Zvanična Radeon HD4850 & HD4870 tema
Pardonemua....pretty please .
Jes' ti siguran u to ? Mozda ...ali mozda.....pri rezoluciji od 2560x1400...ali tad bih vise upirao prst na GPU....q9550 i na stock podesavanjima 2830 MHz zhvace sve sasvim dobro...biliv ju mi .
Ako imas E0 stepping onda imash vise prostora za disanje shto se overclocka tiche...ali mislim da ti nece biti neophodno u 99 % slucajeva...u visokim rezolucijama sa ukljucenim AA&AF ovaj "nas" kwad nece biti limitirajuci faktor...i na defaultu.
Evo polako svanjava bratiji sa CF-om :) :banana:
ATI CrossFire Xtension v1.0
by AgentGOD
Home pages: www.epichardware.com & www.ultimate-filez.com
Donation: www.ultimate-filez.com/?page=donate
Description:
Ever ran into a problem where you could not use your big, multiple ATI GPU setup on a new game?
Don't worry, many people have had the same issue, and up until now, the only solution was to
wait for an updated build of the Catalyst drivers, which usually takes over a month! Now, that
problem has a solution! ATI CrossFire Xtension allows you to create custom profiles that will
force CrossFire (ATI multi-GPU solution) support on non-supported, or new, games and applications.
Requirements:
-Microsoft .NET Framework v2.0 (minimum)
-An non-crossfire supported Direct3D/OpenGL game (usually)
-Two or more ATI graphics cards (dual-GPU on single PCB counts)
-Windows XP/Vista (32-bit or 64-bit)
Instructions:
Extract the program to its own folder, then run the program. Add a game/application to the program
to create a profile for that game/application. Be sure to select the correct rendering method! If
you aren't sure which one your game uses, you can always check Google! Then, launch the game by
selecting, then double-clicking the game, or click the Launch button. Your profile settings will be
saved upon quitting the program, or you can manually save by hitting the Save button. The profile will
be saved as "ATI_CF_Xtension.ini" in the same folder.
Enjoy!
Credits:
AgentGOD - coding the program
ATI/AMD - for the HD 4870 X2
TricksOfDeath - UI revisions
NickF - bug testing
Copyright © 2009 [E]pic [H]ardware & Ultimate Filez
Izvor: XS
:wave:
  • ATI_CF_Xtension.rar
    68.3 KB · Pregleda: 59
jos da su naveli tacne klokove gde bi ima biJo kraj...
batali njegova loopetanja :smash:
hebo 3d mark pusti neku igru i vidi min/avrg/max fps pa uporedi sa nekim rezultatom ovde ili na netu
p.s. "prostim" rename-om .exe fajla u "AFR-FriendlyD3D" npr. mozes svaku igru/demo/benchmark naterati da radi u AFR modu i u 99% slucajeva duplirati fps ;) tako da te price kako dual karte ne valjaju poticu verovatno od "next, next average joe" usera koji moraju da instaliraju 10 drajvera mesecno + jedno 5 nhancera :d
moras ovo "stivo" da "prelistas" ;) kada jednom namestis (mozes i flesnuti bios sa lepo podesenim vrednostima za fan/oc npr.) to ti je to :) posle toga samo next, next kad'izadje novi drajver ;)
u Ati tray tools-ima mozes game profile da pravis (posto je "nemanje game profila" jos jedan od hate-ova atijevih drajvera :)) sto verovatno vec znas posto si imao atija i ranije ;)
Hohoho! :)
A Ati se jadan ubi paraveci nove drajvere da osposobi Crossfire da radi kako treba a nas Ivke kucne dva-tri slovceta i bum,duplo veci FPS u svakoj igri! Yeah,right!
Hohoho! :)
smes li da se kladis "prepametni" decace?
fear2 ti je najskoriji primer ;) mirrors edge i COD WAW pre toga
a sta si btw mislio da radi ovo sto je yoti postovao ;)
rename-uje exe u crysis.exe i tako "folira" drajver da "povuce" crysis profil koji jelte enable-uje crossfire po defaultu
jeste "smesno" ali je tako :smoke: veruj iskusnijem od sebe ;)
u prevodu: "Nezavisno od verzije drajvera mozes force-ovati crossfire tj. oba jezgra (u slucaju x2 karti) iako npr. u debilnom fear2 read me-ju :) pise da crossfire ne radi lol fear2.exe u fear.exe i eto dupliranog fps-a" :)
nemoj bzvz ispadati "gloop u drustvu"
To iskustvo sa crossfire si, pretpostavljam, stekao sa 4870 non-X2? :d Onako, iz prve ruke iskustvo?
edit: radi ATI malo vise na profilima osim sto "renejmuje" exe i kopira setinge od prethodnih profila. ;)
Pa ajde pokrenite neku igru tako i uporedite rezultate sa 4870 1GB pa da vidimo to dupliranje FPS-a ;)
Nema tu sta da budes iskusniji,ako igra pod cross-fire-om daje ~40% veci FPS nego ekvivalentna single-GPU karta nikakvo rename-ovanje ti nece pomoci da dobijes vise.
