Google Nexus 7 - model 2013.
Kad izlazi? :)
Koliko u proseku imate screen on time?
Код мене батерија разбија. Иде и до 10 сати сурф и књиге. Филмови, сурф, књиге и Tune in радио цео дан скоро 9 сати. До јајца је што се тиче батерије.;)
vesela prepiska sa verovatno celim timom skajp support-a.
posaljem da ima bag sa prednjom kamerom, kako dva meseca nema resenja, bla bla
Hello Alexander,
Thank you for contacting Skype Customer Service.
We understand your concerns regarding your camera on your Skype for your Nexus 7 device. We would be happy to help you with this.
Please follow these steps to be able to solve the issue on your Skype fro your Nexus 7 device.
To clear data and cache and to force stop Skype:
In the home screen, tap Settings > Applications (or Apps).
Tap Skype or if necessary, select Manage Applications > Skype.
Tap Clear Data. If necessary, please tap OK to confirm.
Tap Clear Cache. If necessary, please tap OK to confirm.
Tap Force Stop and tap OK to confirm.
To uninstall Skype for Android:
Select Uninstall.
To download the latest version of Skype on your Android device, please follow the steps found here:
https://support.skype.com/en/faq/FA10653/how-do-i-get-skype-on-my-android-device
To learn more about Skype 4 for Android phones, follow the link below:
https://support.skype.com/faq/FA12288
To learn more about Skype 3.2 for Android phones and Skype for Android tablets running in the Classic view, visit:
https://support.skype.com/faq/FA11040
To learn more about Skype for Android tablets, visit:
https://support.skype.com/faq/FA12160
We hope you found this answer helpful. Should you need any further assistance or have additional questions please do not hesitate to contact us again.
Best regards,
Mark Louie B.
Hello Aleksandar,
Thank you for your reply.
We are sorry to hear that the previous steps did not work. We're here to provide further assistance.
Please first ensure you have the latest Skype by visiting skype.com on your device and downloading Skype from Google Play. Alternatively, go directly to Google Play, search for Skype and download the application to your handset.
In case problem still occurs with the latest version please provide us with the following information for investigation.
Check minimum requirements https://support.skype.com/en/faq/FA12309/
Exact steps to took before problem occurred
Device name/model and OS version
Which network you use WiFi / 3G / 4G
Confirm Skype version: https://support.skype.com/faq/FA12194
If your Android device has OS version prior to 4.1 (pre-Jellybean devices, like Android 2.3.X) then please try to create logs as guided here: https://support.skype.com/faq/FA12220
Send us the logs from catlog folder on sdcard - /sdcard/catlog/saved_logs.
We look forward to your response, so we can assist you further.
Best regards,
Pauline A.
i nakon odgovora novi
Hello Alexander,
Thank you for getting back to us.
We need additional information in order to help us resolve this issue.
May we know if you're experiencing the same issue when using your front camera in other applications?
Please send us the above requested information by replying to this e-mail. We will be looking forward to your response so we can assist you further.
Best regards,
Kimberly Ann B.
naravno nista reseno i dalje...
haha bas su ti pomogli..prate te ludim..kao da si cuo za skajp juce i kao da ne znas nista o telefonima..eto to je pomoc njihova..
Ovo mi deluju kao genericki mejlovi, samo menjaju imena svojih radnika, kao i imena onih koji im salju zalbe.
Al vidi se kako blage veze nemaju ni oni.Na ovo da obrisem Cache i Data sam se smejao do suza.:)
Samo par recenica o uredjaju:
Drug je malopre uzeo nov u radnji, dodje kod mene da probamo i vec ce da ga vrati odakle je i dosao. Zasto?
1. Zvuk je preslab
2. Probijanje svetla nenormalno, a crna nije crna nego ljubicasta
3. Sa desne ivice ekrana gore ima 1cm neku liniju kao ekran da nije lepo odradjen
4. Ima nekoliko mrtvih piksela, plus prasinu koja je zapala u procesu proizvodnje
Sve u svemu, ima razlog zasto je jeftiniji od vecine tableta i nas savet: kloniti se uredjaja.
