Kad izlazi?
Koliko u proseku imate screen on time?
Код мене батерија разбија. Иде и до 10 сати сурф и књиге. Филмови, сурф, књиге и Tune in радио цео дан скоро 9 сати. До јајца је што се тиче батерије.
Kad izlazi?
Jos ako se ponovi situacija kao sa n4, do feb-mart 2014 ce konstantno biti out-of-stock...Najava u okt verovatno izlazi u novembru(mislim na n5)
Hello Alexander,
Thank you for contacting Skype Customer Service.
We understand your concerns regarding your camera on your Skype for your Nexus 7 device. We would be happy to help you with this.
Please follow these steps to be able to solve the issue on your Skype fro your Nexus 7 device.
To clear data and cache and to force stop Skype:
In the home screen, tap Settings > Applications (or Apps).
Tap Skype or if necessary, select Manage Applications > Skype.
Tap Clear Data. If necessary, please tap OK to confirm.
Tap Clear Cache. If necessary, please tap OK to confirm.
Tap Force Stop and tap OK to confirm.
To uninstall Skype for Android:
Select Uninstall.
To download the latest version of Skype on your Android device, please follow the steps found here:
https://support.skype.com/en/faq/FA10653/how-do-i-get-skype-on-my-android-device
To learn more about Skype 4 for Android phones, follow the link below:
https://support.skype.com/faq/FA12288
To learn more about Skype 3.2 for Android phones and Skype for Android tablets running in the Classic view, visit:
https://support.skype.com/faq/FA11040
To learn more about Skype for Android tablets, visit:
https://support.skype.com/faq/FA12160
We hope you found this answer helpful. Should you need any further assistance or have additional questions please do not hesitate to contact us again.
Best regards,
Mark Louie B.
Hello Aleksandar,
Thank you for your reply.
We are sorry to hear that the previous steps did not work. We're here to provide further assistance.
Please first ensure you have the latest Skype by visiting skype.com on your device and downloading Skype from Google Play. Alternatively, go directly to Google Play, search for Skype and download the application to your handset.
In case problem still occurs with the latest version please provide us with the following information for investigation.
Check minimum requirements https://support.skype.com/en/faq/FA12309/
Exact steps to took before problem occurred
Device name/model and OS version
Which network you use WiFi / 3G / 4G
Confirm Skype version: https://support.skype.com/faq/FA12194
If your Android device has OS version prior to 4.1 (pre-Jellybean devices, like Android 2.3.X) then please try to create logs as guided here: https://support.skype.com/faq/FA12220
Send us the logs from catlog folder on sdcard - /sdcard/catlog/saved_logs.
We look forward to your response, so we can assist you further.
Best regards,
Pauline A.
Hello Alexander,
Thank you for getting back to us.
We need additional information in order to help us resolve this issue.
May we know if you're experiencing the same issue when using your front camera in other applications?
Please send us the above requested information by replying to this e-mail. We will be looking forward to your response so we can assist you further.
Best regards,
Kimberly Ann B.
A koji android tablet bi nam posavetovao da uzmemo umesto Nexus - a?Falicno je samo sto ima mrtve piksele i ona linija sa strane, zvuk i tuzan ekran je ono od cega ne moze da se pobegne. Jedino sto je rezolucija dobra pa su slova jasna. Ja ga licno u zivotu ne bih uzeo, da gledam u crnu koja je kao ljubicasta i probijanje svetlosti na sve strane. Ocena 5/10 maximalno. Odjavljujem se sa teme i nosimo ovu spravu nazad dok jos radi.
Samo sam pitaoEvo tebi da odgovorim jer konkretno pružaš nešto zajednici, inače ne planiram da ulazim u raspravu, rekao sam kako jeste da ljudi znaju i drugu stranu priče.
