Ово није лоше, јер сам са сорсерком могао да се млатим против скелетон кинга 1 на 1, да ме он туче и једва скида хелт, мислим да сам свега 1 напитак попио, а то је требала да буде тежа борба.Svi monsteri imaju veci damage [po nekim najavama duplo veci]
Today, we wanted to let you know that we’ve made the difficult decision to hold back the PvP Arena system and release it in a patch following the game’s launch.
what is currently in the beta is what we intend for ship, but we're still tuning and things can change.
I ja sam mislio da te Skill rune su drop itemi, da nadjes neku runu i prikacis je za skill i da postoje jace verzije. I sa ovim auto atributima bas su pojednostavili igru, mogli su da stave da mozes automatski da dodeljuje i recimo da mozes ti ali da postoje neki NPC/item/magicni altar gde das gold i mozes recimo jedan attribut da resetujes. Jer ovako imas mnogo nekog atributa iz nekog itema a fali ti neki drugi.
Current issues:
-Running FRAPs, or launching the game with Steam Overlay makes the filter possibly not work on NVIDIA cards.
-The game seems to crash with the "d3d9.dll" file in the folder the FIRST time you launch the game or after a patch update. To resolve this, rename "d3d9.dll" into something else, then launch the game, close the game after, then rename the dll file back to "d3d9.dll". Then to launch the game make sure you run "Diablo III.exe"? and NOT the beta launcher (which also happens to be the link in your desktop).
Instructions:
1. Visit http://darkd3.com select and preview the effect you wish to download.
2. Extract the contents of the downloaded zip into the root directory of your Diablo 3 install.
3. Start the game and turn off/on the effect using the Pause key on your keyboard.
E ***, na brzinu pogledah vest I prevideh glavnu stvar, da je u pitanju patch nakon final launcha :/ ....
Bonus beta content o kom se juce pricalo da je neko otkrio bug u beti i prosao malo dalje je danas potvrdjen. Moze biti spoiler za one koji ne zele da idu unofficial putem 🙂
http://diablo.incgamers.com/blog/comments/bonus-beta-areas-confirmed
