.
Ja sam fino prošao danas :) i ćorava koka ubode zrno :D
