Koliki TV da uzmem?
AtiRage
Cao svima, interesuju me vasa iskustva sa SD i antenskim kanalima na Full HD televizorima. Planiram da uzmem neki od 37 ili 40 inca, ali posto sam u sobi ogranicen sa prostorom [u smislu ne mogu previse da se udaljim od uredjaja] interesuje me na koliko metara i na kolikom ekranu je prihvatljiva slika iz analognog izvora.
Sto se tice prostora - mogu se udaljiti od zida max 2.5 metra. Tako da uveliko razmatram 32" zbog blizine ekrana..
Na umu sam imao seriju 5 ili 6 od Samsunga.
Interesuju me vasa iskustva sa istim televizorima i nasim tv programom [necu imati mogucnost digitalne kablovske].
Kog proizvodjaca bi ste mi preporucili i koji model koji se dobro snalazi sa SD signalom?
TV kupujem za gledanje HD filmova, dvdripova i igranje. Pretezno za kucni bioskop, ali cu puno gledati i tv program.
Unapred hvala :wave:
SRT- Super Resolution Technology
Super-resolution technology was formerly used predominantly in military applications such as spy satellites. However, recent leaps in both super-resolution theory and computing power has made it feasible for super-resolution technology to be brought to the commercial market.
Super-resolution has the unique ability to actually increase resolution and details in certain videos. It works by taking multiple adjacent frames of a video, extracting as much video information as possible from each frame, then reconstructing a single frame by using the details visible in each. In this way, video information that is not present in one frame but is in surrounding frames can be preserved and enhanced. This has the effect of actually rebuilding details that might be absent in certain frames and can even increase the resolution of the original video. The only problem is that most super-resolution algorithms are not robust or adaptable enough to different video situations and fail frequently. Many are also prohibitively slow.
Review nekog tosh televizora:
The outfit's 46XV545U was recently reviewed over at CNET, and critics found the internal upscaling technology to be more of a gimmick than anything. Sure, it artificially sharpened some SD content for the better, but all in all, the SRT system fell under the "bad," not the "good."
Neznam kolko je inace dobar SD prikaz na Tosh televizorima, tako da nemam pojma kolko je ovo korisno i da li zapravo vredi ukljucivati jer vestacki zaostrava sliku..
SRT = jos jedno prodavanje magle.
Sto se tice odnosa dijagonale i udaljenosti, televizor treba da bude odaljen od 2 - 3 duzine dijagonale za gledanje HD materijala.
Blize i morace da radi vrat (konstantno pomeranje glave) dalje i necete videti sve detalje.
Na Panasonicovim 50"ticama je napisano min 2.1m, sto je po meni preblizu, ali valjda oni najbolje znaju 🙂
1.5 x dijagonala za 1080p, ili 2.5 x dijagonala za 720p, najčešći podaci na netu 🙂
KOd gledanja filmova nije ni vazno da se vidi ceo ekran, THX za gledanje preporucuje da centralni deo ekrana zauzima centralni vid a preiferni deo ekrana da bude za periferni vid. To sto smo mi naucili da na CRT udaljeni vidimo ceo ekran a nista sitno na njima druga je prica.
1. Da li treba uzimati TV - Toshiba 40XV550PR (iskoristiti akciju u TM), ili bolje malo sacekati da cena Regze bude mal' pristupacnija???
2.Zanima me kako ovaj TV daje sliku sa obicnog tv signala, posto nemam kablovsku (nisam u mogucnosti), jer ce mi za to najvise sluziti... Naravno, povezacu ga i na komp, za gledanje HD filmova.
Sta je to Regze?
Inace sinoc sam prikljucio kablovski PTT KDS i moram da stavim moje impresije!
Tv canali na ovoj Toshibi su daleko boljeg prikaza ne go grudingu 40cm iako bi trebalo da je obrnuto ali sobzirom na SRT tehnologiju peglanja signala to mu dodje kao veliki +.
Zatim sam isprobao kablovski sistem ICOM i moram da podvrdim jasni cinjenici da su i najlosiji kablovski canali na ovoj Toshibi besprekorni.
Slika je za duplo bolja,lepsa nego na compjuteru na kome je instaliran Leadtek expert tv tjuner.
Narocito sam odusevljen kvalitetom prikaza HD filmova u 720 p ,a pogotovu u 1080 rezoluciji i to preko kompozitnog izlaza sa compjutera na scart TV.
HDMI cabal jos nisam nabavio 10m kazu u firmi www.tehnotronik.co.yu/default.asp?P=4 da ce ga imati sledece nedelje , akod njih cu kupiti i AUDIO cabal od 10 m=200 din ,a DVI--HDMI 10m=1500 din.Mislim da su momci iz N.Sada vrlo korektni sa cenama:banana::banana:
thx se nalupao gluposti za ceo milenijum :smash:
jedno je "pixell peeping" a drugo uzivanje u filmu 😉
po thx-u svi bi trebali da sedimo kao alex iz clockwork orange-a :d samo jos blize ekranu
E ****ga sad, da nije vazno sta se desava u bocnim delovima ekrana, bili bi jos na 4:3 valjda 🙂.