Da se klone uredjaja jer je tvom drugu upao falican primerak.. ?
Falicno je samo sto ima mrtve piksele i ona linija sa strane, zvuk i tuzan ekran je ono od cega ne moze da se pobegne. Jedino sto je rezolucija dobra pa su slova jasna. Ja ga licno u zivotu ne bih uzeo, da gledam u crnu koja je kao ljubicasta i probijanje svetlosti na sve strane. Ocena 5/10 maximalno. Odjavljujem se sa teme i nosimo ovu spravu nazad dok jos radi.
Znaci mi svi kojima radi super isto da vracamo....maaaaamu im...
:d:d:d
Svašta se u ovde može pročitati
A koji android tablet bi nam posavetovao da uzmemo umesto Nexus - a?
Za moj sadašnji (a bogami i za prethodni, tj. stari model) važi: You can pry it out of my cold dead hands :)
Ma sigurno nase nismo dobro pregledali ***....cekaj evo ga mrtav piksel......a ne ipak je prasina.,ah bedak skinulo se, preko ekrana je..:(
Danas sam na sajmu imao prilike da probam ponovo N7, definitivno onaj moj primerak imao problem sa touchom. Eto desava se da zapadne tako los primerak sto me je i odvuklo od ideje da mi ga donesu iz usa jer je previše rizicno ili je to samo na eu tržištu tako nzm. Ekran mu je za 10ku kada se uporedi sa ostalim 7inchim tabletima i tu nema dalje diskusije, ja sam se na kraju ipak odlučio za nesto drugo i sigurno da mi najvise od svega fali ta ostrina ekrana.
Evo tebi da odgovorim jer konkretno pružaš nešto zajednici, inače ne planiram da ulazim u raspravu, rekao sam kako jeste da ljudi znaju i drugu stranu priče.
Nijedan ne preporucujem (mozda ipad ili note najnoviji), ako je crna na svakom ovako losa, da cak i vuče na ljubičasto, džaba im sve (ne tražim amoled, nego da bar liči na nešto). Na stranu sto ovaj primerak imao 2 mrtva piksela u startu, zvuk je preslab i svetlost dosta probija. Trebalo je da slikam sve, i tu crtu u uglu ekrana, nego smo gledali sto pre da vratimo nazad i uzmemo pare. Tablet radi fino, brz je, ali ovo oko ekrana je smešno i ne ispunjava neke moje osnovne kriterijume, kao ni zvučnici. Koliko ga ljudi dižu u nebesa, nije ni cudo da se drug zaleteo i kupio bez testiranja. Srećom pa nije preko oglasa kao dosta ljudi pa da nema keš nazad.
Ipad ne moze da se poredi sa Nexusom 7, jer ima veci ekran. Jedino da poredis Nexus 10 i Ipad.
Sto se tice Ipad Mini-a, bolji je Nexus u svakom pogledu..
Isprobao sam i Galaxy Note 8.0, kao i Galaxy tab 3, i zakljucio sam da ne mogu da se porede sa novim Nexusom, prvenstveno po brzini a zatim i po kvalitetu displeja.
Trenutno nisam nasao bolji tablet od 7 inch-a, iako sam trazio sve i svasta. Trziste tableta je jos uvek u razvoju i tek ce izlaziti fenomenalni modeli.
Ovo je po meni trenutno najbolji tablet u svom domenu, i licno sam prezadovoljan tabletom.
Jedva cekam da izadje Android 4.4 Kit Kat i da vidim kakvo je novo korisnicko iskustvo i sta nam je novo pripremio Google.