Nijedan ne preporucujem (mozda ipad ili note najnoviji), ako je crna na svakom ovako losa, da cak i vuče na ljubičasto, džaba im sve (ne tražim amoled, nego da bar liči na nešto). Na stranu sto ovaj primerak imao 2 mrtva piksela u startu, zvuk je preslab i svetlost dosta probija. Trebalo je da slikam sve, i tu crtu u uglu ekrana, nego smo gledali sto pre da vratimo nazad i uzmemo pare. Tablet radi fino, brz je, ali ovo oko ekrana je smešno i ne ispunjava neke moje osnovne kriterijume, kao ni zvučnici. Koliko ga ljudi dižu u nebesa, nije ni cudo da se drug zaleteo i kupio bez testiranja. Srećom pa nije preko oglasa kao dosta ljudi pa da nema keš nazad.
Hello Aleksandar,
We are sorry to hear that your having issues with your camera on your Skype for Android application. We know how important it is to have this issue fixed.
We have included a list of suggestions below that should help you to solve the problem.
First, please try to clear Skype data. To do this:
Tap on native device's Settings.
Tap on Manage Applications > Skype.
Tap on clear data.
If the problem persist, uninstall/reinstall Skype. To uninstall Skype for Android:
Select Uninstall.
Reinstall Skype from Play Store.
To get Skype on your Android device, visit skype.com using your mobile browser and download it from Google Play (formerly the Android Market). Alternatively, go directly to Google Play, search for Skype and download the application to your device. Once downloaded, Skype is installed and ready to run. There is no separate installation process needed.
If you need any help, you can contact us via live chat to talk to one of our support representatives.
To start the live chat, follow this link:
https://skype.ehosts.net/netagent/c...4&portid=16B6D921-5580-41AA-977F-78E1EA583CB6
Please note that live chat is currently available in English only.
Should you need more assistance, feel free to contact us again.
We’d also like to advise you to update your Skype profile with the latest details. This will help us to provide you with the best possible solution more quickly and protect your account from abuse.
To learn how to update your Skype profile:
https://support.skype.com/faq/FA12314/
Best regards,
Boots C.
Samo sam pitaoznas da se ja nikad ne raspravljam i ne svadjam ovde na forumu
Apple nikada ne bih uzeo, njih nesto hejtujem, jednostavno ne volim iOS, ali njihova izrada je odlicna. Samsungovi tableti jednostavno ne mogu da primirisu Nexusu, imao sam ih.
Mozda ti je stvarno zapao neki los primerak
@ all
Ima li neka aplikacija da testiram mrtve pixele i gde da primetim to probijanje svetlosti?
A za mrtve piksele ne možeš u potpunosti da proveris jer ostaju dole soft dugmici. U svakom slučaju, ako ne vidis, nemoj da ih trazis da te ne nerviraju dzabe.
A sto se tice max brightness-a me bas cudi da je na 7" veci nego na 4.3 xD Nemoj da poredis sa s2 starim 1000 dana x)
Ko je uzeo u radnji, uvek moze da vrati i zameni ili uzme pare nazad, tako da ne vidim kakve veze sad imaju oglasi i preprodavci.
Ko je uzeo od nekog preprodavca, neka se njemu zali ako se javi problem, svesno je usao u taj rizik kupovine bez garancije, a ko je kupio u radnji nema potrebe da panici, sem neprijatnosti da nesto prvi put nije radilo kako valja.
Ako zelis da upozoravas na preprodavce onda idi lepo na oglase pa upozori ljude da ne kupuju, a ne Perici je javio feler na klikeru i nemoj niko da kupuje vise klikere.
Jel lepo ovde covek javio da je imao problema na dva uredjaja sa mrtvim pikselima, i lepo otisao i zamenio, sad ima uredjaj bez felera i sta sad?
Aman vise. Pa kako mozes da procenis iredjaj kada si dobio FELERICAN?
To ti jenkao da sudis o BMW-u na osnovu havarisanog koji si kupio. Stvarno nema smisla...