Ja sam probao da pridjem blize i shvatio sam da samo gledam i titl i ne vidim nista vise.
Bez titla jos nekako i moze da se gleda sa manje razdaljije.
2-2.5x je moje misljenje za postavljanje TV-a.
Eventualno da se uzmu oni nosaci koji mogu da priblize TV za 50+ cm pa kad se gleda HD da se navuce blize, a za standardnu tv i kad je vise ljudi prisutno da se odmakne do zida.
Ja licno gledam 42" plazmu sa 2-2.3m i meni je sasvim ok. Vidim detalje, slika sa 720p mi je dovoljno ostra a SD mi je prihvatiljiv. Ok, to nekome moze i da smeta i ne odgovara. Mogao sam uzeti manji tv za tu dijagonalu ali mi je drago sto nisam! Probao sam kod buraza 50" plazmu sa 2m sa HD (Transformersi) i osecaj je strahovit a razdaljina ni najmanji problem ali SD materijal je onda mucenje.
Ja gledam 50" sa 3m, sa 2m sam pokusao ali ... ne hvala, ne vise 🙂
Doduse, kada sam imao 32" igrao sam se sa manje od 1.5metra i nije bilo lose, ali sve to je max sat vremena, vise od toga mi ne prija.
Sa 3m ova 50"tica moze da se gledao neograniceno dugo.
Taj film mi je izgledao extra sa 2m ali samo sam pustao neke scene dok su prve fotelje na nekih 3m i gledanje jeste prijatno (na 50"). Najdalje je nekih 5m i SD izgleda sasvim dobro (cak super, heh) dok HD ne dolazi do izrazaja.
Sto se tice dijagonale i daljine gledanja cike iz LG-a kazu ovako kako je u tabeli i ja im verujem.
    91.1 KB · Pregleda: 196
Bas me zanima kakve veze sa bilo cim ima velicina sobe?! Sta kakve veze ima da li je levo i desno od TV-a metar ili 10 metara ako ja gledam sa idealne udaljenosti?! Glupost.
Alo, ne zakeraj, ljudi su napisali logicne stvari, prosecne,
Ti ako zamisljas dnevnu od 80 kvadrata, TV gledas sa 2 metra a u ostatku igras fudbal ne spadas u to.
Sa prilozenih daljina ni 720p nije najjasniji a o 1080p da ne govorimo. Vec je bilo tabela na benchu o udaljenosti sa HD videom. Sve preko toga i oko ne pravi razliku izmedju HD i SD snimka.
Pricas o max udaljenosti ?
Pa oni verovatno bas zato nisu naveli sta se gleda vec pise okvirno.
Za SD, 6 metara i 50" nije predaleko. Za HD jeste.
Da li je LG lose naveo ? NIje 😉
Da, inace ovde niko ne gleda kablovsku, svima televizori sluze samo da gledaju HDTV. Svi imaju Blue ray plejere i tri brda diskova sa filmovima i onda sede na metar ispred dijagonale od 50" i svrsavaju od srece. 😛 Ne vidim sta nije jasno, LG inzenjeri su lepo naveli sa koje daljine koja dijagonala zadovoljava kvalitet gledanja. Ako gledas SD mozes komotno da gledas sa vece daljine, ako gledas HD pridji blize i to je to.
Da ti je bila veća rupa u ormanu ne bi onda gledao tabele LG inženjera 🙂 Za kablovsku je to OK, ali za 720p i 1080p nema blage veze.
Sedi blize tv-u i sve ces videti. Ja jesam hteo da kupim 37icu, ali ne i 40icu jer smatram da je prevelika za moju sobu, a neki bi da je gledaju sa metar i kao to je do jaja. Za gledanje sa 2-2,5m dovoljna mi je i 32ojka, a kad ocoravim i obnevidim privuci cu fotelju blize tv-u, to je najmanji problem. 🙂
Ok, ti imas svoju verziju.... ja istinitu 😉
Ok, ljudi - SD se gleda sa vece razdaljine, pogotovo ako je analogni signal, plus i slabijeg kvaliteta.
Za HD postoji grafikon koji sam licno proverio i istinit je. Ako se previse udalji TV ne primecuju se razlike izmedju 720p i 1080p.
Svako gleda tv kako mu prija i odgovara 🙂
Optimalna daljina gledanja zavisi i od dijagonale panela i od rezolucije/kvaliteta signala.
Ako je kvalitet slike bolji, optimalnije je prici blize, jer je ugodjaj bolji.
I obratno, ako je kvalitet slike losiji, optimalnije je gledati iz vece daljine, jer tada nepravilnosti manje iritiraju oko i mozak.
