Nuclear meltdown - Fukushima Daiichi
Mnogi pa čak i u Srbiji pokušavaju da naprave taj auto na vodu. I ne kontaju da bi to u stvari bio perpetumobil.
A aparati za varenje "na vodu" mogu da se kupe. Bilo po buvljacima ruskih modela. Rade lepo ali ipak, sasvim normalno, troše više energije nego što daju.
Što se tiče priče o nuklearnim katastrofama, možda nekome može biti zanimljivo da čuje ovo: http://www.astronomija.co.rs/predavanja/4305-nuklearna-tehnologija-i-incidenti.html Meni je daleko da dolazim. :(
TEPCO to cover No.1 reactor building
Tokyo Electric Power Company has started preparations to cover the damaged Number 1 reactor building at the Fukushima Daiichi plant. The company aims to decrease the amount of nuclear materials leaking into the air.
TEPCO has been working to reduce the leakage of those substances while cooling down the reactors.
It has been clearing contaminated rubble and spraying a chemical hardening agent to prevent the spread of radioactive dust.
TEPCO is going to cover the Number 1 reactor building, which lost its roof in a hydrogen explosion in March. On Friday, workers cleared rubble so that a big crane can be set up near the building.
TEPCO says a polyester sheet will be attached to steel frames, enclosing the 50-meter-tall building. The company says the cover can withstand strong winds. TEPCO also says it will install a ventilator with a filter to capture radioactive materials that would otherwise be concentrated inside.
To minimize radiation exposure among its workers, the company says the steel frames will be pre-assembled as much as possible, shortening the set up time at the plant.
Saturday, May 14, 2011 06:01 +0900 (JST)
LINK
[B je napisao(la):
NShappy;2557280]Mnogi pa čak i u Srbiji pokušavaju da naprave taj auto na vodu. I ne kontaju da bi to u stvari bio perpetumobil.
E = E
Voda je energija.
^^ :trust: ?
„ATOMSKO JEZGRO, NUKLEARNA TEHNOLOGIJA, INCIDENTI (ČERNOBIL, FUKUŠIMA) – I DEO”
(subota, 14. maj 2011, 20:15)
Ovo je bilo danas, sad sam video. :( Da li je neko bio? Verujem da je bila opasna gužva jer je Noć muzeja, a Planetarijum je bio do sada bio u ponudi Noći muzeja, ne znam ove godine. Jedne sam čekao preko 1h da uđem. Idem sledeće subote. ;)
Jedan radnik je poginuo kad se srusilo nesto na njega..
14. 05. 2011. 08:21h | Vestionline
Japan: Još jedan potres, umro radnik u Fukušimi
Komentara 0 | veličina teksta:+-
Zemljotres jačine 6,2 stepena po Rihterovoj skali pogodio je danas severoistočnu obalu Japana, a zasad nema izveštaja o eventualnim žrtvama ili šteti.
Još nema izveštaja o eventualnim žrtvama
Epicentar potresa bio je na dubini od 38 kilometara, 59 kilometara severoistočno od Ivakija, grada na obali Tihog okeana, navedeno je na internet sajtu Američkog geološkog instituta.
Vlasti nisu izdale upozorenje na opasnost od cunamija, javio je AFP. Severoistočni deo Japana razoren je 11. marta u snažnom zemljotresu, jačine devet stepeni, koji je izazvao cunami i u kojem je izgubilo život ili nestalo 24.525 ljudi.
Nuklearna elektrana Hamaoka, smeštena u trusnom području 200 kilometara jugozapadno od Tokija, danas je zatvorila sve reaktore na neodređeno vreme kako bi sprečila eventualni nuklearni incident, saopštila je kompanija" Čubu elektrik pauer", koja upravlja tom elektranom.
Japanski premijer Naoto Kan zatražio je prethodno da pogon bude zatvoren, osam nedelja pošto su zemljotres i cunami oštetili elektranu Fukušima Daiči, severozapadno od Tokija, i izazvali širenje radijacije.
Hamaoka je ranije zatvorila tri reaktora, a danas i preostala dva, izgrađena 1970-ih godina. Lokalni mediji navode da će pogon biti zatvoren naredne dve godine.
U međuvremenu, jedan stariji radnik elektrane Fukušima Daiči srušio se danas u objektu za odlaganje otpada i preminuo.
Naojuki Macumoto, portparol Tokijske elektroenergetske kompanije (TEPCO) koja upravlja Fukušimom, rekao je da je radnik, u zaštitnom odelu i s maskom, prenosio opremu u trenutku kada mu je pozlilo, ali da uzrok smrti još nije poznat.
Prema Macumotovim rečima, nivo radijacije u telu preminulog nije bilo dovoljno visok da bi to moglo da mu ugrozi zdravlje.
