😀prvi leg 🙂
😀prvi leg 🙂
General:
Hellfire plans no longer cost Blood Shards and should now cost gold.
Monster density in Act I has been adjusted.
An issue where crafting certain items caused the server to crashed has been resolved.
Resolved an issue where the proc from Odyn Son could proc from itself.
Items above level 60 will no longer drop for players on the PTR.
Players can now gain Paragon levels on the PTR
Please note: Experience gained for paragon levels will not be reflected in the XP bar. When you gain a Paragon experience level, you will see a toast notification and the level-up explosion. In addition, the Paragon experience UI button appears, allowing players to spend their Paragon points. This is currently the only way to access the Paragon points UI. We are aware of this issue, and it will require a patch to fully resolve.
Monk:
Serenity - Tranquility: An error will no longer occur when a player takes damage while Serenity - Tranquility is active.
igrao sam 5 minuta PTR i izasao 🙁 sta uopste da radim u igri sa onako bednim monster density-jem
plus sto elite ne daju vise NV, totalno retardirano.
OK, oce da izbace magic find, nema problema, ali onda neka elite daju drugi bonus, exp%. Ovako nema poente ubijati ih
i da, master tezina je presmesna, tako da se ne vracam u PTR do daljnjeg 🙂
Blizzard CS EU @BlizzardCSEU_EN
Hey guys, we're looking into some Diablo 3 login issues at the moment, will update again as soon as we have any more information
Hey guys, it seems now that all our games are experiencing the same login issues, we should hopefully have an update for you soon.
