Far Cry 3
Koju verziju imas i pec? Jel rld? Meni se ovo na rld ne desava a imam onaj prvi pec. Ultra i gpu max buffered frames =1, sa tim podesavanjem mi je ono smaracko stucanje nestalo, 35 fps prosek a ti imas 60 a to na visokim detaljima i full hd ne moze ni gtx660ti da isprati, znaci nesto nije ok. Ne znam sta je ovo kod tebe..
Reloaded i onaj 1.01 patch instaliran koji je dosao s njim.
To i ja imam i sve je ok. Postoje igre koje imaju neke tripove da mozes da skrenes, pes npr sa onim seckanjem i duhovima, nije bitan monitor uopste.
Probaj nesto po opcijama vezano za max buffered frames ili vsync
Au Borise kako ti je gadan avatar. Izgubim apetit cim vidim. Vidi pa promeni na neke medvedice ili tako nesto emocionalno i romanticno :D
Kod caleta na e2160 i 4850 sve klokovano igra radi na 1280*1024 sa prosecnim fps-om oko 30. A podesavanja su na medium, texture jedino na high. Oseca se trzanje u blizini objekata i u zatvorenom, na otvorenom ne primecujem.
Patch 1.04
GENERAL FIXES FOR THE PATCH
Fixed several issues with customize controls
GENERAL
Improve stability on multiplayer maps.
Fixed the crash when the player was planting explosives.
Fixed several crashes.
Fixed bug where user was unable to jump on certain surfaces.
Fixed bug where players could become invisible.
Fixed bug with 3D weapon images in Decoding menu.
Fixed bug where weapons could disappear after completing objectives in Co-op.
Fixed bug where users could get stuck in Loadout screen in Co-op.
Removed “Reloading” shout after user shoots the bow.
Parties will no longer be allowed to numerically unbalance games.
Improved and fixed several issues with host migration.
Connection degradation will now properly trigger a host migration.
Fixed several bugs with Loadout menu.
Fixed bug that could display a profile restriction message when trying to join a lobby.
Fixed bug where users could get stuck in 3rd person in Custom games.
Fixed bug with Flamethrower not doing any damage in certain circumstances.
Fixed bug where “Player is on the way” tag could stick to downed players.
Fixed bug where clients could remain on black screen if host left the game.
Fixed bug where Fire Arrows did not do fire damage.
Fixed bug where Long Distance Kill was not awarded.
Fixed bug where Tag Assist was not awarded.
Fixed bug where Killcam wasn’t shown in certain circumstances.
Fixed bug where Survival Instinct was not cancelled properly.
Fixed bug where Psych gas could get dropped in the wrong place.
Fixed bug where Psych gas could affect players outside of the deployment area.
Fixed bug where users could get stuck when killed by Poison gas.
Fixed bug where other player’s footstep sounds sometimes did not play behind you.
Fixed bug where sound could get muffled when being revived.
Fixed bug where user could get de-synced if killed in mid-air
MAP EDITOR
Added information for Player Map playlists.
Improved available space for Player map names in lobby.
Fixed bug where User made maps wasn’t downloaded properly in lobby.
Fixed bug that made the user stuck when igniting Firestom nodes on certain maps.
SINGLE PLAYER
GENERAL
Fixed the accessing bug for the camera and the throwing rocks.
Users that have miss the Relic located in Dr. Earnhardt cave will have the relic recover.
Fixed the bug with the weapon models staying on screen / stuck on the charatcer arm.
The leaderboard is now updating correctly even after if the user is disconnecting/reconnecting the ethernet cable.
The objective is now properly updated after Jason burns the weed fields.
New options the hide the HUD are now available in the option menu.
Add support for downloadable content.
Fixed the issue when the user was becoming invincible after failing mission 'Black Gold' several times.
The Phonecall from Hurk (ULC missions) is no longer overlapping the brief of the 'Piece of the past' mission.
Fixed the issue when Sam was no longer in the jeep's turret after placing two bomb and being kill several time in 'Black Gold' mission.
Sam is no longer getting stuck when the user destroy an enemy car.
Dajte nemoguce da se samo meni javlja onaj problem?
Ne znam kako da objasnim najbolje, u onom snimku na HD se fino vidi, doduse ne kao kad bas igras.. Znaci mesavina ghostinga kod monitora, blura i preskakanja frejmova, bas onako zaboli glava..
