'DoG
Meni je ovaj fix sredio problem sa ucitavanjem textura:
Fix for the texture problems.
1.Create a Rage shortcut with the following launch parameters:
+cvaradd g_fov 12 +com_allowconsole 1 +com_skipIntroVideo 1 +image_anisotropy 16 +image_usecompression 0 +g_showplayershadow 1 +m_smooth 0
2.Create a file called rageconfig.cfg in Rage/base/ and put the following commands in there:
seta image_usecompression "0"
seta image_anisotropy "16"
seta vt_pageimagesizeuniquediffuseonly2 "8192"
seta vt_pageimagesizeuniquediffuseonly "8192"
seta vt_pageimagesizeunique "8192"
seta vt_pageimagesizevmtr "8192"
seta vt_maxppf "24"
seta vt_maxlockedpages "256"
seta vt_minlod "-2"
seta vt_lodBias "-2"
seta vt_maxaniso "2"
seta vt_qualityhdplossless "1"
seta vt_qualityhdppower "0"
seta vt_qualityhdpspecular "0"
seta vt_qualityhdpnormal "0"
seta vt_qualityhdpdiffuse "0"
seta vt_qualitydctpower "100"
seta vt_qualitydctspecular "100"
seta vt_qualitydctnormal "100"
seta vt_qualitydctchroma "100"
seta vt_qualitydctluma "100"
seta vt_restart
3. Go to C:\Users\UserName\AppData\Local\ and create a folder called "id software" (without "). Then create a folder called "rage" (without ") inside that folder.
4. Run game and play.
