S.T.A.L.K.E.R. — Clear Sky
@Chinaski: Sa kojim patch-om igras i ima li bagova?
sa 1.5.07 i ima malih bagova ali nista strasno. nista sto ce ti upropastiti igru.
Pa u SoC-u sam pobio na desetine tih duhova u ona dva laboratorija. Za sve mutante je zakon nabudzen SPSA14 ili Chaser13 i 12x70 shot rounds. SPSA14 nabudzen da maksimalno iskoristi 12x70 shot rounds obavezno nosim.
I taman posla da sada sve opet prelazim da bih odradio taj kvest, i kacim video.
Nema potrebe da se trudiš,nema veze.Sigurno si veći expert od mene za Zonu pa je glupo da ti protivurečim.Ako ti kažeš da je to lak quest onda je lak.Ja sam imao utisak da su ti poltergejtsi u Clear Sky malo "tvrđi" od onih u SoC kao i pseudogiant.U SoC sam ih relativno lako ubijao i onog u X-Lab 18 i u Yantar podzelju.Poltergejtsi su mi još manje pravili problema mada ih je koliko se sećam u X-Lab 18 bilo više od dva.Sad u Clear Sky onaj pseudogiant u Red Forestu je pravo nezgodan igrač.
A evo šta kaže jedan tip koji je očito imao problema u rudniki
How to kill the poltergeists at red forest!
Yes I did it, this is how: In the compass artifact mission there is a bunker, in it there is a basement with 2 poltergeists who will kill you 10 seconds after you go down there. so this is how I managed to kill them: After killing all the guards in the bunker wait for your fellow stalkers to come in. go outside the room where the compass artifact was and look for a wall with a big hole covered with big rusted plate.that wall is the one of the exits from the basement. stay near it and wait for the poltergeists to come and start going ape**** throwing things(they will not be able to hurt you)wait a minute or two, and the other stalkers will notice the ghosts, and they start shooting at them! join them and drop some grenades and shoot. after they are killed, go in and run to the room with the anomaly (throw some bolts first) and pick the gun and grenades from the closet. but do it quickly.THAT IT!
Rešio je na sličan ili isti način kao i ja.Izgleda da su mnogi imali problem tu čim je čovek to okačio.
A i za ove pseudogiante jedan video http://www.youtube.com/watch?v=7vnpyzLrnOQ
Jaoooo dobro što ga nožom nije bockao :) ja sam koristio prebudženi Viper 5 posle 30tak metaka je gotov....
Ne kazem da se moze jedostavno usetati i srediti ih tek tako. Sve zavisi od toga kakvu opremu imas, artefakte, i kako si upgradeovao. Budzi se ili preciznost ili rate of fire, a ne oboje istovremeno. Isto vrijedi i za odijela.
Ja nosim Wintar BC za snajperisanje, nabudzen accuracy do kraja, armor-piercing municija. FT 200M za blisku borbu, nabudzen rate of fire do kraja, armor-piercing municija. I vec sam gore spomenuo SPSA14.
cemu ova provokacija?
Sala :)
Krenuo sa .08 patch-om i na pocetku u swampu nakon sto sam pobio 15 bandita kod Northern farm (glavni quest),kaze mi 'hold the point until help arrives' medjutim nikti dolaze prijatelji niti neprijatelji. Jel moguce da jos uvek nisu resili bagove zbog kojih ne moze dalje?
Mislim da si sve uradio kako treba... Igra je inace ne doradjena, narocito taj pocetni deo sa frakcijama, pa zato neka mesta izgledaju pomalo nejasno...
Resio. Kad se ovo desi malo voznje sa guidom resava problem :)
Nema to veze s guidom. Nekad moras malo duze cekati da dodje pomoc, no mozes i dalje raditi druge kvestove. Ja sam morao recimo duze cekati da preuzmu Southern farm, ulaz u Cordon.
Sada dobro radi. Swamps mapu sam odradio 95%.
Znam da nema veze sa guidom,nego sa cekanjem,ali kad te guide negde preveze vreme se premota unapred za neku vrednost. I tako par puta i eto pomoci :)
Saved games.
1.5.04 - 1.5.08 versions saved games will be compatible with 1.5.09.
Patch introduces the following changes:
Improved integrated anti-cheating system to take screenshots from the player’s screen.
Improved integrated anti-cheating system that allows the remote admins to track the modifications in network game parameters.
