Batman: Arkham Origins
Steam skida update za igru 3.1 GB !!!
Hah evo i kod mene, sta li sad petljaju, sigurno je nesto za multi vezano, mada ga ni ne igram.
Verovatno je multi u pitanju posto se na steam forumu neki zale da im je izbrisan skroz progres u multiju...
Izgleda da je patch 2.0 u pitanju
http://community.wbgames.com/t5/Sup...pport-Latest-Updates/m-p/41975/thread-id/3469
Patch 2 List of Fixes
This Patch is now live.
Disabled invalid collision object in Mad Hatter level, which was preventing some people from crossing the river
Fixing missing objective for Lacy Towers.
Fixed 'secure area' bug with Gotham Bridge.
Fix for Deadshot quest not completing properly.
Fixed for the player being locked behind a door by AIvsAI. Fixed user bug who was stuck in Industrial District Enigma Tower
Fixed Black Mask drug stash/chapter mixup that would lock away some drug canisters.
Added the ability to run NVidia Benchmark feature from Options Menu.
Fixed a crash at the end of Deadshot.
Issues with MyAlibi should be fixed.
Fixed Bird thugs not spawning.
Fixed a bug in Royal Hotel that would prevent players from progressing at Helicopter scene.
Fixed Fatal Error on Press Start screen.
Fixed bug making it impossible to grapple in bridge
Fixed sequencer not working properly in Gordon’s office.
Fixed elevator that couldn’t be boosted in Bridge.
Fixed issue with elevator not going back to the correct position in Sewers.
Numerous other more minor fixes.
Haha znao sam, probao sam 1-2 partije da odigram, al meni se nimalo nije svidjelo.
Edit: super eto popravili su vaznije bugove i ubacili benchmark tool, to je se cekalo :D
Instalirao sam update1, hoce li mi update 2 izbrisati save game?
Za ovu igricu postoji brdo updateova (poslednji je update 8), a pojavio se i patch 2.0.
Sta da instaliram da bi mi igrica bila, sto kazu, up-to-date ?
Ako sam dobro razmeo treba na "klot" igricu instalirati Update v20131106 pa onda update v2.0. A sta je sa Update 8, da li on treba preko svega da se instalira ?
definitivno cekam goty verziju da nabavim original, ko zna koliko ce biti dlc-a..
Ovaj initiation ima sanse da bude odlican DLC
Mislio sam da ce biti story DLC kad ono mape za challenge mod :/
E sad... ali dobro, nije lose ni to...
Nego, imam utisak da je ovaj Batman mnogo kratak, taman se zaigrao, kad dodje red da nasamaram Dzokera i eto ga credits. Cimi mi se da sam presao igru sa 28-30% (tako pise kad lodiram). Sada sam se dao u prelazenje sporednih misija, celendza, osvajanja kula i ostalih zanimacija
@slashdance007
Moj recimo da kazem kao speed run (ne zurim po svaku cenu ali nigde se ne zaglavljujem)
ali sa svim zivim mogucim side misijama odradjenim kao i istragama za ubista itd. Dakle sve moguce
(osim skupljanja svih data pack-ova) treba mi oko 10/11 sati sto uopste nije malo.
@Dex
Ma to je moj neki subjektivni osecaj da je igra krakta, jer je ogram 2 dana po pola sata pa ne igram nedelju pa 1 dan intezivno pa pauza od nekoliko dana i kad na kraju resim da je igram dok j ne predjem onda ubrzo dodje kraj jer nemam osecaj koliko sam presao pre toga.
Nego, kako da resim jednu Enigma kulu, proletim kroz nju, mislim da je poslenji update 2 koji sam instalirao, posle njega ma jos 2 koja zavise jedan od drugog i zahtevaju oko 10GB (privremenih) za instaliranje, jos to nisam probao.
