kovacm
Pokusajmo ovde da ostavljamo korisne komentare. Mislim da je dosta receno na temu nedostatka Flasha... 😉
za sve koji se razmisljaju da ga kupe, idemo redom:
Ars Technica reviews the iPad
"Truthfully, this device is one that can only really be understood by playing with it firsthand (we know, it took us more than 18,000 words to tell you that). No matter how many words get spilled on the iPad, there's still no simple way to describe how it feels and how it's different from a typical computing or smartphone experience. Those of us on staff who were highly skeptical about the iPad before having touched it had a very different understanding of it after spending some serious time with the device. This is likely to be the case with most users."
link
In-depth review: Apple's IPad and iPhone OS 3.2 (Appleinsider.com, Daniel E. Dilger)
"The verdict on the iPad: you probably don't need it (considering that the category was just invented out of thin air), but you may want one enough that its fairly moderate price may not prove to be an obstacle.
There's no quit. When you're done with an app, you just return to the Home screen by touching the Home button. The app quits itself, immediately. It doesn't cycle through all of your open documents asking to save them, it just quits.
And there's rarely any save commands. Apps that work with documents save them automatically as you work, typically using a version control system that allows you to undo all of your changes step by step, even after you quit the app and then reopen the file again.
There's no exposed file system nor file permissions nor open file dialogs nor anything like the Finder for exploring the iPhone OS' internal file system. There's also no sense of managing which app opens which file, because apps only open their own files."
link
Fudzila: Reasons not to buy an iPad link
Nekoliko random stvari. Posle ona dva reviewa cisto da se vidi koliko Fudzilla pise napamet 😀
btw za moredatore: sta cemo sad sa ovim iPad-om? nije ni Mac OS X, nije ni laptop... ? zar ne bi bilo logicnije da imamo Apple sobu sa svim Apple uredjajima u istoj a ne Mac OS X? 😉 mozda da otvorite iPhone OS ?
link
link
