iPad - official
kovacm
Pokusajmo ovde da ostavljamo korisne komentare. Mislim da je dosta receno na temu nedostatka Flasha... ;)
za sve koji se razmisljaju da ga kupe, idemo redom:
Ars Technica reviews the iPad
"Truthfully, this device is one that can only really be understood by playing with it firsthand (we know, it took us more than 18,000 words to tell you that). No matter how many words get spilled on the iPad, there's still no simple way to describe how it feels and how it's different from a typical computing or smartphone experience. Those of us on staff who were highly skeptical about the iPad before having touched it had a very different understanding of it after spending some serious time with the device. This is likely to be the case with most users."
link
In-depth review: Apple's IPad and iPhone OS 3.2 (Appleinsider.com, Daniel E. Dilger)
"The verdict on the iPad: you probably don't need it (considering that the category was just invented out of thin air), but you may want one enough that its fairly moderate price may not prove to be an obstacle.
There's no quit. When you're done with an app, you just return to the Home screen by touching the Home button. The app quits itself, immediately. It doesn't cycle through all of your open documents asking to save them, it just quits.
And there's rarely any save commands. Apps that work with documents save them automatically as you work, typically using a version control system that allows you to undo all of your changes step by step, even after you quit the app and then reopen the file again.
There's no exposed file system nor file permissions nor open file dialogs nor anything like the Finder for exploring the iPhone OS' internal file system. There's also no sense of managing which app opens which file, because apps only open their own files."
link
Fudzila: Reasons not to buy an iPad link
Nekoliko random stvari. Posle ona dva reviewa cisto da se vidi koliko Fudzilla pise napamet :D
btw za moredatore: sta cemo sad sa ovim iPad-om? nije ni Mac OS X, nije ni laptop... ? zar ne bi bilo logicnije da imamo Apple sobu sa svim Apple uredjajima u istoj a ne Mac OS X? ;) mozda da otvorite iPhone OS ?
Ma iPad je laptop upotrebljiv kao mobilni :)
e pa nek je sa srecom.
iskreno se radujem pravom pocetku ere tableta. krajnje je vreme da se zaboravi celuloza.
kad se ocekuje u evropi? planiram da ga uzmem
mnogo je tu stvari... nedoreceno. Posebno oko transfera podataka koje treba da se koriste na ipadu, a tu mislim na editovanje i upotrebu dokumenata, pdf, filmova i ostalog. Ovo mi vise lici na beta verziju i da se prave stvari mogu ocekivati tek sa novom revizijom sw...
Iako fudzilla pise svasta, ne moze se prenebregnuti par gresaka koje izludjuju korisnike. Pored cuvenog wifi problema, po meni druga greska u industrijskom dizajnu (prvu su napravili sa iphone 3g) je nemogucnost drzanja uredjaja na stolu u horizontalnom polozaju i rtadu sa njim (3g se grebe na dva mesta od upotrebe) zbog nedostataka obicnih gumenih podmetaca koji postoje na macbooku...
Niko me ne moze uveriti da ce svi raditi u krilu, ili iz ruke... Jednostavno, greska dizajnera koja se evidentno nece ispraviti.
^ Steve je ionako obecao da ce sledeca generacija iMac-a doneti nesto drasticno novo! ;)
(...valjda ce uspeti da naprave intel iMac koji moze da radi duze od godinu dana :D)
ranije se spominjao SMB, NFS... file sharing na iPadu. moguce da ce to doci u nekoj narednoj verziji OS-a.
Ja sam citao na Developer sajtu, 3.2 softver ce imati Documents folder u koji ces moci strpati sta hoces, a isto tako iz njega snimiti na komp. E sad nije mi jasno dal ce da izbace 3.2 pre 4.0, tj dal ce 4.0 imati to pojma neam.
Edit: Mislio sam na iPhone softver, a kolko vidim iPad ima 3.2... nisam pametan..
Edit: Evo nasao sam ovo je za 3.2 koji je trenutno na iPad-u
Allows transferring files between a computer and the device for a shared (per app) document store that all applications can access. Only available for the iPad.
nesto nisam primetio :trust:
da li se zna okvirno kolika ce mu biti cena u EU?
pa standardna varijnata 500 usd = 500 eur...
iPad shortage forces Apple to delay international launch until May
link
Stize u ponedeljak :)
Guglujte malo WePad kao jednu od najavljenih alternativa.
Na prvi pogled, "zvuči" bolje nego iPad:
"The German maker of the new tablet is setting out to rival Apple's iPad with the promise of greater sophisticated technology. Neofonie GmbH says, "The WePad outperforms the iPad by sporting a bigger screen, a webcam and USB ports for connecting printers and other devices."
Moreover, for people who want to put music on their WePad do not have to use specific software. Unlike Apple's devices that require iTunes to listen to music. The WePad has a sporty 11.6-inch screen that is powered by Intel and relies on Linux software as the backbone, which is compatible with Google's Android and all Flash applications. The basic version of the WePad will come will WiFi and 16-gigabyte of storage will cost US$600 and the big brother 32-gigabyte model is priced at US$777."
Kad bi mi trebao neki takav uređaj, o ovome bih možda razmišljao. Sva sreća, ne vidim potrebu za "tablom" ;)
Iskreno, neznam jos uvek sta da mislim. Razumem na koju pricu su isli i kako Microsoft, Nokia i ostali imaju masu patenata za neke druge stvari i sta su hteli da naprave, ali bar ja nevidim sebe da mi treba ovakav uredja u skorije vreme. Nije stvar u tome sta konkurencija nudi, hp.com/slate ide na mnogo bolju pricu, ali i to mi je mnogo, neznam. Nevidim sebe kao iPad owner nebitno koliko malo ili mnogo kostao.
http://tugrik.livejournal.com/834583.html
I think folks are actually wise to be 'on the fence' about this. If you don't have a specific use or problem to solve in mind, don't get one unless you're just after it for the fun of it. Wait for the 4.0 software upgrade or maybe even the 2nd-gen hardware (which will hopefully have a camera and other little upgrades after us early-adopters' usage gives Apple some upgrade ideas). What excites me about the iPad isn't so much what it does right now... it's what it's going to be able to do once software developers get the hang of the device. My remote-admin duties just got a lot more convenient and interesting. I can't wait to see what this will do for comics, gaming and even small-business stuff. I already use my iPhone as my creditcard terminal. Making the iPad into a full point-of-sale system? Yeah, I can see that.
Amusing side-note: I had to get a diagnostic test down at the local hospital today. Since it involved a few hours of hanging out in waiting rooms I brought along the iPad and the little Sprint Overdrive for connectivity. When I pulled it out while waiting for the pre-admission line, a group of on-duty nurses suddenly gathered around in that oh-wow-is-that-the-new-Apple-thing? way. They all wanted to fuss with it. I jokingly said that while I was in getting my tests done in an hour or two I'd leave it there at the nurses' station for them to try. Wouldn't you know it, "the person ahead of you in line isn't quite ready yet, so let's just get you done now. Here, I'll take that iPad..." and zoom, I was on the table for my appointment. :) Instead of getting out at 2pm I was out of there by 11:30a, and all the nurses got a good twenty minutes of playing that "Labyrinth HD" game, reluctantly returning it to me. Ha!