Ovaj Initiation d.l.c. je otimačina keša. Recikliranje postojećih trening mapa sa manje dostupnih spravica u arsenalu, dva nova skina za, praktično, samo model Deadstrouka i novim rečenicama za protivnike. I sav taj ogromni, nesagledivi sadržaj to u tričavih 6+ GB...
Može li neko da mi pomogne u vezi sa Grapple Kick zadatkom koji s ejavlja na nekim mapama? Piše "Use the grapple kick to knock an enemy off of the walkway". Koliko sam shvatio iz tog opisa, uhvatiš se za neprijatelja hvatalicom + udariš ga nogom (jedan automatski potez) i, ako se nalazi pored ivice, pretureće se preko ograde i pašće dole. To bi trebalo da je to, medjutim, igra nikako ne registruje taj metod kao ispunjenje zadatka.
Jos uvek ne dobih odgovor na to kojim redosledom se instaliraju apdejtovi da bi igrica bila kompletno patchovana.
Au, mora da postujes redosled, najbolje je da instaliras samo poslednja 2 update-a a to su
Update v20131106 (svi prethodni su ukljuceni u ovaj update)
Update.v2.0.Incl.DLC (zahteva oko 10GB prostora dok se instalira, ne zauzima toliko nakon instalacije)
SAMO jedna napomena, posle instalacije poslednjeg update-a SVAKI put kad izaberem Resume Story pokrece mi Benchmark (imate na Steam-u temu o tom problemu) savetujem da prvo savuvate sejvove C:\Program Data\Steam\RLD!\(cini mi se 209xxx folder posto ih imam vise) pa tek onda update i NIKAKO ne pokrecite benchmark (evo ja sam se zaznuo).
Sada sam u dilemi sta da radim, da reinstaliram igru i krenem ispocetka ili da samo krenem ispocetka, chalange mode radi kod mene jos uvek :D
@slashdance007
Hvala.
@RazbojNick
Koliko se secam potrebno je da ispalis (f) graple tako da se uhvati za ivicu balkona/krova odmah ispod neprijatelja i kako te mehanizam privlaci stisni dva puta space i bices katapultiran i uz malo srece ces istovremeno i otkinuti neprijatelja.
@RazbojNick
Ne, to nije to. Mislim na Predator mape iz Initiation paketa i jedan od zahteva (trofeja) koji sa njim stiže. Kada je protivnik kod ivice, gadjaš ga sa ledja u istom nivou i relativno blizu sa grapple gun (2) pomoću čega poletiš ka njemu u stilu Liu Kanga i opališ ga nogom preko ivice pored koje stoji. Problem je što i najmanja ogradica pravi ogroman problem da ti uspešno obaviš, tj. zadrži neprijatelja od pada, samim tim tebe od ispunjenja zadatka. Neprijatelj ostane na istom nivou uz malo gledanje zvezda, a ti moraš da zapališ u štek, jer se svi usmere ka tvojoj poziciji. Tako bar 6-7 puta dok se ne smiluje da padne preko.
Nema više veze, uspeo sam iz ko-zna-kog puta. Megazayebano je da se uradi + igra ne priznaje svaki put.
Inače su ti novi trofeji iz Initiation stvarno preglupi. Primer: treba da baciš kujiki bombu i da uradiš "smash" obaranje. U pitanju je obično tiho obaranje/davljenje sa ledja uz završni, "smash", udarac, ali pre toga baciš tu dimnu kujiki bombu. *****izam.
Kad ce DLC-ovi za Arkham Origins? Cini mi se da su najavljena pet, a izaso je samo Initiation?
Da mogli su da izbace neki story DLC...
“The team is currently working hard on the upcoming story DLC and there currently are no plans for releasing another patch to address the issues that have been reported on the forums,” the representative said.
Dakle stize nam story DLC..
Hvala bogu. Mislio sam da sam se za'*** kad sam uzeo season pass...
Konacno je najavljen novi DLC, nosi naziv Cold, Cold Heart. Izlazi 22. aprila.
