Hardrockdrinker
Cenjen
Jedino je R9 290 nesto "novo" , ostalo je sve rebrend po drugi put ?
http://videocardz.com/45877/amd-radeon-r9-280x-rebranded-hd-7970-ghz-edition
R9 280 ( 7970 Ghz ) treba da bude odgovor na GTX 770 sto vec sad moze da nagovesti kakve su performanse
R9 290 . Nema nista od Titan killera, fali im samo cirka 50 % minimum
"The site is also claiming that R9 290X is faster than GTX 780, while not as fast as TITAN, but that may depend on the settings you choose with the BIOS switch, which is a new standard for reference flagship models from AMD."
Nazalost, sve je ovo manje ili vise ocekivano...
