Samsung I9300 Galaxy S III
Neoficijelni način je da uradiš root, a zatim skidaš najnovije stock romove (npr. odavde: Stock Official Firmwares) i flešuješ ih iz CWM-a bez full wipe-a (wipe data/factory reset), već samo sa wipe cache i wipe dalvik.
Odavno se nisam nalupao kao u ovom postu :S:,nećeš se naflešovati stock romova kroz CWM :)
Opisani način je ako želiš da flešuješ custom romove bez brisanja podataka. Tu mora prvo root.
Stock romove ćeš morati preko odin-a, root za njih nije ni potreban, kao što reče -=crusader=-
Taj okvir je najlosije odradjen deo na celom telefonu, aj sto ima te linije al sto se lako grebe a ispod ostaje crno katastrofa.
Istom magijom kojom bi nasli kriptonit van Sci-Fi stripova :)
Mozda se Superman krije iza cirilice.
To jeste tacno, iako sam znao - ali ovako je interesantnije :)
Mislim da nije bilo.
Samsung Galaxy S3 Secret Codes-
*#1234# (View SW Version PDA CSC, MODEM)
*#0*# (General Test Mode)
*#12580369# (SW & HW Info)
*#197328640# (Service Mode)
*#0228# (ADC Reading)
*#32489# (Ciphering Info)
*#232337# (Bluetooth Address)
*#232331# (Bluetooth Test Mode)
*#232338# (WLAN MAC Address)
*#232339# (WLAN Test Mode)
*#0842# (Vibra Motor Test Mode)
*#0782# (Real Time Clock Test)
*#0673# (Audio Test Mode)
*#2263# (RF Band Selection)
*#9090# (Diagnostic ConfiguratioN)
*#7284# (USB I2C Mode Control)
*#872564# (USB Logging Control)
*#4238378# (GCF Configuration)
*#0283# (Audio Loopback Control)
*#1575# (GPS Control Menu)
*#3214789650# (LBS Test Mode)
*#745# (RIL Dump Menu)
*#746# (Debug Dump Menu)
*#9900# (System Dump Mode)
*#44336# (Sofware Version Info)
*#7780# (Factory Reset)
*27673855# (Full Factory Reset)
*#0289# (Melody Test Mode)
*#2663# (TSP / TSK firmware
update)
*#03# (NAND Flash S/N)
*#0589# (Light Sensor Test Mode)
*#0588# (Proximity Sensor Test
Mode)
*#2732832553282*# (Data Create
Menu)
*#273283255663282*# (Data Create
SD Card)
*#3282727336*# (Data Usage Status)
*#7594# (Remap Shutdown to End
Call TSK)
*#34971539# (Camera Firmware
Update)
*#526# (WLAN Engineering Mode)
*#528# (WLAN Engineering Mode)
*#7412365# (Camera Firmware
Menu)
*#80# (Unknown)
*#07# (Test History)
*#3214789# (GCF Mode Status)
*#272886# (Auto Answer Selection)
*#8736364# (OTA Update Menu)
*#301279# (HSDPA/HSUPA Control
Menu)
*#7353# (Quick Test Menu)
*27674387264636# (Sellout SMS /
PCODE view)
*#7465625# (View Phone Lock
Status)
*7465625638*# (Configure Network
Lock MCC/MNC)
#7465625638*# (Insert Network Lock
Keycode)
*7465625782*# (Configure Network
Lock NSP)
#7465625782*# (Insert Partitial
Network Lock Keycode)
*746562577*# (Insert Network Lock
Keycode SP)
#746562577*# (Insert Operator Lock
Keycode)
*746562527*# (Insert Network Lock
Keycode NSP/CP)
#746562527*# (Insert Content
Provider Keycode)
#272imei# Product code
Pitanje: Za software update pita me da izaberem zemlju. Da li da izaberem srbiju ili United Kingdom ili neku drugu?
Pitam to zbog redovnosti update-a
Septembar - Oktobar...
ahhh ja misli da ce sutra da ga puste ;(
http://global.samsungtomorrow.com/?p=17786
Odličan i ovaj Toffee braon :)
hoce neko da menja plavi za sivi?XD
Konačno baterija ok. Battery booster preporučujem posle par dana stvarno valja.
    31.6 KB · Pregleda: 198
Jel mogu ja nekog da zamolim da mi detajno objasni sta na odinu predstavlja
PIT:
PDA:
PHONE:
CSC:
Fleshovo sam ja romove i sl ali uvek radim po pisanom uputstvu i to prodje ok, al me zanima konkreno sta je sta i cemu sluzi zasto se nekad koristi samo pda a nekad sve i sl.
Bio bi zahvalan ako neko nadje malo vremena :)
PDA ti je ROM, CSC je country code valjda za koju državu je pravljen, koje ćeš jezike imati itd, a phone je modem vezano za mrežu ;)
Pit nisam siguran šta je, ali mislim da je to nešto što se tiče memorije, particionisanje ili tako nešto :)
Evo ja googlam u medjuvmrenu kolko sam skapirao to mu dodje to sto si ti napisao.
E sad kolko sam ja razume (ispravite me ako gresim plz) 2 farijante samo update na novijuverziju do mu dodje kad kroz odin ide samo .pda i ti fajlovi su obicno 80-100 mb a kad ide komplet instalcija sve ispocetka onda ide pda modem csc i to mu dodje npr ovo sa xda http://forum.xda-developers.com/showthread.php?t=1646610 oko 800 mb. ?:)
Pit je za ponovno reparticionisanje kompletne interne memorije: data, cache i sdcard.
