Da li se nekome desava isto msto i meni sa kretanjem!?
	http://www.fifa4fans.de/downloads/onelink_e.php?showid=524
	http://www.fifa4fans.de/downloads/screens11/fifa_10_santiago_bernabeu2.jpg
	http://www.fifa4fans.de/downloads/onelink_e.php?showid=527
	http://www.fifa4fans.de/downloads/screens11/crowd_patch1.jpg
	http://www.fifa4fans.de/downloads/onelink_e.php?showid=530
	>======================================Duong's Match Graphics Replacement=========================================<
						  Version 1.0
Release date: October 19, 2009
|> General features <|
*Version 1.0:
-All features from v0.5 updated.
-Depth of Field reconfiguration.
-Level of details and render rate reconfiguration.
-New nets.
-Optional grass texture.
-Overbright 'Silverscreen' Edition removed due to performance issues.
*Version 0.5:
-New 3D grass - shorter and sharper, with new texture
-New generic grass texture
-Updated face shadows
-New kit shadows
-New grass lighting & shadows parameters
-New kits' & players' model lighting
-New in-game PostFX effects that will apply to both cinematics and normal match graphics.
-New tunnel lighting
-Each match time (sunny, overcast, sunset, night) has its own set of lighting parameters that are tuned to be as realistic as possible.
|> Specific features <|
*The patch is available in 2 modes: Neutral Edition and Vibrant Edition.
-Neutral Edition features lighting effects and colours that are relatively dull and easy on the eyes.
-Vibrant Edition features high-contrast, glossy and luminated lighting, together with a slight film-noir effect applied to match-time. This mode offers more dramatic and cinematographic visual effects, as well as a console-like feel to the game - more colourful and vibrant, as compared to Neutral Edition.
*There is also a third mode that restores your data to EA's original, in the event that you are dissatisfied with the patch.
|> Installation <|
***CAUTION!! DO NOT shift any file inside the folder 'Duong's Match Graphics Replacement 10 v1.0' to another location. I repeat, DO NOT do that.
|> Main patch installation <|
-Extract this RAR file to any location.
-Backup your zdata_36.big, zdata_36.bh, zdata_38.big and zdata_38.bh by making copies of these files, then move them to a different folder. Preferrably, backup your WHOLE data folder (located at FIFA 10/data), if you have enough free disk space in your computer.
-Next, simply double-click on the mode you want to install, and wait for the command window to finish processing. And guess what! You're done :)
*(To have a more dynamic in-game experience, you may want to keep this folder open while playing the game. BEFORE or AFTER a match, you can switch from FIFA 10 to this folder, using Windows+Tab or Alt+Tab, and apply another mode. This way, you can play the next match with different lighting effects if you so wish)
|> Optional grass installation <|
-After installing any of the Editions above, backup zdata_42.big and zdata_42.bh
-Right-click 'Optional Grass Texture.7z', look for the 7zip or WinRar menu and select the option 'Extract Here'.
-Open the newly extracted folder, 'Optional Grass Texture', double-click 'Install Optional Grass Texture.bat' and wait for the command prompt screen to finish processing. And you're done.
*If you're not satisfied with the grass, simply restore the zdata_42.big and zdata_42.bh that you have backed up before this installation.
*If you encounter a bug, please report back to me at: http://www.soccergaming.com/forums/showthread.php?t=160607
	http://rapidshare.com/files/294714746/Duong_s_Match_Graphics_Replacement_10_v1.0.rar
	http://www.mediafire.com/download.php?mymyznnzmik
	OVAJ DONJI PATCH JE ZLO DOBAR!!
Skinuo sam fifa 2010 sa rapidshara i otpakovao rar fajlove i dobio 60 razor fajla.Kako to da sredim da bih instalirao preko deamon toolsa.Da li je jos neko skidao sa rapidshare?
