GeForce 104, 106 & 108
  • Začetnik teme Začetnik teme dz0ni
ma bitno je da je GTX460 brz kao 5850 :d ti forceware-i su cudo!
GF110 stize kao konkurencija 5970(da ne bude zabune nijedna nije dualka)
http://www.tcmagazine.com/tcm/news/...-say-nvidia-prepping-512-core-geforce-gtx-580
Nvidia was un-fashionably late to the DirectX 11 party but now that AMD is just about ready to release its second-generation DX11 graphics cards, word around Rumorville is that the greens are cooking up something to counter the Radeon HD 6900 series.
The Nvidia flagship rumored for a December release is the GeForce GTX 580 and it is supposed to be powered by a new 40nm GPU (GF110) packing 512 CUDA Cores and some 128 texture units (the GTX 480 has 60 TMUs). The alleged card would also have a 512-bit memory interface, 2GB of GDDR5 memory, a TDP close to that of the GTX 480, two (6-pin + 8-pin) PCIe power connectors and one mini HDMI, plus two DVI outputs. Hmm, hot and salty...
Mozda se i obistini ono sto je Jen pricao na GTC-u, a verovatno hoce, da ce imati unapredjenog fermija krajem ove godine, pocetkom sledece.
http://www.fudzilla.com/graphics/item/20312-fermi-mid-life-kicker-comes-in-40nm
Veoma moguc scenario jer bi takva kartica u gamingu pruzala 50% vise od GF100... ostaje pitanje yeald-a koji predstoji i pred ATI-em kad izbaci 69xx seriju koja ce verovatno biti priblizne velicine kao i GF110 a verovatno i potrosnje
Dok god ima ljudi kao sto je Zeljko, ovakve glasine mogu da se shire!
Jedino sto je tacno i sto je potvrdjeno, jeste da ce NVIIDIA sledece godine imati novi GPU!
Fermi je monstruozno velik i na granici dimenzija koje moze da podrzi litografska oprema! Nekakav GF110 koji bi mogao da bude brzi od GF100 bi MORAO biti jos veci, a to jednostavno fizicki nije izvodljivo!
Sto se tice ovog FUD-ovanja o dimenzijama Caymana i povlacenje paralele sa tim fantomskim GF110 jeste nista drugo do jos jedan sjajan "quatabilni" biser zbog kog svi na forumu vole Zeljka! 🙂
Nedjo za tebe je Fermi monstruozno velik a ATI 69xx koji ce biti tek nesto malo manji je prava stvar predpostavljam, cak ce verovatno jaca verzija imat i isti broj power konektora ali tebi to nista ne znaci to je ATI 🙂
Ove glasine ja ni nisam predstavio kao vest vec bas kao moguc scenaio tako da nemoj da dizes galamu, jer NV treba odgovor na 69xx definitivno ako ne decembra onda bar januara/feb.... a ja sam 101% siguran da NV ne sedi skrstenih ruku
Eh, Zeljko, Zeljko, pa ne prolazi vise ovakav FUD i zamena teza 😉
heheh... pa nisam ja ni rekao da si ti tu glasinu predstavio kao vest! Predstavio sam tebe kao propagatora glasina u koje propagatori zele da veruju i pri tome osecaju potrebu da zapljunu i jedan FUD na konto proizvoda o kome nista ne znaju sem da dolazi iz suprotnog tabora! 😉
Da li ti je i jednom palo na pamet da bi za potrebe ubrzanja od 50% (ej 50%! :sceptic🙂, taj GF110 morao da bude OGROMAN i daleko preko 530 mm^2 koliko ima Fermi?? A pri tome znamo da je fizicka granica masina za proizvodnju cipova ~580 mm^2 (hvala DAS-u na ispravci u onom drugom thredu! 😉 )
I na osnovu koje konstalacije zvezda si dosao do zakljucka da ce Caymans imati takvu povrsinu???
Čekaj, ako Nvidia menja arhitekturu upravo zbog veličine, zašto upravo to potenciraš?
Ove glasine znače i nešto mnogo bolje: možda ATI stvarno ima ispred sebe dobru seriju GPU-a. Prvi kupujem ako srede GSOD probleme i ispeglaju drivere napokon.
Jednostavno sudeci po dobitku GF104 u igrama u odnosu na gf100 i predpostavci da su jos uspeli da optimizuju chip i ako bi stvarno TMU broj jedinica duplirali realno je ocekivat bar 50% bolje performanse...
