nikola1970
Ko ima problema sa ERROR porukom tokom update-ovanja na 4.3, evo rešenja, ja sam ovo uradio. Brišu se svi podaci zato uradite backup svega:
1. Download the toolkit here: http://forum.xda-developers.com/showthread.php?t=1809195
2. Install the toolkit to the default C:\ folder it tells you to
3. When launching the toolkit it will ask you which version of android you're running (I was number 15)
4. Install the device drivers (option 1)
5. Download 4.3 from here: https://developers.google.com/android/nexus/images (specifically I downloaded ' Factory Images "nakasi" for Nexus 7 (Wi-Fi), version 4.3 (JWR66V))
6. Put the factory image in: C:\Google_Nexus_7_ToolKit\put_google_factory_image _here\
7. Turn off your Nexus 7, turn it back on holding the power button and both volume + and volume -
8. Plug in the USB cable
9. Select "option 3 - unlock / relock bootloader" and follow the steps, it will the come up on the Nexus 7 telling you you're about to unlock it; us the volume buttons and power button to select ok
10. Select "option 9 - Download, Extract and Flash google factory stock rom"
11. Select "option 2 - flash google factory image" on the next screen
12. Follow the instructions typing yes where it needs (Note. the checksum did not match for me!), keep following the instructions..
13. Device will reboot after it transfers across and boot into 4.3 - complete the setup process
14. After the setup process is finished, plug it back in and select 'option 3' and relock the bootloader!