U objektu u kojem se dogodio incident uskladištena je voda kontaminirana radijacijom, koja je iscurila iz reaktora, naveo je Asošijejted pres.
info sa - http://www.vesti-online.com/Vesti/Svet/137070/Japan-Jos-jedan-potres-umro-radnik-u-Fukusimi
E = MC2
Chernobilj katastrofa, za narod - By igoritza. :)
ako se nadovezemo na ovu pricu gore, ako je procitate, lako moze da se pohvata sta se desilo u Chernobilju.
postojala je bojazan da ako prsne spoljni izvor struje, koji je u fukushimi takodje prsao, da ce da se nabije toplota, dok se dizel generatori pokrenu. njima je u tom trenutku u Chernobilju bilo potrebno da se zahuktaju dobrih 75 sekundi, dok krenu da proizvode 5.5MW potrebnih za normalan rad sistema za hladjenje.
neki genije je smislio da se iskoristi mehanicki momentum zaletele turbine, i postojeci pritisak reaktora, ne bi li proizveo jos malo struje u procesu. to je bilo dovoljno za 45 sekundi punog rada sistema za hladjenje, sto ostavlja 30ak sekundi tolreantnog gubitka snage.
sve sto je ostalo je, da se izvede ekperiment i da se vidi dal je tako nesto moguce (go russians, sa eksperimentima u slucaju propasti, koji ce da najverovatnije izazovu propast )
test je izveden zapravo, pre toga - 82', 83', i 85' godine. i svaki put se pokazalo da nije dovoljno struje u slucaju main power grid failure-a.
Kako u komunizmu svaki ovakav eksperiment mora da prodje info biro, precednika, cetiri sluzbe i 7 shaltera, i na kraju KGB, direktor chernobilja nije hteo da se zamlacuje sa procesom, te je odlucio da sam testira svoju elektranu. termalni output reaktora je u prva tri neuspela eksperimetna bio propisan na NIKAKO manje od 700MW, da bi turbina imala odredjeno magnetno polje, odnosno snagu da proizvede potrebni efekat premoscavanja 75 sekundi procesa.
reaktor je u trenutku pre nesrece radio na 1600MW, polovine od svog maksimuma, onda je, nesto slicno kao i u srbiji samo sa mnogo vecim posledicama u nizu - crkao neki terminal, tamo negde u okolini. dezurni kontroler elektricne mreze je zahtevao da se odlozi eksperiment, te je naredio pauzu. koja se posle ispostavila kljuchna za katastrofu. naime - test je trebao da se obavi u dnevnoj smeni, a da nocna preuzme samo regulisanje "preostale toplote" (referenca iz gornjeg teksta, fisioni materijali koji se stabilizuju)
i onda je u smenu dosao genije - Leonid Toptunov - covek koji je samo tri meseca bio aktivan na poslu, i u prevodu - nije imao pojma sta radi. on je inace bio zaduzen za kontrolne shipke od Bor-a, koje sprecavaju neutrone da prave lancanu reakciju.
isti taj Toptunov je greshkom ugurao Kontrolne shipke previshe, izazivajuci kopletno gasjenje reaktora. snaga reaktora je tada pala na samo 30MW, sto je manje i od 5 procenata za obavljanje eksperimenta. zajednickim snagama, genijalci su pokusali da ignorisu greshku Toptunova, i odlucili da podignu kontrolne shipke, da bi podigli snagu reaktora. long story short - pokushali su po svaku cenu da izvedu eksperiment, gde su prikacili dodatne pumpe vode (koja takodje ima osobinu gutanja neutrona) i dostigli vrednost od oko 200MW, ali posto voda guta nukleone takodje, da bi podigli snagu reaktora - morali su jos vise da podignu shipke, skoro ih totalno iskljuchujuci iz reaktora, te je preostala samo lancana reakcija prirodnim putem.
gornja vrednost reaktora je bila niska, a kontrolne shipke skroz podignute, te je reaktor bukvalno pretvoren u kljuchalu chorbu nevolja koja mora da eksplodira.
naravno, niko pametan nije bio u tom trenutku u nuklearki, te su oni sasvim normalno nastavili sa eksperimentom. pokrenuli su eksperiment sa samo 200MW - zaboravljajuci totalno da dok se smanjuje momentum turbine, smanjuje se i snaga vode, koja nije pod pritiskom u propisanim granicama - tako se stvarala para, odnosno - penushava voda, koja je totalno izgubila mogucnost da guta neutrone, i to je reuzltovalo u jos vecem povecanju snage reaktora, koja je bila neocekivana.
