HTC One
Možda nije signed? Probaj sa ovim sto sada downloadujes
ista prica :(
C:\fastboot>fastboot flash zip RUU.zip
target reported max download size of 1526722560 bytes
sending 'zip' (1151232 KB)...
OKAY [ 47.056s]
writing 'zip'...
(bootloader) signature checking...
FAILED (status read failed (Too many links))
finished. total time: 76.421s
C:\fastboot>fastboot oem rebootRUU
< waiting for device >
(bootloader) Start Verify: 3
OKAY [ 0.043s]
finished. total time: 0.044s
OKAY [ 46.984s]
writing 'zip'...
FAILED (remote: 12 signature verify fail)
finished. total time: 161.095s
STVARNO VISE NE ZNAM STA DA RADIM!
Probaj da otkljucas bootloader preko htcdev.... Pa onda opet ponovi ovo iznad.
Ili probaj nekako da odradis s-off
http://forum.xda-developers.com/showthread.php?t=2291087
Samo lagano I ne nerviraj se :)
OKAY [ 0.036s]
finished. total time: 0.036s
FAILED (data transfer failure (Too many links))
finished. total time: 1.397s
OKAY [ 0.035s]
OKAY [ 46.854s]
writing 'zip'...
(bootloader) zip header checking...
(bootloader) zip info parsing...
(bootloader) Read zipped android_info fail
FAILED (remote: 99 unknown fail)
finished. total time: 47.107s
OKAY [ 0.035s]
OKAY [ 46.975s]
writing 'zip'...
finished. total time: 161.257s
i kako sad da se ne nerviram, a s-off ne mogu da uradim zato sto ne mogu da ukljucim usb debuging.
kad kucam adb device , nema nista nije pronadjen uredjaj.
imte jos neku ideju!??? kako da se pomerim sa mrtve tacke!?? :wave::alo:
Na kom si windows-u?
Au. Pa to je bio problem mozda. Jer 8.1 u vecini slucajeva nece da prepozna fon u fastboot-u niti hoce da rade adb komande. Moras da nadjes komp sa Win 7 ili da uradis kao sto sam ja uradio ovo : http://forum.xda-developers.com/showthread.php?t=2544620 (pratis samo prvi deo da bi ti proradio fastboot i adb, onda radis ovo sa RUU fajlom)
Instalirao Sam novi ARHD. Telefon odokativno deluje brze I ispravljeni su bagovi koji su me najviše iritirali (back dugme prestaje da reaguje ili kad skoči na kraj embedovanog youtube videa).
Ali mislim da su mi animacije u sense malo drugačije. Naime kod skrolovanja kada se dođe do kraja liste opcija dalje swajpovanje pravi vizuelni razmak između zadnjih opcija na listi. Ako se dobro sećam ranije je taj razmak bio najveći za najbližu opciju a za svaku sledeću sve manji. Sada su mi razmaci identične širine za sve opcije... Da li je još neko primetio ovo?
jos nisam ubacio 51, i mogu ti reci da je to za razmak placebo ;)
pre nego sto odem kod druga da probam na win7 , intresuje me da li je za flashuvanje RUU-a neophodno da se vidi uredjaj i na adb ?
zato sto kod mene kada kucam:
fastboot devices - prikazuje uredjaj
adb devices - ne pokazuje nista
koliko sam pronasao da bi omogucio adb da funkcionise kako treba moram da omogucim usb debugging do kojeg nemogu da udjem zato sto mi zamrzava htc logo.
i za s-off isto tako moram da stikliram usb debugging....
tebi radi fastboot na win 8.1? meni ne
jaoooo prso sam! idem kod druga pa javljam ako ne dobijem infarkt.
Obzirom da cu fon da nosi, u servis da bi mi instalirali 4.4 interesuje me da li neko zna kako nasi strucnjaci resavaju problem sa ljubicastim tackama na slikama koje se slikaju kad je manjak svetla. Vidim da je masovni problem pa rekoh da li i njega da istaknem i da mozda dobijem novi fon?
Za nase prevarante ne znam, al' u stranim zemljama menjaju kameru.
Elem, uspesno flashovao fw, sve uredu(preko linux-a jer imam 8.1 win).
Edit: Nakon update-a fw-a win 8.1 mi uspesno prepoznaje fon u bootloader-u. Rade komande iz njega i sve je u fullu.
"E:\mini-sdk>fastboot getvar all
(bootloader) version: 0.5
(bootloader) version-bootloader: 1.56.0000
(bootloader) version-baseband: 4A.23.3263.28
(bootloader) version-cpld: None
(bootloader) version-microp: None
(bootloader) version-main: 4.19.401.8
(bootloader) version-misc: PVT SHIP S-OFF
(bootloader) serialno: HT36JW904896
(bootloader) imei: Sta te briga :D
(bootloader) meid: 00000000000000
(bootloader) product: m7_ul
(bootloader) platform: HBOOT-8064
(bootloader) modelid: PN0710000
(bootloader) cidnum: 11111111
(bootloader) battery-status: good
(bootloader) battery-voltage: 3884mV
(bootloader) partition-layout: Generic
(bootloader) security: off
(bootloader) build-mode: SHIP
(bootloader) boot-mode: FASTBOOT
(bootloader) commitno-bootloader: dirty-bee46337
(bootloader) hbootpreupdate: 11
(bootloader) gencheckpt: 0
all: Done!
finished. total time: 0.078s"
@cevolav:
koji si android imao pre početka ove agonije?
Imao sam 4.3
3.62.401.1
i da naglasim da sam sad kod drugara i normalno nisam uspeo da pokrenem flash RUU :wall::wall::wall:
kad stignem kuci probacu eventualno kroz linux ako nemate neki bolji predlog.
@cevolav Radiš pogrešno, lepo piše da ovo flashujes iz recoverya. Kopiraj taj RUU.zip na sdcard, bootuj u recovery I install. Možeš da pristupis recoveryu?
Ako imaš tw recovery onda mount sdcard I copy, a ako nemaš copy na flash pa preko otg - a ili stavi karticu u neki drugi telefon/čitač kartica.
Meni je otg kabal sa usb flash-om "spasao zivot". Tako da preporucujem svima da ga kupe jer vredi za tih par stotina dinara.
par ljudi koje ja znam je kod nas u Podgorici dobillo naloge da podignu nove telefone, sve u zadnjih mjesec dana ;)
Jel jos neko i flashovao ARHD 51? Sada mi nema onog da kada zakljucam fon i ponovo odkljucam da se aplilacija onako lepo vrati kao iz pozadine pa se poveca na ekran, nego samo se onako "grubo" pojavi posle odkljucavanja ekrana.
evo tu je otg usb i recovery kaze sledece...
prethodno flash formatiran sa fat32 i prebacen Guru Reset M7 3.62.401.1.zip (http://www.htc1guru.com/dld/guru_reset_m7_3-62-401-1-zip/)
*udjem u recovery*
ClockworkMod Recovery v6.0.4.5
*ubacim flash*
/storage/usbdisk: idle-Unmounted
/storage/usbdisk: Checking
*idem na -instal zip*
*zatim - choose zip from /storage/usbdisk
E: Can't mount /storage/usbdisk
:S::mad::bottle:
Nije lepo mountovao disk, probaj neki drugi? Probaj da nadjes neki tut kako pravilno da mount usb u recovery-u.