PS: Takodje ne bih mogao prezaliti da sam uzeo neki drugi tablet koji nije Nexus, pa da dobijem svega 2 update-a uz nekakav trosim memoriju-interfejs i da mogu da se pozdravim sa novim aktuelnostima i boljim verzijama Androida dok ne kupim novi uredjaj. (Ne racunam CUSTOM rom-ove, jer sam na prethodna tri mobilna telefona izmenio vise od 30 sistema i zakljucio da sto je STOCK, to je STOCK i tu nema dileme. Jedino su prednost neke sitnice, kao sto su pojedine beneficije kad imas rootovan uredjaj, recimo blokiranje reklama, malo overklokovanja cisto iz zezanja, itd.)
@shatroghistro
Kako ne shvatas ovo sto ti ljudi pisu?!
Kazu ti da su svi ti problemi iskljucivo kod tvog, iz aviona jasno felericnog primerka. I da nijedan drugi uredjaj nema te probleme. Idi u bilo koju prodavnicu i uzmi izlozeni primerak pa ces se i sam uveriti.
Jedino je jacina zvuka sporna. Ali sobzirom da ti je zapao felerican primerak, moguce da je i zvuk slabiji nego na ostalim/normalnim primercima.
Samo sam pitao :) znas da se ja nikad ne raspravljam i ne svadjam ovde na forumu
Apple nikada ne bih uzeo, ne zato sto ih nesto hejtujem, jednostavno ne volim iOS, ali njihova izrada je odlicna. Samsungovi tableti jednostavno ne mogu da primirisu Nexusu, imao sam ih.
Mozda ti je stvarno zapao neki los primerak
@ all
Ima li neka aplikacija da testiram mrtve pixele i gde da primetim to probijanje svetlosti?
Imas na google play dosta njih. Samo kucaj "dead pixel". U sustini oni pustaju osnovne boje na ekranu, pa ti gledas da li je neki pixel mrtav ili zaglavlje. Za probijanje bi trebali da imaju povecanje/smanjenje osvetljenja.
Ako se secas ti testovi su ugradjeni u stock samsung androida, a pristupa im se preko USSD koda.
Bice da se ponavljam ali kome se jednom dese problemi OOTB... nije svejedno.
Hajde kazes ok mozda se tako desilo bas mene zapalo ali ako se desi opet pa jos jednom... nije svejedno. Ja prosto precrtam nekog proizvodjaca i stavim tacku.
Da ne spominjem problem sa garancijom kada 2 mrtva pixela i nekakvo parce necega ispod stakla nije bilo dovoljno da ubedim prodavca da tablet nije ok.
Ja donekle za Nexus tablete i razumem to je sve masovna proizvodnja ali da se toliko NE gleda sta se trpa u tablet... ja ne mogu da razumem.
Kontam da im se mnogo bolje isplati da ne gledaju uopste sta stavljaju i da ne usporavaju proizvodnju pa nakon toga sve one tablete koji se vrate a kladim se da je broj ogroman, obrisu nesto kao poprave i prodaju 20-30% jeftinije.
Pa valjda kad je nesto ocigledno felericno, ode se i zameni se, sem ako nije ispod zita kupljeno.Ili je mozda to zabranjeno u toj radnji?
Eno bagovi sa iOS-om, i sta mi sad treba da trcimo na apple teme i da vicemo kako treba da zaobilaze iphone-ove i ipad-ove u sirokom luku?Smesno.
Elem....novi mail.
Hello Aleksandar,
We are sorry to hear that your having issues with your camera on your Skype for Android application. We know how important it is to have this issue fixed.
We have included a list of suggestions below that should help you to solve the problem.
First, please try to clear Skype data. To do this:
Tap on native device's Settings.
Tap on Manage Applications > Skype.
Tap on clear data.
If the problem persist, uninstall/reinstall Skype. To uninstall Skype for Android:
Select Uninstall.
Reinstall Skype from Play Store.
To get Skype on your Android device, visit skype.com using your mobile browser and download it from Google Play (formerly the Android Market). Alternatively, go directly to Google Play, search for Skype and download the application to your device. Once downloaded, Skype is installed and ready to run. There is no separate installation process needed.