Effects quality smanji na medium ili low da bi iskljucio motion blur, fov stavi negde na oko 85. A za trzanje ako imas problema probaj sa vsyncom ili ogranicavanjem maxfps-a u config fajlu, a ako ti se i tad pojavljuje (kao meni), onda nema resenja dok se igra propisno ne patchuje...
Ok.. samo nemam effects quality opciju.
PostFx u svakom slucaju stavi na medium jer dobijas i 10 fps u proseku vise.. prikaz je sasvim solidan i prihvatljivo (ne)iskrzan i sa post fx medium i 2xMSAA, kod tebe na full hd ima da izgleda jos bolje.
Ne igram na full hd, smanjio sam na 1600x900. Sad jeste malo bolje sa FOV 85, Gpu frame buffered 1 i Vsync 1. Ne znam sta smem da odvrnem tamo od opcija a da ne utice previse na performanse.. Ova voda na Very high nije dobra ni kao medium u Crysis 1.. Stvarno nista posebno grafika.
Grafika je u nekim momentima dobra kao warhead na gamer podesavanjima a cak ima i kao nekog kvazi dx11 osvetljenja i na ultra podesavanjima ume da deluje bas solidno ali je voda smesna kao i ono maskiranje brda, stena itd teksturama iz cs 1.6 :) :d
Jedan screen i od mene.. stene nisam smeo da slikam :D Btw, kako da ogranicim fps u config fajlu, nema nista da zvuci da je to, samo 'show fps'. I da, igru pokrecem na DX11.exe, a onda sam menjao i na dx9 (isto preko dx11.exe), gledam sta bolje radi, ali kad sam probao obican exe nemam nikakve save-ove. Jel isti djavo to, i kad namestim dx9 u dx11 fajlu?
Ljudi moji, jel ovo Boris ili su ga oteli vanzemljaci? :trust:
Sto? :D Mislis da uzivam u ovom bakcanju s grafikom :D
Ljudi, poceo sam da igram igru i imam problem sa autosave-om. Prvi save je zapamtio, a svaki sledeci se gubi i igra mi startuje uvek od tog prvog...
U cemu je fora?
Unapred zahvalan
Baš sam popizdeo, shebala mi se igra i sada kad vratim stare save-ove ne vidi ih uopšte, ima li neke pomoći?
Tek poceh onako intenzivnije da je igram, dok sam zavrsio AC3, sad ovo. Al sam bas zadovoljan kako je dosada, cini se da ce ovo da bude extra zabava. Doduse sada na pocetku mi nekako bas fali municije stalno :D. Moram se malo vise navikavati na stealth. Ili ima vise municije kasnije?
Sto se tice grafike, odvrnuo sam sve, osim 4xMSAA, dx11, sve radi ko podmazano. Jedino sto mi ova igra bas zagrije graficku, ode i do 80C, doduse dobro nasvirana.
I meni pobrisao SVE!!!Ima li rešenja za ovaj bug????
Ja apdejtovao na 1.04 i naravno izgubilo se sve sačuvano , premazao opet krek preko igrice i vratilo se :D
Tako da sad sve radi ok :)
Juce sam zavrsio i generalno mi se svidja igra. Igrao sam Blacke verziju.
Malo sam imao problema sa pucanjem igre zbog visokog kloka za CPU (jedva sam otkrio sta je u pitanju).
Smanjio klok na 4GHz i posle je bilo sve ok. Evo kako izgleda kod mene, AA 4x, postavka kao na Ultra osim post fx na medium.
Fps od 35-50. GPU na def, bez kloka.
    110.9 KB · Pregleda: 94
    92.8 KB · Pregleda: 87
    101.4 KB · Pregleda: 88
    254.2 KB · Pregleda: 120
    384.5 KB · Pregleda: 128
odakle ti prigusivac?
Ovako ne mogu da igram, kako god da podesim ovo se desava, kao da imam neki od prvih LCD monitora pa se javlja ghosting.. Pokazuje mi da imam 60 fps.
Ne vidim ja ovde nikakav ghosting.Ovo je upravo taj microsttuter o kome je zapoceta debata od skoro.
Imas kasnjenje..
Da li si probao sa najnovijim patch-em?Imas jos dva komada ,koliko vidim izasao je i 1.04v !
Jesi probao sa drugim driverima?
Skinuo sam najnovije drajvere.. Patch nisam. Kad bi mogao jos neko da snimi da vidim kako je kod vas..
