Jel ima neko link za psas free verziju. Treba mi za goldcard. Ili jel zna neko da mi preporuci servis koji ce mi to provereno i brzo odraditi. (Fon zaglavljen u butloaderu)
Hvala.
Ako je zabranjeno ovako, moze pm.
probaj ovako:
B.O.2. Option 2: PSAS free Version:
..O.2.1. Download an install the PSAS Free Version: http://revskills.de/downloads/psas.zip
..O.2.2. Start PSAS (needs administrator rights)
..O.2.3. Goto "Hardware Forensics" - "WINCE SD Card Utils"
..O.2.4. Click on "Get Serial and Disk ID".
..O.2.5. Choose the right SD Card (note the size)
..O.2.6. Copy the displayed CID (i.E. 9E000000400000000000020002000000)
..O.2.7. Send the CID to a friend owning the full version to prepare your image
..O.2.8. If you don’t know one, send a PM to either "lyriquidperfection", "oliverweidel", "mskip", "sirsmiles" or me ("pcwe")
..O.2.9. Once you have your image, click on “Write Image File”
..O.2.10. Select the image you received (Goldcard.img)
..O.2.11. Now your Goldcard is ready
probaj ovako:
:smack::zgran:
Koji rom je u pitanju?
:smack:
Imam instaliran Leo "Stock" NAND Android ROM. I sa njim imam jos jedan problem. Cesto kada me neko zove imam veoma slab zvuk u slusalici. I to ne znam kako da resim. Hvala!
Moze preporuka za WP7 rom?
Na HD2 je trenutno Android 2.3 u NAND HyperDroid GBX v8.0.
Pozeljan je DualBoot. Leo je sa 512MB, microSD 2GB.
Hvala
imam problem sa UltimateDroidom, kada slusam muziku preko slusalica probijaju mi i prejako se cuje, kako to da resim.
Treba mi telenor logo da bi telefon odneo u servis jer mi ekarn nekada posle zakljucavanja ne reaguje!
Radio sam Task29, ubacivao android Hyperdroid na nand, Win energy...
Radice ti sa tom karticom, samo cepaj!Hvala.
Zanima me WP7, hocu makar da probam, zato sam i uzeo ovaj HD2. Naci cu vecu karticu pa cu probati.
Hvala