Caymans zakljucujem da ce biti priblizno velik ko GF100 na osnovu uvecanja 6870 u odnosu na 5770 i to da zagovaraju dosta bolje performanse sto je moguce vecim jezgrom jedino jer optimizacija/redizajn ipak ne moze doneti toliki napredak
ako, ako i ako... a kako to sve da odrade u periodu od 5-6 meseci?
pa 'ajd neka je po tvojoj matematici: za 5770 znamo da je 166 mm^2! Za 6870 kazu da je 230 mm^2! TO je uvecanje od ~40%
'ajd sad ti meni daj matematiku kako si dosao do ~530+ mm^2?!
1. A kako su dobili "dosta" sa gf104 za ~6 meseci tako ce i za dodatnih 6 dobiti slicno
2. 5870 je 334mm + 40% = 467mm sto je po meni priblizno fermiju 🙂
Jedini moguc scenario za novi Fermi chip u 40nm po meni je 12 SM sa po 48CC-a = 576, uz 256-bit magistralu. Taj chip bi imao 50% vise jedinica od GF104 a istu magistralu, znaci mogao bi da bude i nesto manji od GF100, negde oko 500mm2.
E sad, 50% vise performanse je nerealno ocekivati, ali 20-25% u odnosu na GTX 480 bi se moglo ocekivati.
Naravno sve ovo pod predpostavkom da je dizajniranje tog chipa pocelo negde kad i GF104, i da mogu da ga stancuju u full-u 🙂
I plus sredjivanje ddr5 kontrolera, da li je moguce da ostvare toliki bandwith sa 256bit-a za toliko brz cip? jedino da se koristi ona ddr5 sto radi efektivno na 6000Mhz.
Pa da, i to, definitivno bi morali da srede kontroler da izdrzi mnogo vece frekvencije - barem 5Ghz.
Ako i Cayman poraste proporcionalno u odnosu na Cypress koliko i Barts u odnosu na Juniper, imace vise od 2500 SP (u tih 40% je izgleda 60% vise SP i duplo sira memorijska magistrala, a u slucaju Caymana bi uvecanje otislo samo na SP). NV u tom slucaju nije dovoljno "samo" 576 😉. Naravno, ne mislim da je to realno, Cayman ce tesko preci 1920SP (480x4), a NV ce gurati GF104 384CC i dual kartu protiv njega.
GF100 je imao ledja u obliku Quadro i Tesla karti koje ce na kraju verovatno i doneti zaradu, ali razvijati toliki cip (576CC) iskljucivo za gejming trziste nema nikakve logike... sem da mogu da kazu da imaju najveci 😉
NVIDIA preparing GTX580 to swing punches with the 6970?
I just love GPU wars - I seriously do. We all win because of it, each team will try to bring something out to smash the other and because of the runaway success of the 4k and 5k Radeon GPU's - NVIDIA has some serious thunder stealing to do.
With the 6k launch very imminent, NVIDIA need something - and here we go, the leaks of a GTX580 with full 512 CUDA cores.
Now, these are rumours - so don't start lighting your pitchforks and gathering your peeps... But, NVIDIA are supposedly working on a new Fermi GPU called "GF110" which builds on a restructured design with new clusters. This is NOT a reworked GF100 GPU with all CUDA cores unlocked - but a new solution, design, layout and it should hopefully see a big increase in texture units.
Currently GTX480 has 60 texture units, but according to sources NVIDIA has re-jigged it's GPU to grab texture units by the balls and squeeze them to give us 128 texture units. This is done by changing the ratio in the SM units from 8:1 to 4:1 (CUDA cores relative to TMU's) - the latter is something they did with the GT200 GPU.
The rumours go on to suggest the new GTX580 will use a huge 512-but memory bus, connected to GDDR5 memory for a drool-worthy amount of bandwidth. It's still on the 40nm tech, it will still be a power hungry monster like the 480 - but hopefully not as much as the 480.
Of course, as I said before - these are just rumours. NVIDIA know the smack down is about to happen with the Cayman from AMD... maybe this is just a bit of sand in the eyes?
http://www.tweaktown.com/news/17157...580_to_swing_punches_with_the_6970/index.html
Vec je bilo price o ovoj vesti 😀 i kao sto su se svi slozili, u pitanju su necije puste zelje 😀
Pobogu oni do skoro nisu mogli da naprave potpuno ispravan GF100 cip 😀
pa možda i prave veliki kvadratni gf104 :d sa 512 coda cores ali sigurno nema 512bit-nu magistralu, ne bi me iznenadilo da opet prave neki mamutski čip, a sa 512cc i 256bit-nom magistralom to bi bilo i manje od fermija, a njmanje bi me iznenadilo da ga nazovu gtx580, taman full gf104 nazovu gtx560 i nvidia rides again😛
Ja ne vidim nista neverovatno u tome da nV izbaci refresh gpu-a posle 8-9 meseci. To su uvek radili. Toliko vremena im je trebalo da izbace g200b, a jos manje im je trebalo da izbace g71, koji se pak nije razlikovao od g70 samo po sitnijem proizvodnom procesu, vec je do te mere optimizovali da je imao manje tranzistora (278 naspram 302 miliona), a da je pritom bio i brzi na istom kloku. Po meni jedino je pitanje da li ce to da bude neki full gf100, ili nesto poput gf102, gf110, ostaje da se vidi. A da ce izbaciti gtx485 ili kako god mu ime bilo, u to nemam sumnju.