dan danas se ne zna zasto - neko je pritiso dugme za gashenje reaktora. to znaci zapravo jedino sto covek i moze da uradi - da ubode kontrolne shipke do kraja i zaustavi reaktor kompletno. ali, posto kontrolne shipke idu sporo, a napravljena je chorba od reaktora, te je spustanje shipki Bora izazvalo jos brzu reakciju u donjem delu jezgra koje je bilo tih par sekundi nebranjeno. **** ovde treba objashnjenje zasto se to desilo **** Vgagi, nastupi :)
tako brzo bombarodvanje nesticenog nuklearnog goriva je izazvalo nenormalno brzo povecanje snage reaktora koji je tada dostigao za samo 3 seknde - 550MW. to je zapravo izazvalo eksploziju materijala samog reaktora, te su prsli i fuel rods-ovi. nakon toga, nabio se i pritisak, te je i on izazvao eksploziju. poslednje merenje na displeju je pokazivalo 33GW, 10 puta vise nego maksimalna vrednost reaktora.
nakon toga je nasledila i eksplozija izazvana "nuklearnom ekskurzijom" - 3 sekunde nakon eksplozije pare, eksplodiralo je i gorivo. treba znati da gorivo u nuklearki NE MOZE da eksplodira kao fisiona bomba, vec se odredjena kolicina energije "bori" sa prostorom, i dobiva bitku.
do tada je vec nastpila vatra, koja je krenula da baca zrake smrti, odnosno fisione ostatke svuda naokolo.
i shlag na tortu - neki car je, pre svih ovih legendarnih ucesnika u dogadjaju prvi hteo da pokaze svoje umetnichke sposobnosti, te je stavio Bitumen u konstrukciju krova nuklearke. bitumen koji se pali ko barut. takodje propisan da se NE stavlja u zidove elektrane. to je izazvalo opstu katastrofu i dalje znate. dalje su ruski vatrogasci dobili informaciju da gase pozar izazvan elektrichnim instalacijama, i da slobodno udju u reaktor ... :(
Ovo je tek jedan dio price, i to prilicno netacan :)
Toptunov nije krivac za to sto se desilo, vec osoba pod imenom Anatolij Djatlov; top nuklearni inzinjer tadasnje drzave:
[YOUTUBE]uoEgkGNO-sQ[/YOUTUBE]
Malo da oživimo temu, pošto situacija nije bolja...
Japan should have made core meltdown public – Russian minister
The Japanese company that runs the Fukushima nuclear plant admitted three of six reactors damaged by the tsunami actually suffered meltdown within days, a shocking revelation that's left many wondering why the information was not made public sooner.
Još se sećam da mi je neko rekao da bezveze mračimo ceo događaj, crnjak je da je ovo mnogo gore nego što sam zamišljao u tom momentu:(
To je bilo jasno svega nekoliko dana posle incidenta.
Meni su interesantnije 'posledice' incidenta u Fukushimi na energetsku politiku.
Pre neki dan je US Department of Energy podrzao garancijama na pozajmicu gradnju prve americke baseload solarne centrale u Nevadi od 110 MW. Gradnja treba da pocne sredinom ove godine i da se zavrsi do pocetka 2013, i kostace izmedju 650 i 750 miliona $.
Centrala ce biti cirkularno polje velicine 2 kv. milje od 17000 heliostata, koji ce usmeravati solarnu radijaciju na vrh tornja visine 538 ft, gde ce koncentrisana toplota zagrevati istopljenu so do temperature od 1050 °F, koja ce potom da se vodi do parnih turbina, i konacno u skladiste pri temeraturi od 525 °F za upotrebu kada nema sunca.
Ovo je prva centrala ove vrste u US, 20 godina posle demonstracionog postrojenja Solar Two od 10 MW kod Barstow, Calif.
I druga vest, mozda jos znacajnija. Nedavno je u izvesnim poslovnim novinama skrenuta paznja na firmu General Fusion, koja se vec nekoliko godina bavi projektom razvoja tzv “magnetized target fusion”, koncepta koji je razvijen jos pre 30 godina. General Fusion tvrdi da ce energetski net gain postici u roku od 4-5 godina, i da ce komercijalnu fuzionu energiju imati u roku od 10 godina.
Heh, kako to sada bezazleno zvuci, da, da, otopoila su nam se potpuno 4 jezgra, trebali smo to odmah reci. Pre mesec dana se dramilo, mora se spreciti topljenje jezgra. ovo ono. A sad onako mrtvi ladni, ebi ga, desilo se, nikom nista, mediji vise i ne prenose.
Ko zna koliko je jos nuklearnih havarija zataskano potpuno. Da li ste znali da se jedna od najozbiljnijih havarija do sada desila u svajcarskoj u planinama pre cetrdesetak godina. Doslo je do potpunog topljenja jezgra nekog eksperimentalnog reaktora, brze bolje su potpuno zatrpali i ostavili tu "pecinu" gde se reaktor nalazio, tako da nije bilo (ili se bar ne zna) nekih ozbiljnijih posledica po okolinu. Cudno mi je sto oovome nije bas lako naci nesto na internetu.
