Jos sam i dalje na stock telenor rom-u, pojavio mi se update. Da li ga treba instalirati ili ne, sta se dobija a sta gubi, da li cu instalirati sa njim taj knox i napraviti sebi problem u slucaju root-ovanja? Trenutni rom mi je MG4.
Nema nikakvih problema sto se tice roota i knoxa.
Dobija se:
- GALAXY GEAR Support
- TRIM Support (Makes the device much faster)
- Core UI elements updated to the ones on the Galaxy S4 (Galaxy S4′s theme all over)
- New Samsung Keyboard
- GPU drivers have been updated (Higher GPU benchmark scores)
- New Lockscreen: Multiple Widgets, improved ripple effect than Android 4.1.2, ability to change clock size and set a personal message
- New Screen modes (From S4): Adapt Display and Professional Photo
- Daydream
- Driving mode
- Actionable notifications
- Move-to-SD-card feature
- New Camera mode : Sound and Shot
- New Additions in Notification Centre
- Completely revamped Settings UI (Tabbed interface – Exactly like the Galaxy S4)
- Implementation of Voice controls (Let’s you control various parts of the phone using voice commands – Galaxy S4 feature)
- New Samsung Apps: Calculator, Clock, Contacts, Gallery, Music
- Full screen Samsung apps
- New S-Voice (from Galaxy S4)
Moze, napisao sam gore. Nema knoxa jos.
Kako da obrišem slike, koje su mi nekako ubacile u galeriju sa društvenih mreža ? hvala
Pa *** mene smara da mi memorija puna a nista vise ne radi nego pre...
Bem li ga meni najbolje da e vratim na android 2.1
T bar memorija nije problem