Fixed bug with killing the player after respawn.
Improved player-checking system upon connection.
Fixed bug with RPG-7.
Fixed bug in buy menu.
Added new effect High Definition Ambient Occlusion.
Increased the game stability.
Changes of game balance in Multi-player:
- Increased damage dealt by "Tunder С14", "SA Avalanche ".
- Added possibility to attach scope to "SA Avalanche".
- "UDP Compact" pistol now has an increased cartridge (12 bullets).
nije valjda da niko ne zna kodove(sifre) za varanje
daj pomagajte
Da li je igra sa ovim zadnjim patchom postala igriva, tj. mislite li da treba mozda cekati, hoce li se pojaviti jos jedan?
Ima li negde kod nas da se uzme original Clear Sky, po mogucstvu limited edition?
Zavrsio sam. Dobar je STALKER ali ima tu jos puno mesta za unapredjivanje. A i nekako je zbrzan pri kraju ovaj Clear Sky. Raduje me sto su najavljeni jos jedan expansion kao i nastavak.
Nemam nista protiv izazova pri trazenju artefakata, sto zanimljivije to bolje...jedino mi ide na zivce kad artefakt nasade na drvo a stalker skace zivahno kao nilski konj lol ...bese jedan artefakt na nekom drvetu blizu ulaza u bazu Dutyjevaca (u Clear Sky)...nikako nisam uspeo da ga do'vatim:D
Koji su must have modovi za ClearSky? Nisam igrao CS i sad sam uhvatio malo vremena pa bih hteo da stavim sta valja od modova :)
i ti bi tako skakao da teglis na grbaci opremu ekvivalentne tezine dzaku cementa :p
to sam bas danas igrao i nikako nisam mogao da ga nadjem. u stvari, nije artefakt, nego neki stek. popeo sam se na prvu granu i nisam znao sta dalje. a sto se tice artefakata, mislim da je sistem u FC2 sa dijamantima bio sasvim dobar. veci izazov od toga ni ne zelim...
A da...bio je to shtek...a i to sa opremom, pa pobacam iz ranca sve i opet ne mere da naskoci, a nigde maximum strenght:D
A to za dijamante iz FC2, nije to bas neki izazov...pratis samo lampicu.Ipak je ovo Zona u kojoj vreba milion opasnosti, a ne samo dosadni komarci sa kalasima:p
Moras da budes spretan kao macka, i to leopard.
Moze da se dovati, ali treba hodati lagano po grancicama.
Mada moguce je da ne mislimo na istu situaciju, ali ti dakako pokusavaj :D.
Ja sam na tri mesta našao štekove na drvetu.Prvi u nivou Cordon, blizu baze Stalkera , malo iznad nje i tu se penješ preko spuštene grane i nije prevelik problem popeti se do šteka.Drugi je u nivou Darkvalley,kod baze Merc gde je bio ulaz u LabX-18, do šteka se dolazi preko krova i tu je mislim nekih 200 metaka 7.62 za mitraljez.Teći štek na drvetu je u Agroprom nivou pored zida baze Stalkera kod izlaza koji vodi do one bare(odnosno do bivšeg ulaza u Undergraund).I do njega se dolazi odozgo, preko krova baze pa onda koliko se sećam neka letva ili tako nešta, pa na zid i polako na drvo, a u šteku je opet neka municija 7.62 ali mislim da je za snajper (SVD i SVU).
Toliko sam ja našao, možda ima još.
ja govorim o tom prvom steku. hajde da jos malo izigravam Tarzana...ok, popnem se na 1. granu i sta dalje? da li treba sa nje na naskocim na jos neku? sudeci po lokaciji steka - da. ali ne znam gde i ne vidim nista od lisca.
a dijamanti su bili sasvim ok. treba da utvrdis pravac i a kada dodjes do njih, da vidis da li su eventualno iznad ili ispod tebe i to je ok. a ovde se polomis. bas pored tog steka ima jos jedan na brdascetu na grobu nekog stalkera a radijacija izuva iz cipela, pocrneo mi je 971P, potrosio sam gomilu injekcija i medkitova a nasao sam samo 1 medkit i 1 injekciju :mad: sada hocu da se vratim do mocvara ali treba proci pored onog ludog mirtaljesca iz Army. divota...
btw. preselicu ove postove u CS temu kada nadjem vremena.
