Koliko ce to uticati na performanse u 1080p? Ja bih rekao ni malo. 🙂
Nove konzole ce imati vise od 4GB VRAMa pa ako hoces da ti karta traje duze od godinu dana, zeleces sto vise GDDR5 RAMa.
Kome se ne zuri da kupuje novu grafiku, bolje mu je da preskoci ovu seriju i saceka sledecu godinu i Maxwell, bice dosta isplativija kupovina, imo.
Masala.$699 to $759
Kako će to napredak biti ogroman ako ga nećemo videti?
Koja je poenta ove serije... Ovo se zove zbrzano izdavanje.
PCBeast, a reci mi da li uopšte ima poboljšanja kod GTX 770 kartice, vidim da ima apsolutno identične specifikacije kao i GTX 680...jel samo nešto tu tweakovano ili je u pitanju rebrandirani GTX 680 ?
Pa poenta je da se izbaci novi chip, tj druga generacija na istoj arhitekturi nakon godinu dana od izlaska prethodne perjanice. To sto je konkurencija udarila u wall i ceka die-shrink i vise nije ahead of the curve, ne znaci da treba sve da stoji u mestu. Dakle, never settle :d
Jedino su problem cene za krajnje korisnike...
Rebranded 600 series, faster than predecessors
Our sources were happy to share some additional details about Nvidia’s upcoming cards. It turns out that the GTX 760 Ti, the slowest of the bunch, is based on the GK104 225 chip. The GTX 750 Ti has a 256-bit memory interface and in reality represents a rebranded GTX 670. It looks dangerously similar to existing GTX 670 boards.
Add-in-board partners expect to start selling this card in the third week or June and they will be able to make their own custom cards. We don’t know much about performance but we expect it to be around GTX 670 levels. The Geforce GTX 770 is based on a somewhat faster GK 104 425 chip, again a 256-bit unit, and our sources are telling us that the card is more or less a GTX 680 renamed for 2013. Nvidia will allow AIBs to manufacture their original boards but the cooling solution on the card looks like the one from GTX Titan.
The cooler better known as NVTTM cooling fan will let this chip clock higher than GTX 680 and should deliver at least a five percent performance boost over the GTX 680. The card is expected in the first week of June. The fastest of them all, based on the huge GK110 chip is the Geforce GTX 780. The card also shares a 256-bit memory buss and is based on GTX Titan LE. The first cards come as Nvidia direct boards and will be directly supplied to partners.
Nvidia will make these cards at first as it wants to control the quality and make sure nothing goes wrong in the manufacturing process. The card was supposed to launch on May 23rd but out sources now insist that it might show a week earlier on the May 16th, but we will try to find out which of these two dates is right.
In addition to that, atleast the proof that’s provided with the post has leaked the entire specifications for the GeForce GTX 770 GPU. The core clock is maintained at a high 1059 MHz while boost clock goes as far upto 1125 MHz which is pretty impressive, additionally It features a 2 GB GDDR5 memory running across a 256-bit bus and has 1536 cores, the same number as the previous generation flagship GeForce GTX 680. The memory runs at the 7 GHz effective which is very high and might be dangerous for current GTX 680 boards so as advised before, this process should be done at your own risk. Performance of the GPU is expected to be around 5-10% faster than the GeForce GTX 680 at a cost near the GeForce GTX 670 around $399-$449.
