Graphics Feature Status
Canvas: Hardware accelerated
Compositing: Hardware accelerated on all pages and threaded
3D CSS: Hardware accelerated
CSS Animation: Accelerated and threaded
WebGL: Hardware accelerated
WebGL multisampling: Hardware accelerated
Flash 3D: Hardware accelerated
Flash Stage3D: Hardware accelerated
Flash Stage3D Baseline profile: Hardware accelerated
Texture Sharing: Hardware accelerated
Video Decode: Hardware accelerated
Video: Hardware accelerated
Driver Bug Workarounds
clear_alpha_in_readpixels
exit_on_context_lost
set_texture_filter_before_generating_mipmap
Version Information
Data exported 29.9.2013. 20.39.43
Chrome version Chrome/29.0.1547.76
Operating system Windows NT 6.2
Software rendering list version 6.2
Driver bug list version 2.1
ANGLE revision 2424
2D graphics backend Skia
Performance Information
Graphics 7.4
Gaming 7.4
Overall 5.9
Driver Information
Initialization time 143
Sandboxed false
GPU0 VENDOR = 0x1002, DEVICE= 0x673e
Optimus false
AMD switchable false
Driver vendor Advanced Micro Devices, Inc.
Driver version 12.104.0.0
Driver date 3-28-2013
Pixel shader version 3.0
Vertex shader version 3.0
Machine model
GL version 2.0
GL_VENDOR Google Inc.
GL_RENDERER ANGLE (AMD Radeon HD 6700 Series Direct3D9Ex vs_3_0 ps_3_0)
GL_VERSION OpenGL ES 2.0 (ANGLE 1.29.0.2424)
GL_EXTENSIONS GL_OES_element_index_uint GL_OES_packed_depth_stencil GL_OES_get_program_binary GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_float GL_OES_texture_float_linear GL_OES_texture_npot GL_EXT_occlusion_query_boolean GL_EXT_read_format_bgra GL_EXT_robustness GL_EXT_texture_compression_dxt1 GL_EXT_texture_filter_anisotropic GL_EXT_texture_format_BGRA8888 GL_EXT_texture_storage GL_EXT_frag_depth GL_ANGLE_depth_texture GL_ANGLE_framebuffer_blit GL_ANGLE_framebuffer_multisample GL_ANGLE_instanced_arrays GL_ANGLE_pack_reverse_row_order GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_ANGLE_texture_usage GL_ANGLE_translated_shader_source GL_NV_fence
Window system binding vendor Google Inc. (adapter LUID: 0000000000008270)
Window system binding version 1.4 (ANGLE 1.29.0.2424)
Window system binding extensions EGL_EXT_create_context_robustness EGL_ANGLE_d3d_share_handle_client_buffer EGL_ANGLE_query_surface_pointer EGL_ANGLE_surface_d3d_texture_2d_share_handle EGL_NV_post_sub_buffer
Diagnostics
0
b3DAccelerationEnabled true
b3DAccelerationExists true
bAGPEnabled true
bAGPExistenceValid true
bAGPExists true
bCanRenderWindow true
bDDAccelerationEnabled true
bDriverBeta false
bDriverDebug false
bDriverSigned false
bDriverSignedValid false
bNoHardware false
dwBpp 32
dwDDIVersion 11
dwHeight 1080
dwRefreshRate 60
dwWHQLLevel 0
dwWidth 1920
iAdapter 0
lDriverSize 1155264
lMiniVddSize 0
szAGPStatusEnglish Enabled
szAGPStatusLocalized Enabled
szChipType AMD Radeon Graphics Processor (0x673E)
szD3DStatusEnglish Enabled
szD3DStatusLocalized Enabled
szDACType Internal DAC(400MHz)
szDDIVersionEnglish 11
szDDIVersionLocalized 11
szDDStatusEnglish Enabled
szDDStatusLocalized Enabled
szDXVAHDEnglish Not Supported
szDXVAModes ModeMPEG2_A ModeMPEG2_C
szDescription AMD Radeon HD 6700 Series
szDeviceId 0x673E
szDeviceIdentifier {D7B71EE2-247E-11CF-5C70-4137BEC2C535}
szDeviceName \\.\DISPLAY1
szDisplayMemoryEnglish 2807 MB
szDisplayMemoryLocalized 2807 MB
szDisplayModeEnglish 1920 x 1080 (32 bit) (60Hz)
szDisplayModeLocalized 1920 x 1080 (32 bit) (60Hz)
szDriverAssemblyVersion 12.104.0.0
szDriverAttributes Final Retail
szDriverDateEnglish 3/29/2013 04:37:02
szDriverDateLocalized 29.3.2013. 4:37:02
szDriverLanguageEnglish English
szDriverLanguageLocalized English
szDriverModelEnglish WDDM 1.2
szDriverModelLocalized WDDM 1.2
szDriverName aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
szDriverNodeStrongName oem4.inf:cb0ae414c46b9cbb:ati2mtag_NI:12.104.0.0😛ci\ven_1002&dev_673e
szDriverSignDate
szDriverVersion 8.17.0010.1191
szKeyDeviceID Enum\PCI\VEN_1002&DEV_673E&SUBSYS_174B174B&REV_00
szKeyDeviceKey \Registry\Machine\System\CurrentControlSet\Control\Video\{DE53BF91-2F6E-4153-ACA8-5A59D31DCA25}\0000
szManufacturer Advanced Micro Devices, Inc.
szMiniVdd n/a
szMiniVddDateEnglish n/a
szMiniVddDateLocalized n/a
szMonitorMaxRes
szMonitorName Generic PnP Monitor
szNotesEnglish No problems found.
szNotesLocalized No problems found.
szOverlayEnglish Not Supported
szRankOfInstalledDriver 00E02001
szRegHelpText
szRevision
szRevisionId 0x0000
szSubSysId 0x174B174B
szTestResultD3D7English Not run
szTestResultD3D7Localized Not run
szTestResultD3D8English Not run
szTestResultD3D8Localized Not run
szTestResultD3D9English Not run
szTestResultD3D9Localized Not run
szTestResultDDEnglish Not run
szTestResultDDLocalized Not run
szVdd n/a
szVendorId 0x1002
Log Messages
GpuProcessHostUIShim: The GPU process exited normally. Everything is okay.