jao :wall:
mislis da je ovo samo zbog "magicnih" 9.2 drajvera ;)
rename u fear.exe i ne moras da cekas novi catalyst ;)
ista "akcija" vazi i za mirrors edge/cod waw/brothers in arms hells highway npr.
proguglaj malo videces i sam :)
opet da ti prevedem :)
izadje nova igra i "eminentni" sajtovi izbace benchmark gde x2 radi losije od single 4870, svi krenu da hejtuju ati drajvere i bila gejtsa po forumima a (po)neko pametan se seti i da proba sa rename-om ;) i gle cuda uglavnom radi
u pojedinim slucajevima (kao sto je oblivion.exe npr.) dolazi do shebavanja senki/tekstura ali u slucaju AFR-FriendlyD3D.exe, Crysis.exe, Bioshock.exe, UT3.exe sve do sada sto sam probao a da je vredno paznje (sve moguce gluposti a la Shellshock 2 Blood Trails ionako ne instaliram) radi ;)
Epilog:
fear2, mirrors edge i cod waw su mi poleteli nakon rename-a ;) a nisam morao da cekam novi drajver
samo mi ti nemoj o iskustvu plz
"bavim se dizajnom/video montazom a nemam pojma sta je AR" :smash:
"pljujem mgs4 a instaliram i igram dark sector/x blades" :d
da ne nastavljam dalje :smoke: o npr. nepomerljivim ljudima iz shao lin-a :)
naravno da ATI radi "malo vise" na profilima ali prostim "trikom" mozes naterati oba jezgra (karte) da rade ;) a to je valjda najbitnije ako vec imas dual gpu zar ne ;)
pa instaliram da vidim kakve su igre. Sta ima lose u tome? Kakve to ima veze sa iskustvom? Opet *****s ko foka Ivke. ;) Ako nista drugo, to je smao + za iskustvo. O Shao Linu necemo...zao mi je sto sam to ikada pomenuo. Sa druge strane ako je to neverovatno, sta su Adam i Eva i ostle "cinjenice"? Jel verujes u to? No, necemo o tome, totalni je off.
Nikad nisam rekao da ne znam sta je AR, pitanje je bilo zasto u samom BR snimku u nekim filmovima koji su navodno 16:9 postoje crne strafte, zasto nije crop. To da ja ne znam sta je AR i kako funcionise je prosto nametnuta zlonamerna laz! I ovo prozivanje sto ti sad radis je nista drugo do zlonamerna prozivka! Uostalom, nista drugo ni ne radis po forumu, samo se pojavis s' vremena na vreme da nekog poklopis, pljunes, isprozivas i flejmujes posto si ti, jelte, najpametniji na svetu. ;)
Uzivaj u tom svom svetu, a mene molim te ostavi na miru. Zapravo, ne moras, pisi sta oces. Dosta mi te je, ides na ignore. (znam da te nije briga, nije ni mene. poz.)
Asus intros Mobility Radeon HD 4870 X2
Koliko radi taj lap na baterijama - 10 sekundi :d
A pazi josh careve koji su klokovali proc na laptopu sa 2.52ghz na 3.95...i josh planiraju LN2 poduhvat.
Joj.
Imao sam prilike da se druzim sa jednim 17" Alienware-om
koji je imao 2x3870 mobility ...
Ispravljac je kao poluga zlata i tezak i velik' :d
Za ono cudo treba dozvola za oruzje
Core2 neki naj-jaci i 4GB ram-a, Vista x64 i stativa :)
Ne radi naravno CrossFire jer pajseri iz ATi-ja ne mogu
da naprave normalan svez drajver za Vistu x64 a da
uopste moze da se koristi CrossFire (Code43 greska, kao kod mene na desktop-u)
Cak i X2 kartice iskljucuju jedno jezgro :mad:
Vec skoro 4 meseca se ceka normalan drajver ... ni 9.2 ne popravlja ovaj bug.
Moze da radi sa bajatim 8.10 catalist-ima ali tu nema profila za novije igre
a i pitanje je da li ce biti bagova
jao :wall:
Epilog:
Ja i dalje ne vidim neku veliku korist od ovoga-svakako ce Ati mesec dana posle pojavljivanja igre podrzati istu kroz crossfire(ako je moguce :)).
Znaci tvoja poenta je 'koj ce mi drajveri,mogu ja to sam',a sta je kad Ati izbaci nove drajvere u kojima poboljsa rad nekog naslova u Crossfire-u(sto je i najcesce kada se radi o izlasku novih drajvera koji donose performanse) ? Jel ti je i onda dovoljno rename-ovanje?
