Tek tad? ***....
Fermi and the PTX 2.0 ISA also add support for C++ virtual functions, function pointers, and
‘new’ and ‘delete’ operators for dynamic object allocation and de-allocation. C++ exception
handling operations ‘try’ and ‘catch’ are also supported.
Heheha, vidim da neko čita dekrete (vlažne snove) Tima Sweeney-a iz Epica...To je i buducnost 3D grafike.. software render na video karti.
Iako je josh rano za software render na video karti, tuda ce svejedno sve ici u buducnosti. Glavno pitanje koje se na danashnji dan postavlja je da li je nvidijin tajming dobar - ako zrtvuju performanse grafike da bi pokazali kuda idemo u buducnosti to moze skupo da ih koshta. Ali kapiram da nisu toliko zaludjeni i kratkovidi.
Upala mi u oko softverska teselacija:
http://vr-zone.com/articles/nvidia-fermi--arriving-in-q1-2010/7786.html?doc=7786
That said - GF100 is still a GPU - and a monster at that. Packing in 3 billion transistors @ 40nm, GF100 sports 512 shader cores (or CUDA cores) over 16 shader clusters (or Streaming Microprocessors, as Nvidia calls them). Each of these SMs contain 64KB L1 cache, with a unified 768KB L2 cache serving all 512 cores. 48 ROPs are present, and a 384-bit memory interface mated to GDDR5 RAM. On the gaming side of things, DirectX 11 is of course supported, though Tesselation appears to be software driven through the CUDA cores. Clock targets are expected to be around 650 / 1700 / 4800 (core/shader/memory). It remains to be seen how close to these targets Nvidia can manage.
neverovatno da nema dual slot cooler?, takav dizajn skoro da nije bio dovoljan za G92 (prvu reviziju)...
Ima dual slot kulerA posebno mi se svidja to sto nije duza od prethodne generacije.
ova na slici nema dual slot cooler![]()
Thankfully this thing doesn’t appear to be a behmoth like the competition. It takes a practical approach and simple dual slot cooler ..
ImaA i nisam jedini koji to vidi ...
Valjda vidite 2 "pipka" za ubacivanje u brackete pobogu...