Naravno, ali mnogo ljudi nije htelo da veruje, čak ni ja, nekim delom. Mada sam nekako kontao da je mnogo loše, podsećalo je na černobil nekako, ali zbog drugačijeg tipa reaktora, nije bilo onako velike eksplozije.
Eh, da, koliko smo se zamarali onim tabelama, pratili stanje postrojenja iz dana u dan, a stvar je praktično bila već gotova... :(
@VGagi
Primećujem da si izuzetno dobro upućen u celu ovu energetsku problematiku. Da li ti je ovo samo interesovanje ili profesija? :)
Rekao sam jos prvih dana da treba da zatrpavaju. Po fotografijama je bilo jasno da nema mogucnosti za popravak.
Nisu zatrpali, bilo im lakse da speru sve u more :wall:, ispadose rusi vece "kamikaze" sa sanacijom cernobilja.
Eksperimentalni reaktor u Lucens-u. Bio je mali, proizvodio je samo 30 MW toplotne / 8.3 MW elektricne energije. 1969 se desilo delimicno topljenja jezgra, a cinjenica da je reaktor bio mali i da se nalazio u podzemnoj pecini je omogucilo potpunu lokalizaciju incidenta.
http://www.nucleartourist.com/events/part-melt.htm
http://www.servinghistory.com/topics/Lucens_reactor
Cold War... Ogranicena sredstva informisanja...
@ marko_n
Interesovanje.
Tokio: Požar u nuklearki Fukušima 2
Tanjug | 27. maj 2011. 08:43 |
TOKIO - U jednoj zgradi japanske nuklearne elektrane Fukušima 2., operatera "TEPCO", danas je izbio požar. Požar je, kako je saopšteno, brzo ugašen, i ne očekuje se curenje radioaktivnosti.
Fukušima 2. se nalazi na oko 12 kilometara južno od havarisane nuklearne elektrane Fukušima 1. objasnio je portparol "TEPCO" Takeo Ivamoto.
Uzrok požara se trenutno istražuje, a povređenih nije bilo.
U razarajućem zemljotresu i cunamiju 11. marta teško je oštećena nuklearna elektrana Fukušima 1., u kojem je u tri reaktora, koja su bila u to vreme u funkciji, došlo do topljenja nuklearnog jezgra, i curenja radioaktvnih čestica i vode.
Lep pogled na kanjon odavde:(
Jel zna neko kako je sa stanjem radijacije u okeanima i morima? Vreme je odmora, pa da se spremimo na vreme.
Ako ne ides u japan da plivas nemas nista da se brines.
a da li nema ? ne, ne izazivam ja sad opstu paranoju, jednostavno smo dosli u situaciju da smo postali svesni da nas velike kompanije lazu, i da ne mozemo da uradimo nista protiv toga. sobzirom da je zapravo zaista doshlo do kompletnog topljenja jezgra, pitaj boga kolike kolicine cezijuma, stroncijuma i argona su oslobodjene. i znajuci da je od ta tri elementa half life minimum 29 godina, mene zivo zanima ko i na koji nacin moze da kaze da je negde u svetu sigurno, jer se ne zna kolicina oslobodjene materije, koja jako lako moze da se rasprshi po celom svetu.
Poneses gajgerov brojac na more, pa pre nego sto udjes u vodu proveris situaciju. Mogao bi cak i da naplacujes test na drugiom delovima plaze.
Ili raslje...
Sansa da bilo koji od teskih elemenata dospe morem do nama dostupnih/zanimljivih mora (celo Sredozemlje, Spanija, Francuska, Italija, Grcka, Turska) je toliko prokleto mala da bez problema pristajem na nju. Svakodnevno pristajemo na daleko vece rizike od tog (da nam recimo padne klima na glavu).
Nadajmo se da ste u pravu, mada meni više ova planeta ne izgleda isto, niti će skoro pored ovakvih s*anja. Sad možemo da se pravimo blesavi, ali na jednoj od onih animacija gde se vidi širenje svih radio-aktivnih elemenata, ono je baš doprlo do skoro svih mesta na planeti, bilo vazduhom ili vodom, nadajmo se da je to razvodnjeno u okeanu, ali mislim da niko nema pojma koliko će to da utiče na nas i na ostala živa bića.
Kad vidim da mi je skuša u frizu iz okeana blizu Japana, smorim se...jedina stvar koja je dobra što je upecana pre ovog svega, ako je datum ispravan.
Moram da vas zračim, mada je možda bolje praviti se da je sve ok:)
