rAMA
Odakle si izvukao to 30/100 🙂
GTA na konzolama nije imao neki framerate, niti je radio u nekoj rezoluciji, ali je radio konstantno, dok ti na PCu treba danashnja top konfa da bi imao normalan framerate. Pored toga, grafika na konzolama je "organskija", na PCu grad izgleda kao model iz Autocada, a pochinjem da sumnjam da PC nije u stanju da simulira DOF, jer svaka igra koja ga na konzoli ima, kod PCa je sve oshtro 10 kilometara...
Jeste da smo otišli daleko u offtopic, ali ajde. DOF u GTA služi kao neka loša dioptrija da bi se zamaskirali ogromni minuse engine-a, i da može se upaliti.
The 360 version of the game runs at :
1280 x 720 with 2 x AA and runs at around 29-30fps
Texture Quality = Medium
Render Quality = Low
View Distance = 21/100
Detail Distance = 10/100
Vehicle Density = 33/100
Shadow Density = Not available on the consoles
The PS3 version of the game runs at :
1120 x 640 with NO AA and is upscaled to 720p at around 29fps
Rockstar has left the depth of field blur OFF by default on PC (I call it the vaseline filter) You can enable the vaseline filter by pressing P on your keyboard, this will blur everything to buggery and you will lose out on the crisp sharpness of the PC graphics.
So there you go if you have a PC and you are playing the game at higher settings than those I just listed well congratulations that means you have a Next Next Generation PC.
