TheBear
	The facts are quite clear: in general, ATI’s cards offer better multi GPU scaling than anything NVIDIA can currently offer. Believe it or not, NVIDIA’s SLI scaling is actually very, very good considering we saw on average a 60% to 81% increase when going from one card to two. We’re just not that excited about it because ATI threw a live hand grenade into the SLI party by posting performance increases that were simply jaw-dropping in nearly every respect. It is because of this dual card scaling that a HD 5850 Crossfire setup can make up a ton of lost ground when compared to ATI’s single GPU scores. On the other hand, the HD 5970 is simply trampled by the GTX 470 SLI setup.
Remember, when you hear an incensed fanboy spouting off about how awful the GTX 480's noise and heat levels are, that his point only applies in a very limited sense, relative to some slightly better competition. I wouldn't hesitate to put a GeForce GTX 480 into a gaming rig of my own on that basis. Yes, I would prefer the Radeon HD 5870's overall combination of attributes, especially in terms of price and performance. But let's be clear: in an undeniably tough situation, Nvidia has avoided the temptation to reach the highest possible performance levels at the cost of reasonable power draw and acoustics. Folks seem to be missing that fact, which has caused Nvidia to send out its viral drones to spread the message. Such silliness shouldn't be necessary. This is one lesson we're happy they've learned, and I'd hate to fail to acknowledge it.
Ljudi, ne mozete se dogovoriti oko buke nikako jer je pre svega subjektivna kategorija.
Meni je recimo bucno sve sto se uopste cuje. Bucni su mi i novi GTX-ovi i 5800 serija i nikada ne bih uzeo referentne modele sve da mi ih neko i pokloni na koriscenje (za preprodaju bih i te kako uzeo). Jos pride ne volim takve kulere zbog prljanja tako da je to double no (no-no?) za mene.
Ali naravno da ne mogu da kazem - e ljudi nemoj sad niko da kupi te karte zato sto su meni bucne. Nekome ne smeta ta buka, neko nabije sluske, neko trpi zarad performansi.
A neko je bot pa mu nije bucno 200 db, nije mu vruce 200 stepeni i nije mu skupo 2000 evra za kartuNa stranu to sto u zivotu ne planira da je uzme. Vazno je samo da se na netu slucajno ne napise nesto lose o voljenom mu brendu.
I jos pride optuzite Uruka da je fanboy, a ja mogu da potvrdim da je decko jedan od najnormalnijih korisnika ovde i da uopste nije opterecen firmama. Gleda da uzme ono sto njemu najvise odgovara i sta mu se svidja.
ATI-jev modularni pristup je odlican. Pogotovo po pitanju teselacije. Dve slabije karte daju rezultate kao jedna jaca (2x5750~5850), a pritom imaju bolju teselaciju.
2x5770 su tek urnebes.
Kad bi neko probao 3xCF sa 5750 pa da vidimo to bi bilo sjajno![]()
http://www.guru3d.com/article/overclocking-geforce-gtx-480-with-extra-gpu-voltage/ auuuuuuuuu dere brate:banana:![]()
O kakvom modularnom pristupu je rec, ako moze objasnjenje?? Koliko sam shvatio, Ati ima jednu istu jedinicu za teselaciju i gura je takvu u svaki cip - tako da i Cypress i Juniper imaju istu teselation jedinicu, pa otuda bolji rezultati 2x5750 od 5850/70 u Unigine testu. To je sve samo ne modularno, zapravo to je amodularno
Zapravo, nVidia-in pristup teselaciji je mnogo modularniji - imas 16 manjih jedinica i iskljucujes po zelji i tako skaliras nanize.
Za tebe je onda vodeni blok, bez obzira na kartu :wave:
Sve je ok: oc-om GTX 470 FPS bi se popeo na ~40, sto znaci da bi mogao nivo teselacije da se jos podigne za jedan stepen i da FPS padne na ~30-35. S druge strane podizanjem nivoa teselacije kod 2x5750 setup-a FPS bi pao drasticno, na recimo ~20. To su dva razlicita sveta
Plus, treba ukljuciti i min.FPS u jednacinu.
100-150 evra jeftinijeevo karte OC 860/1240 (memorije ne ide mnogo ali je ok), oko 12% bolji rez.
@Uruk: na koliko su to podeseni klokovi? Odlicno se odrzao, obzirom na extreme teselaciju i povisenu rezoluciju.
Au, pa naravno da se drzi, kad su ga odvalili od kloka.....
to radi kao 480 ... a za 150 evra jeftinije... moglo se ocekivati ovako nesto..
Al moze i 480 da se klokuje, mada opet....
na vodi moze ovako ne mnogo..
Iz licnog iskustva ?
Point of View 470 extreme test
..kaze nije mu prelazio 90C na 70% fana... Ako bude bilo ovih karata bojim se da ce ati morati da spusta cene 5870?
Nisi u pravu, 35 FPS-a je sasvim ok, ja koliko sam video ono tece dovoljno glatko cak i u ~30 FPS.
Plus sto je ukljucen AA, taman bi otprilike, sa iskljucenim AA odrzao slican FPS u 1920x1080, sto je super za onakav nivo grafike.
E sad, drugo je pitanje to da li ce se ovaj engine iskoristiti konkretno i za neku igru.
Za sada jedine fotke koje mogu da pokazem su napajanje i pare koje chekaju GTX470 :d