If you need any help, you can contact us via live chat to talk to one of our support representatives.
To start the live chat, follow this link:
https://skype.ehosts.net/netagent/c...4&portid=16B6D921-5580-41AA-977F-78E1EA583CB6
Please note that live chat is currently available in English only.
Should you need more assistance, feel free to contact us again.
We’d also like to advise you to update your Skype profile with the latest details. This will help us to provide you with the best possible solution more quickly and protect your account from abuse.
To learn how to update your Skype profile:
https://support.skype.com/faq/FA12314/
Best regards,
Boots C.
:D ovo definitovno niko ne cita, samo vrte 3-4 iste seme mejla kad se neko pozali i sad kad bih nastavio, vrteli bi iste mailove.:)
Apple nikada ne bih uzeo, njih nesto hejtujem, jednostavno ne volim iOS, ali njihova izrada je odlicna. Samsungovi tableti jednostavno ne mogu da primirisu Nexusu, imao sam ih.
@ all
I ja ne mirisem apple ni najmanje (cak sam i dobio ban na 7 dana kada sam napisao za 5s par reci u smislu "bas su revolucionarni, svaka im cast" i emoticon puke), a kad sam pogledao poslednji klip kako cekaju po 15 dana u redu i spavaju u djubretarskoj kesi, jos ih vise ne podnosim, ali svi kazu za tablet samo ipad.
Sto se tice nexusa, idem na sajam pa cu da pogledam tamo, mada uvek je previse osvetljeno. Ovo jeste bio felerican primerak, ali sam prilicno siguran da bolji prikaz crne (da bar lici na nesto) i bolji zvuk ne moze da se dobije. Gledao sam na gsmareni i brojevi se poklapaju. Jeste da za najmanje para se najvise dobije, ali ipak dosta stvari nisu kako bi trebalo pa ce se preskočiti i ova serija. Bas mi krivo sto nisam slikao\snimio.
A za mrtve piksele ne možeš u potpunosti da proveris jer ostaju dole soft dugmici. U svakom slučaju, ako ne vidis, nemoj da ih trazis da te ne nerviraju dzabe.
Krajnje netačno. Skineš Dead Pixel Test ili neku sličnu aplikaciju i startuješ. Pojavi se skroz beo ekran sem soft tastera dole, pogledaš, zarotiraš tablet za 90 stepeni, soft tasteri se pomere i tako u krug, istestiraš ceo erkan na mrtve piksele, posle toga dodirneš ekran bilo gde i ekran bude skroz crn sem soft tastera. Proveriš da nema zaglavljenih (stuck, tj. svetlih piksela) i opet u krug da ispomeraš soft tastere.
Takođe, kad je skroz taman ekran možeš da proveriš i da li ima probijanja pozadinskog osvetljenja i sl.
Sa sve skidanjem Dead Pixel Test-a (aplikacija je velika 20 kB) ovo traje možda 2 minuta i proveriš ceo ekran bez problema.
Inače imam Galaxy S2 i mada crna boja na N7 ne može da se meri sa SAMOLED-om, sve ostalo je daleko bolje na N7 - na S2 boje su prezasićenje, kolorit je skroz pogrešan i sve deluje veštački, fotografije nemaju prirodne boje, video materijal deluje kao crtani film i isto je bilo sa svakim SAMOLED ekranom koji sam video - džabe prava crna kad sve ostalo nije realno.
Takođe, max brightness na N7 je daleko veći i bela je baš bela, ne neka plavičasta ili žućkasta. Na N7 je oko 580 nits, dok je na tvom Note II sa kojim ga verovatno porediš ~250 nits.
