Mortal Kombat [reboot]
Pojasni ovo molim te, za ovo nisam nikad čuo :)
Nikada nisi video decu kako igraju olimpijadu u igraonici?
Poloze joypad, stave upaljac preko 4 buttona i njakaju ga levo-desno.
Tako se bez problema ruse svetski rekordi :).
Doduse, ja sam koristio mobilni ... tehnoloski napredak je nezaustavljiv.
Hahaha, koliko dojajna fora, ne mogu da verujem :d Moram probati kad stignem do tog "test your might" :D
Jel neko uzeo My Kung Fu is Stronger ? Cini mi se kao prilicno ludacki trofej... :)
Evo saveta :) :
For Victories and Fatalities, go to options and set it to 1 round. Plug in a second controller and play 2 player versus. At the loading screen input the following kombat kode 044-440 for sans power. With 1 punch it goes to FINISH HIM, making the 100 victories and finishers go by way fast. The biggest pain is having to input the code every match. Find the easiest fatality/stage fate/babality to do to make life simpler.
For X-Rays, go to options and set the rounds to 3. Again play 2 player versus. At the loading screen input the following kombat kode 466-466 for unlimited super meter. This allows you to get 4 X-Rays per round, 12 per match. You'll have 150 in less than an hour. Again having to input the code every match is a pain, but that's why you do 3 rounds instead of 2, so you have to do it less often.
For the 24 hours of play time, go to practice -> tag team practice. Choose 2 characters and leave your console on while you go to sleep/work/out. *Be sure your controller is wired or is connected via a charging device. If the controller turns off, practice mode will go to the pause menu and not count the time.
The 10,000 pints of blood spilled will be acquired as you work toward mastering the other statistical aspects.
To ce dosta ubrzati, ali acunaj da to moras da uradis sa SVIM borcima... Moras mesec dana da odvojis samo za to :)
Predobra igra i story mod, namucio me Shao Khan na kraju strasno, jedno 4,5h mi je trebalo da prebijem.
Jedan od najtezih bossova koje sam ikad igrao.
Konacno pravi MK ! :)
^ Na kom si nivou igrao kad ti je trebalo 4h da ga prebijes? Meni je na Medium trebalo jedno 10ak pokusaja... Cim je poceo da ***** onda je bilo lagano... Do tada je bio prilicno nemoguc :) Nazalost, takav je i u svim susretima... Samo treba da bezis od njega i sklanjas se... Ne mozes lepo da uletis u borbu i da se mlatite... :(
Mislim da osvajam bez problema :D.
The official PlayStation Fan account on Facebook have announced that PS3 gamers will be able to play Mortal Kombat online, without using an online pass, until the PS Store is live again.
Before the PSN outage players would have needed a ‘Kombat Pass’ (which was included with new copies of the game) to play the title online, but PS Store downtime has prevented fans from entering the code. This is only a temporary solution though and when the PlayStation Store is back up users will need to enter their code or buy a Kombat Pass $9.99 to continue playing online.
Od sinoć se igra bez koda samo uđeš online i ne traži ništa biće tako dok se ne vrati PSN.
U koliko sati pocinje? Taman da dodjem da malo navijam (ako se setim)... BTW sto se tice online nije onako strasan lag kao sto se prica... Ima meceva gde ne mozes da igras, ali uglavnom je ok... Doduse bas su retki oni u kojima nema uopste laga...
Trebalo bi da je u 12.
Online je los(u nekim trenucima i katastrofalan, lag se primeti cak dok biras i lika), sem ako igras sa ljudima koji nisu daleko.
