Zračak nade na pomolu za AMD
Zna li iko da li će se dvojezgarni K10 ("Kuma") pojaviti u 45nm?
To je 4 Ghz na vazduhu. Sta je toliko neverovatno ? Samo intel izvlaci 4 Ghz ? :d
ne nego nema takav screeshot na 6.3GHz. nisam rekao da je 4GHz neverovatno, vec ako ima taj cpu-z shot na 4GHz neka tako stave i cpu-z shot na 6.3GHz
Malo im, pa do januara hoce jos malo da ispeglaju, barem do 7 :)
Napokon i kupovina ATI-a da im se isplati :)
:wave:
pa dobro ali bolje 5GHz na SS nego 5GHz na DI :)
Poenta price je da sada extreman overklok nije exkluzivno pravo vlasnika Intelovih procesora. ;)
naravno... eh taj coldBUG
a i stvarno nije nikad zanimljivo bez konkurencije ;)
Naravno, bice zanimljivije u narednom periodu. ;)
AMD processors launching starting in January 2009 through June 2009 unveiled
The breakdown of processors looks like this:
January 2009:
* Phenom II X4 940 at 3GHz, 8MB total cache using the AM2+ socket
* Phenom II X4 920 at 2.8GHz with 8MB of total cache on the AM2+ socket
February 2009:
* Phenom II X4 910 2.6GHz with 8MB total cache on the AM3 socket
* Phenom II X4 810 Phenom II X4 810 2.6GHz with 6MB total cache on the AM3 socket
* Phenom II X4 805 Phenom II X4 805 2.5GHz with 6MB total cache on the AM3 socket
* Phenom II X3 720 Phenom II X3 720 2.8GHz with 7.5MB total cache on the AM3 socket
* Phenom II X3 710 Phenom II X3 710 2.6GHz with 7.5MB total cache on the AM3 socket
April 2009:
* Phenom II X4 945 3.0GHz with 8MB total cache on the AM3 socket
* Athlon X4 615 2.7GHz with 2MB total cache on the AM3 socket
* Athlon X4 605 2.5GHz with 2MB total cache on the AM3 socket
* Athlon X3 420 Athlon X3 420 2.8GHz with 1.5MB total cache on the AM3 socket
* Athlon X3 410 Athlon X3 410 2.6GHz with 1.5MB total cache on the AM3 socket
June 2009:
* Athlon X2 240 2.8GHz with 2MB total cache on the AM3 socket
* Athlon X2 235 Athlon X2 235 2.7GHz with 2MB total cache on the AM3 socket
http://www.dailytech.com/AMD+Processor+Roadmap+Launch+Dates+Revealed/article13571.htm
Isti djavo!!!
A spominje li se igde TDP za sve ove procesore? Videh da ce ovi AM3 (nekako) raditi na mojoj plochi, ali mi je naponska za max. 125W pa da znam chemu da se nadam. :trust:
Koliko sam ja cuo ovi AM2+ ce biti TDP 125W, a velika vecina AM3 95W, tako da nemas problema sa tim :)
Josh kad nalepim hladnjake ne mosfete, bice i OC avantura.
Da, mislio sam na te prve dualcore D procesore, prosto mi je besmisleno da ih nazovu isto. A sad vidim da je još gore jer se i noviji isto zovu (ne pratim baš novosti u slovo :S:).
Zapravo i jedan i drugi ste u pravu, s tim shto je Ji verovatno mislio na presler :)
Intel Pentium D 920 Presler
Intel Core i7 920 Nehalem
Nešto ne verujem da je AMD želeo da njihovo nove čedo asocira na Preslere koji doduše nisu bili ozloglašeni kao Prescott, ali nisu mogli da pobegnu od Netburst belega.
AMD-ova numeracija nema veze sa Preslerom, ali verujem da su hteli da se pokazu dostojnim Nehalemu.
Pa bice na putu da budu dominantni onog trentutka kada izbace potpuno novu mikroarhitekturu. Do tada ce biti konkurentni, negde slabiji, negde mozda jaci, negde jednaki.
Iz ugla krajnjeg kupca, bitno je da su "tu negde", shto oslikava zdravu konkurenciju.
A ako ikada i budu nadmocniji, ne verujem da bi namerno stavljali manji performance rating. To je neshto po chemu se neupuceni vode prilikom kupovine, svako ce pre uzeti model 9000, nego li neki 420 (ko ne zna, naravno).
ti brojevi ne predstavljaju performance rating... to je jednostavno nomeklatura unutar odgovarajuce familije... slazem se da veca brojka ima odredjeni psiholoski efekat na kupca, pa tako model 9950 moze da bude primamljiviji od modela 810 iako je ovaj potonji sigurno brzi... ali obzirom da ce AMD do sredine iduce godine odraditi corssover izmedju 65nm i 45nm, krajnji kupac ce za back2School i onako na raspolaganju imati samo modele sa trocifrenim oznakama ;)