Nvidia Quietly Unveils GeForce GT 440 Graphics Card.
Nvidia Corp. has quietly unveiled its new low-cost graphics card aimed at branded desktop computer makers. The GeForce GT 440 will increase performance of PCs aimed at casual gamers.
Nvidia GeForce GT 440 features 144 stream processors operating at 1189MHz as well as 192-bit memory controller that connects memory operating at up to 1800MHz frequency. The novelty works at 594MHz. Naturally, the new graphics board supports all modern video technologies, including decoding of various contemporary formats, such as Blu-ray 3D (MPEG4-MVC). The new device consumes up to 56W of power.
Based on the fact that the GT 440 features 192-bit bus, the card is powered by the code-named GF106 graphics processing unit.
Given that the novelty is aimed at OEMs only at present, its exact price remains unknown. It is highly likely that the GeForce GT 440 costs less than $100.
NVIDIA GeForce GTX 460 SE on November 15th
Vraca se vreme Vante i slicnih kartica, MX440 i slicno 🙂
A sada ozbiljnije... otkud sada ovo? "Samo" 6 klastera (288CC) i 256-bitna magistrala. Kome li ce ovo uvaliti, kada je cena GTS450 i 5770 vec povoljna, a ni GTX460 nisu daleko. Sumnjam da je za OEM-e, ne moze konkurisati Juniperu. Mislim, povuci ce GTX460 768 gotovo izvesno, ali ce ovo biti dosta sporije od nje.
AMD je nesto slicno uradio sa 5830, ali je razlika u ceni izmedju 5770 i 5850 bila daleko veca, postojala je rupa od ~100 dolara/evra.
Mozda se nakupilo ostataka 104ke i koristi isti PCB cim je 6+6 za napajanje?
Kad pogledas u oznaci stoji gtx460 tako da ce neupuceni ovo kupiti sa osmehom na licu 🙂
Da, ali svi ocekuju full GF104... a predstavlja se dodatno osakaceni.
Nije to predstavljanje jer ako se i desi bice uradjeno tiho da do neupucenih ne bi doslo da to bas i nije gtx460. To je potrosnja falicnih gpu-ova kojih se mozda dosta nakupilo.
Mozda je gtx460 vec full gf104, a ostalo je prazna prica? Mozda ne smeju da puste full gf104 jer u tom slucaju gtx470 ne bi prodali ni u snovima, a nekako moraju da se prodaju gf100 chipovi?
Moje misljenje je da je sad kasno za taj misteriozni full gf104 i da sad moze da se ocekuje 110, 114 i td. Mada 114 moze da bude full 104 mozda bez i malo optimizacije..
Nema sumnje da si u pravu, ali to dovoljno govori o tome koliko su problema imali... ta karta ce morati da bude tako pozicionirana da ce ugroziti prodaju GTS450.
GTX460 sigurno nije Full GF104, tu nema dileme. Sto se GTX470 tice, ta karta je prakticno vec EOL, a prema svemu sto sam saznao vec neko vreme nije ni profitabilna. Prodace se to sto je zaostalo i gotovo. Sada nema razloga da ista vise cekaju da ne bi ugrozavali prodaju GTX470.
Vrlo lako bi moglo da se desi da si ovde u pravu 😉
Nece nista ugroziti jer ces SE moci da kupis narednih mesec ili dva. Iz nvidia ugla to je odlican potez u pravom trenutku jer ce prodati falicne primerke za mnogo vise nego sto vrede. I bez problema ce biti rasprodati zbog imena GTX460se.
Isti PCB sve isto samo pakuj i prodaj..
Sad je kasno da ga pustaju u full, sad ce da ga jos malo izpoliraju povecaju performanse za ~10% i predstave ga kao gf114.
Niko me ne moze ubetiti da je bilo nekih tehnickih problema sa gf104, jednostavno je bio prejak i morali su da ga ogranice kako im ne bi ostao pun magacin gf100 koji su se ipak prodali kroz GTX470. Tako je steta umanjena, cista ekonomija...
