Mafia II (ps3, xbox360)
Odakle si izvukao to 30/100 🙂
GTA na konzolama nije imao neki framerate, niti je radio u nekoj rezoluciji, ali je radio konstantno, dok ti na PCu treba danashnja top konfa da bi imao normalan framerate. Pored toga, grafika na konzolama je "organskija", na PCu grad izgleda kao model iz Autocada, a pochinjem da sumnjam da PC nije u stanju da simulira DOF, jer svaka igra koja ga na konzoli ima, kod PCa je sve oshtro 10 kilometara...
Jeste da smo otišli daleko u offtopic, ali ajde. DOF u GTA služi kao neka loša dioptrija da bi se zamaskirali ogromni minuse engine-a, i da može se upaliti.
The 360 version of the game runs at :
1280 x 720 with 2 x AA and runs at around 29-30fps
Texture Quality = Medium
Render Quality = Low
View Distance = 21/100
Detail Distance = 10/100
Vehicle Density = 33/100
Shadow Density = Not available on the consoles
The PS3 version of the game runs at :
1120 x 640 with NO AA and is upscaled to 720p at around 29fps
Rockstar has left the depth of field blur OFF by default on PC (I call it the vaseline filter) You can enable the vaseline filter by pressing P on your keyboard, this will blur everything to buggery and you will lose out on the crisp sharpness of the PC graphics.
So there you go if you have a PC and you are playing the game at higher settings than those I just listed well congratulations that means you have a Next Next Generation PC.
DoF u GTA i nije DoF...samo mutljevina koja na srecu moze da se iskljuci...
Predjen GTA 4 na XB-u, daleko je to od konstantnog frejmrejta, ali daleko od toga da je nesto posebno problematicno i da utice na gameplay.
Koje su ovo godine u kojima se odvija radnja, '60, '70?
2K Elizabeth (2K Games)
Hey guys,
When designing Mafia II, we optimized for each of the three different systems the game would run on to make sure the core experience was the best it could be. Because of this, there are some differences from one platform to the next. In terms of the PS3 version, I wanted to clarify a couple points you have been asking about: There will not be highly detailed grass or large pools of blood, the cloth movement is less noticeable than, for example, the PC version, and the visual fidelity in the demo is generally representative of what you’ll see in the full game.
Our aim is to make a cohesive and immersive experience and optimize the game for each platform so that it could run its best. And while there are some differences between each version, I’m sure you’ll find that the core gameplay and the heart of Mafia II remains no matter whether you play on PS3, 360, or PC.
Thanks for your patience while I checked with the dev team on the specific issues you were asking about, and I hope you see you in Empire Bay next week.
Davno sam prestao da se zalim na takve stvari i da mi smetaju, ali ona trava je kao iz neke PS2 igre..
Mafia2 izlazi u petak.
Onaj tamo petak izlazi u EU (27. avgust).
Iako sam skinuo demo jos ga nisam probao (mrzi me nesto)
Inace od ove igre ne ocekujem nista spektakularno, ocekujem jednu prosecnu igru (mozda maxiumum solidnu) sa atmosferom i tematikom kao glavnim adutom.
Pa da, kao prvi deo, nista posebno..
Prvi deo je bio keva po meni uz GTA San Andreas najbolja igra tog razdoblja.
Ali ipak to je bilo pre dobrih 6,7 godina i na osnovu onih trailera i klipova rekao bi da nam dvojka ne donosi nista novo , osim mozda poboljsane grafike i nekih tehnikalija.
Inace ja sam veliki fan tematike o Sicilijancima i cozza nostri ( narocito o cozza nostri iz perioda prve polovine 20-og veka) i sto se mene tice ja bi bio jako srecan kad bi ove igra bula " Boom" i nesto novo u pravom smislu te reci..........ali pomalo sam skeptican u vezi toga.
Uostalom ajde probacu demo nocas ako stignem ili sutra pa javljam utiske..........