Pošto očigledno da porediš sa svojim Note2 koji veličaš zbog jedne dobre karakteristike koju ima (crna), pogledaj malo i ostale karakteristike ekrana pa onda lepo idi i vrati svoj neosvetljeni i prezasićeni Note II:
http://www.anandtech.com/show/7231/the-nexus-7-2013-review
http://www.anandtech.com/show/6386/samsung-galaxy-note-2-review-t-mobile-/8
Moze ta fora sa rotiranjem.
Nisam poredio sa note 2, bio je na punjaču i mrzelo me da skidam, sam pogled na crnu mi je bio jasan da vuce na ljubičastu. Bela na amoledu nije bela ali daleko da je ocajna kao sto je na n7 crna. Boje jesu prirodne, ali na s4 imas mode da boje izgledaju prirodnije. A sto se tice max brightness-a me bas cudi da je na 7" veci nego na 4.3 xD Nemoj da poredis sa s2 starim 1000 dana x)
Samo hocu da upozorim ljude da nije sve kako se priča jer ne mogu da vrate i uzmu pare kao moj drug jer dosta njih\vas kupuje po oglasima. Onda se sve mane zanemare i stupa na snagu "svaki ciga svog konja hvali".
Ko je uzeo u radnji, uvek moze da vrati i zameni ili uzme pare nazad, tako da ne vidim kakve veze sad imaju oglasi i preprodavci.
Ko je uzeo od nekog preprodavca, neka se njemu zali ako se javi problem, svesno je usao u taj rizik kupovine bez garancije, a ko je kupio u radnji nema potrebe da panici, sem neprijatnosti da nesto prvi put nije radilo kako valja.
Ako zelis da upozoravas na preprodavce onda idi lepo na oglase pa upozori ljude da ne kupuju, a ne Perici je javio feler na klikeru i nemoj niko da kupuje vise klikere.
Jel lepo ovde covek javio da je imao problema na dva uredjaja sa mrtvim pikselima, i lepo otisao i zamenio, sad ima uredjaj bez felera i sta sad?
Kakve veze ima veličina ekrana sa maksimalnim osvetljenjem (jačinom pozadinskog osvetljenja)?
Ovo su samo primeri:
iPhone 5 - 4 inča - 600 nits
iPad 4 - 9,7 inča - 400 nits
Nexus 7 (2013) - 7 inča - 580 nits
Galaxy Note 8.0 - 8 inča - 480 nits
Galaxy S2 - 4,3 inča - 300 nits
Note II - 5,5 inča - 250 nits
Nexus 7 (2013) ima izuzetno jako pozadinsko osvetljenje, za korišćenje napolju je fantastičan. Od kada sam stavio mat foliju nemam više ni odsjaj napolju i mogu da ga koristim praktično ne obraćajući pažnju s koje strane mi ide ambijentalno osvetljenje.
Ne upozoravam na preprodavce nego da znaju da nije sve sjajno bajno i da ako se pod utiskom da je sve naj naj zalete i kupe na oglasu da mogu da zažale. I stoti put, ne pricam o mrtvim pikselima, nego komplet utisak van toga da je tablet loš. Ne u odnosu na druge nego jednostavno nije to to: i zvuk i to probijanje svetla i crna je deal breaker.
@mighty- veca povrsina pa vise isijava, nisam mislio konkretno na te brojke, ali hvala za podatke.
Aman vise. Pa kako mozes da procenis iredjaj kada si dobio FELERICAN?
To ti jenkao da sudis o BMW-u na osnovu havarisanog koji si kupio. Stvarno nema smisla...
Naravno da nije tako, poredjenje ti nema logike. Dal da ponovim deseti put.. Ne pricam o felerima nego o nečemu što je van tih felera na svakom nexusu: los zvuk i ne los nego očajan prikaz crne, a na tom tipu ekrana me ne bi čudilo da na svakom ima probijanje svetla. Rekao sam sta sam imao, necu vise da se ponavljam. Isto kao kad su tvrdili neki da note 1 nema black clipping. Sutra cu na sajmu da vidim i taj primerak.