Dalje,ti si rekao da se prostim rename-ovanjem u 99% slucajeva dupliraju performanse, sto nema veze sa istinom. Neke igre,kao sto je Crysis rade tek ~35% bolje kad rade oba GPU-a nego kad radi jedan. Dakle pokusavas da prodas pricu kako je multi-GPU resenje odavno prelezalo sve boljke i da sad sve radi kako treba,a to neces uspeti,bar ne meni. ;)
poz. :wave:
bla bla bla :) nigde nisam napisao "koji ce mi novi drajveri" i da "cf u crysis-u skalira 100%". U Crysis-u po defaultu radi cf!
to sto ne skalira kao sli je neka druga prica :) a i to je jedna igra :D
rekao sam da mozes forsirati cf u novom naslovu npr. bez mesec dana cekanja novih catalyst-a ;) i to bas "metodom" koju sam objasnio ;)
i da, dual gpu/cf/sli resenja odavno rade itekako :smoke:
nisu "best bang for buck" ali rade u svim iole "igrivim/"hit" :d" naslovima! za one druge naslove i jedan gpu na dual gpu/sli/cf konfama je dovoljan!
p.s. da nije malo gloopo imati radeta u masini a biti tako sarkasticno negativan po pitanju drajvera?
poz. :wave:
Cekaj,cekaj,jos ja ispade negativan po pitanju drajvera?! :trust: Pa upravo je suprotno,procitajte sta sam napisao,ja sam bas rekao da treba sacekati Ati drajvere a ne koristiti neke third-party aplikacije. Bilo bi dobro da barem procitate sta se napise. Ako sam po neccemu 'sarkasticno negativan',onda je to po pitanju muliti-GPU skalamerija. :)
pa i ja uporno pokusavam da ti objasnim da nisam protiv drajvera ali da se moze tweakovati cf za "i wanna play it now dammit, fcuk ati and their driver support" likove :)
logicno je naravno da se (skoro)uvek instaliraju novi drajveri
sve ovo sa rename-om je prelazno resenje ali priznaces vrlo dobro :smoke: i radilo je 100% u novom tomb raider-u, fear-u, cod-u i brothers in arms-ima + mirrors edge
pa ne treba da budes ;)
odavno su prelezane "decije bolesti"
@CAR
ne daj bios :-devil-: neka proba ovo :smoke:
mada sumnjam da gs ima referentni pcb :trust:
kod mene radi na oba jezgra :smoke: ali na 880 za core pri 1.35 naponu temperature odu do djavola (90+) pa necu da se "shalim" :)
izgleda da vlasnici sapphire/palit karti najvise profitiraju
bar dok ne nabavim ovo
Probao sam to,odnosno pokusao,ali moja kartica nema Volterra regulatore :) tako da mrka kapa.
Jel'ovo lose ;)
http://www.anandtech.com/video/showdoc.aspx?i=3517&p=1
Conclusion:
http://www.anandtech.com/video/showdoc.aspx?i=3517&p=14
cf lose skalira u krizi i to smo svi znali ali gledajuci "overall" rezultate priznaces da cf/sli i nisu tako losa "resenja" ;)
neces dobiti 100% brze sa dve karte ali 50-95% hoces sigurno :)
+ sto obicno dual gpu karte budu i do 100e (malo kasnije naravno posto u vreme "launch date-a" obe kompanije napumpaju cene jer znaju da ima dosta "i want it now" likova koji ce to da iskesiraju) jeftinije od "2x single" karti ;)
mene je npr. x2 (po sadasnjem kursu) u septembru izasao 300e :) (oko 400e tada ali tada je i 280gtx npr, bio 500+ e)
reci mi sta to ima bolje za te pare ;)
Eh,pa 50-95% je svakako manje od 'dupliranja FPS-a u 99% slucajeva' ,zar ne? ;)
A ovo za cenu tvoje kartice,sta ti znaci 300 evra po sadasnjem kursu,a 400 tada ? :) Koliko si tada platio karticu po tadasnjem kursu? A na kraju krajeva,nije ni bitno koliko si je ti platio,ako si ti prosao jeftinije to ne znaci da su i drugi mogli da je nabave po toj ceni.Evo bacih pogled na sadasnje maloprodajne cene 4870X2 i krecu se od 38-46K. Eto sad mozes jos vise da uzivas :)
Takodje,kada sam spominjao Crysis uopste nisam ciljao na to kako je SLI superioran u ovoj igri,naprotiv,kao sto se da videti na anandtechu skaliranje je tu negde.
4870 i kraj... Niti sam procesor overklokovao, a hocu= brutalnost...
AA 4x
Sve na Max u 1280x1024, jer monitor mi ne moze vise :D
Stvarno bruka, odusevio sam se k'o malo dete...
Ne zelim da razmisljam o Crossfire-u... Ne bi valjalo...
ako ga nisi klokovao ni malo onda ti je karta brutalno zagusena...
stavi ga makar, ali makar na 2.66Ghz...