Meni najpre smeta sto se danas malo uziva u igrama, a toliko se dzangriza po pitanju tehnikalija. Odjednom vecina posmatra stvari sa zanatske strane, umesto da se, ako preduslovi za to postoje, prepustimo uzivanju u igri kao takvoj. Povodom izostanka trave i potocica krvi sam procitao neka zanimljiva misljenja na stranim forumima - argumenti poput - zasto da placam isto igru na obe konzole, ako je na jednoj planski osiromasena za neke segmente - i tome slicni stoje i ne moze da se kaze da ne piju vodu - uostalom, idealno bi bilo da svi svugde uvek sve mozemo da pokrenemo "u fulu", ali da li se cekala Mafia II zbog radnje, smeka, atmosfere i ostalog ili da bismo brojali frejmove, uzgajali travu i tome slicno? Jeste da su potocici krvi prikladni takvoj tematici, medjutim, ukoliko igra bude priblizno zarazna kao original cisto sumnjam da ce nam novo poglavlje u prici o Cosa Nostra-i biti toliko mrsko. Slazem se da je pozeljno da sve tece glatko, ali ce kljucno za uspeh igre u osiromasenom izdanju biti da li ce nedostaci pomutiti srz. Nadajmo se da nece.
Uzgred, koliko je velik demo, nisam kod kuce, pa da se unapred pripremim za download... hvala!
Da li si uopste probao demo? Meni je ono na ps3 skoro pa neigrivo.
Ok, ako nemas mogucnost izbora igraces igru kakva god da je(tako sam ja igrao SFA2 na SNESu, jer nisam imao PS1), ali ako imas, zasto da igras krsh konzolnu verziju?
U ne-DX10 igrama možeš da ograničiš framerate na željenu vrednost (30 npr.) ako ti tako odgovara.
Je l' mene pitas? Nisam u civilizaciji proteklih nedelja, a samim tim ni uz PS3. Uskoro stizem. Citao sam da deluje poprilicno lose... imam PC, naravno, ali je u poznim godinama i potreban mu je jedan sveobuhvatan upgrade, tako da je PS3 moja realnost kad je rec o zeljno iscekivanoj igri. Ne sumnjam da je bolja na kompjuteru, a s druge strane se nadam da ce imati i te kako sta da pruzi prosecno zahtevnom korisniku konzola. Ne mogu da olako poverujem u to da ce posle toliko godina napraviti nesto sto je nemoguce igrati... ako ostane pri travi i izostanku famoznih barica, nista strasno, a ako bude totalno neigriva, stvarno sramota. Valjda nisu bas toliko poludeli...
@zero
Hvala. Znaci, dobar deo noci ce otici na download...
Pazi, nije nemoguce igrati, ali su zaista mogli vise da se potrude.
Realno shin je upravu, ipak je ps3 mocnija masina od kutije a multiplatform izgleda uglavnom losije na ps3.
Sve to stoji. Samo ne deluje da ce se skoro nesto promeniti na tom planu. Koliko mi je poznato vecina PS3 naslova je zakinuta kad je rec o multiplatform igrama i mozda i nije toliko bitno da li su programeri nedovoljno zainteresovani ili je Sony previse "zatvorio" konzolu za pojedine razvojne timove. Istina je verovatno negde na sredini, a krajnji rezultat se vidi. Isto kao sto se vidi sta PS3 moze kad su u pitanju ekskluzive...
Nazad na temu... vec sada je jasno da su mogli i vise i bolje kad je rec o verziji za PS3, potpuno se slazem, i nije da pomalo ne strahujem kakav ce zavrsni proizvod da bude, ali se ipak nadam da ce oni najvazniji segmenti igre ostati na nivou dovoljnom da Mafia II koliko-toliko opravda sve ove godine iscekivanja...
Kako ti ili bilo ko drugi može da zna da li su mogli bolje unutar rokova i budžeta? BS kao i uvek kad neka verzija ispadne lošije. Znaš, nemaju neograničeno resursa na raspolaganju pa da rade svaku verziju u nedogled.
@shin: Aj' da je neko drugi komentarisao pa da ne razume, ali i i ti si beše programer? ...
Da i bas zato znam da ako nisi u stanju, ne treba previse da zagrizes 😉.
Meni nedostatak trave i mrlje od krvi nisu toliko bitni, ali sveukopno los kvalitet slike i posebno los framerate jesu.
Ne mora da znači da će i ostati tako.
As a general rule, demo builds are branched off from the main game branch at a much earlier date. You pluck and remove the aspects of the game that aren't going to be included in the demo, QA it separately and release it to the heavens. All the while, the main branch continues to enjoy optimizations, tweaks and what not until GM starts looming. This doesn't mean that grass and cloth physics are going to magically appear in the PS3 version - although our optimization work was completed on Mafia 2 some time ago. I'll be buying - with my own money - a copy just like the rest of you.
