Vlajo
uff bre NIkola ,evo ti 😉
obrisi ovo .txt ... da ostane ovako Rageconfig.cfg
Radi kao lutka. Hvala !!!
Probajte ispratiti ovo uputstvo koje sam nasao na jednom forumu jer je meni uspelo da pokrenem igru
posle niza bezuspesnih pokusaja.Jeste da je primetno ucitavanje textura u daljini,ali se brzo ucita
tako da meni ne smeta.
1. start > control panel > device manager > display adapters...desni klik na graficku,odabrati uninstall
i cekirati box "Delete the driver software for the device" .nakon zavrsetka NIKAKO NE RESTARTOVATI RACUNAR!!!
2. start > control panel > programs and features....deinstalirati ATI ili AMD catalyst drajvere koji postoje u racunaru
i kada vas install wizard pita odaberite "Express uninstall all ATI software".Posle zavrsetka NIKAKO NE RESTARTOVATI RACUNAR!!!
3. Na C particiji pronadjite svaki folder sa nazivom ATI i obrisite ga.I u C:\Program Files\ nadjite ATI folder i obrisite ga
SADA RESTARTUJTE RACUNAR
4. Skinite drajvere za graficku verziju 11.6
Ako imate windows 7 64bit skinite drajver sa ove adrese http://support.amd.com/us/gpudownload/windows/previous/Pages/radeonaiw_vista64.aspx
a sa ove za windows 7 32bit http://support.amd.com/us/gpudownload/windows/previous/Pages/radeonaiw_vista32.aspx
Instalirajte drajvere i igru
5. Desni klik na precicu Rage i odaberite properties,zatim u Target text box dodajte ovu liniju posle Rage.exe
+cvaradd g_fov 12 +com_allowconsole 1 +com_skipIntroVideo 1 +image_anisotropy 4 +image_usecompression 0 +g_showplayershadow 1 +m_smooth 0
(mora biti razmak posle Rage.exe)
potvrditi na apply
6.Otvorite notepad i u njega iskopirajte ovaj text
// Video
seta com_videoRam "1024" //sets the Video Card memory Set this to the amount you have in MB
seta com_maxfps "20" //limits the frames to 60 can be changed to what you desire
seta image_anisotropy "2" //Using the highest setting here but you can set as 2, 4 or 8
seta image_usecompression 0
seta image_filter "GL_LINEAR_MIPMAP_LINEAR" //filtering for light maps
seta image_preload "1" //Use preload images when ever possible
seta image_lodbias "-1" //LoD settings
seta image_ignoreHighQuality "1" //Sets up for using HQ gfx
seta image_ignoreLowQuality "0" //ignores the low textures
seta image_useCache "1" //Enabled Cache to allow the textures to load properly without popping
seta image_cacheMegs "250" //Cache size in Megabytes
seta image_cacheMinK "1024" //Cache minimum size in kilobytes
seta r_swapInterval 0 //VSYNC 1 enabled, 0 diabled
seta r_useHighQualityPostProcess "0" //Fore High Quality post proccessing
seta r_shadowsHighQuality "0" //Fore High Quality shadows
seta r_displayRefresh "0" //keep it so the engine doesn't double render a frame
seta r_renderer "low" //highest rendering options
seta r_multiSamples "8" //Set this to 16 or 8 if you're having low-fps as 32 is the Max Multi-sampling
seta r_useHBAO "1" //Ambient occlusion
seta r_useRenderThread "1" // 0 Disable or 1 Enable threaded rendering useful for newer cards to increase performance.
seta r_visDistMult "1"
seta r_useMotionBlur "0" //use blur
seta r_skipBump "0"
seta r_skipSpecular "0"
seta r_skipNewAmbient "0"
seta r_shadows "0"
seta r_cgFragmentProfile "best"
seta r_cgVertexProfile "best"
seta vt_lodBias "-1" //LoD settings
//below is cache settings
seta vt_pageimagesizeuniquediffuseonly2 "4096"
seta vt_pageimagesizeuniquediffuseonly "4096"
seta vt_pageimagesizeunique "4096"
seta vt_pageimagesizevmtr "4096"
seta fc_maxcachememoryMB "1024"
seta vt_maxPPF "8"
seta com_allowConsole "1"
seta com_skipIntroVideo "1"
seta cg_usecompression "0"
seta cg_useprecompressedtextures "0"
snimite ovaj dokument kao Rageconfig.cfg u folder "base" gde ste instalirali igru(npr. C\Program Files\Rage\base)
7. Idite u C:\Users\Korisnickoime\AppData\Local i napravite novi folder pod imenom "id software"(bez navodnika),a u njemu napravite folder pod imenom "rage"(isto bez navodnika).
To je to.Restartujte racunar i trebalo bi sve da radi.
Probao sam mnogo Rageconfig.fcg fajlova,razne stvari ali nista nije uspelo dok nisam uradio ovo ,
Srecno i pozdrav svima.
Ajde pisemo peticiju protiv konzolaskih igara :dMene je vec brdo naslova smoriloo zbog konzolacije pc igara.....*** jos malo pa shift+delete
potvrditi na apply
// Video
seta r_skipBump "0"
seta r_shadows "0"
seta vt_maxPPF "8"
:d jel se ti salis samnom 😀
sa ovim config-om ce igra raditi vise nego ocajno...ko sto ce tako i izgledati 🙂
ahh bilo kako bilo ... zastane meni tu i tako ... opadne frame na 45 ... al bas me briga... to je sve na otvorenom ... u zatvorenom radi na 60 fps-a i to mi je vazno sa obzirom da su sve misije u nekom zatvorenom prostoru... sem u dead city-u doduse i tamo radi ok 🙂
EDIT: ajde bas cu da probam da i ja vidim bar ovaj config fajl koliko je pogresan
EDIT 2 : moram priznati sa ovim configom radi kao zmaj....
Takodje moram priznati da sa ovim configom mogu da igraju samo slepci :d posto se teksture ocitavaju tako brzo ... da imate vremena da pretrcite celu tablu(misiju) dok se one ne ocitaju XD ) e sada za te drivere i sve to ne znam ... bilo bi lepo kada bi mogao postaviti neki kratak video da mi vidimo kako to radi.
seta com_maxfps "60" //limits the frames to 60 can be changed to what you desire
vt_pageimagesizeuniquediffuseonly2 8192
vt_pageimagesizeuniquediffuseonly 8192
vt_pageimagesizeunique 8192
vt_pageimagesizevmtr 8192
vt_restart
vt_maxaniso 4
image_anisotropy 4
Kako "ubiti" screen tearing u igri?
