Far Cry Nastavak?
Koliko zavitlancije :d
Evo citat sa gamespot foruma
ok so i was able to get my hands on far cry 2 today(retail version). I've spent a few hours on the single player already and so far it's pretty good.multiplayer creator takes some time getting used to . like i mentioned in an earlier post, it has a benchmarking tool, and i can safely say the game is optimised fairly well. Im using a HD 4870 gpu, e8400 cpu, 4gb ram...Ultra High Settings (1680x1050) 2xAA -- Average 42fps/highest 62fps
believe it or not the install size is only a mere 3.16 GB. Enemy AI are fairly smart, they can spot you from a good distance, snipers in shrubs up mountains are fairly accurate. they use cover when they need to...i remember setting fire to a small patch of grass near an outpost. 2 minutes later a small group of enemies decided to investigate, while i was hiding on a cliff edge with a rocket launcher waiting for them to arrive. when they came i shot a rocket at them, they saw it coming and tried to leap out of their jeep before it hit. enemies interactions are random, so they dont always do the same thing everytime
@goxy :p
Citat sa foruma...
driving can be heavy if you choose to do it that way. most of your missions you get are not that far from where you received them. I've only done a few missions so far but when i had to drive there i encountered many enemies along the way who would try and run me off the road or fire at me. you even get patrols. The game is 50km of terrain, you have to expect alot of driving. You can take a bus to instantly get to certain regions of the map, but the area im contained in only has 4 locations where the bus can drop you off so it cant take you where-ever you want
Da ali opet i za crysis je pisalo da ce trebati 12gb slobodnog prostora, pa je bila nekih 6,7 gb ili tako nešto(kad se instalira jel).
Ako se ne varam u svetu je izašao zajedno sa Crysis Wars, a kod nas ne.
Mi nismo svet ;)
Ista koju svuda imas po netu,radi samo editor.
Znaci cekamo 24-i ?
Evo na sta sam ja naleteo a tice se tvrdnji da igra nije full
Dakle
Far Cry 2 is fulll game
Dunia is new game engine with high compress supports. Worlds.dat(2.5gb) is equally when uncompress to 7.5gb of textures
Ubisoft Confirms SecuROM for Far Cry 2
Some of you have been asking about the copy protection used in Far Cry 2. Here's a summary of how it will work:
* You have 5 activations on 3 separate PCs.
* Uninstalling the game "refunds" an activation. This process is called "revoke", so as long as you complete proper uninstall you will be able to install the game an unlimited number of times on 3 systems.
* You can upgrade your computer as many time as you want (using our revoke system).
* Ubisoft is committed to the support of our games, and additional activations can be provided.
We'll keep an eye out for any other major questions on this matter and update this sticky accordingly.
Uh, kako ce da prste banovi ovde izgleda...
E jel ima ovo mp?
Ovakve postove cuvaj za onu "Skalamerije i naklapanje" sobu. Nemojte i ovde da zapocinjete ATI vs NDA plox.
Rece covek koji je mirodjija maltene u svakom konzole VS PC flejmu:d
Stvar se tice igre i konkretna je informacija a ne zvaka "ima li leka", "koliko % je ostalo", "hoce li to meni da radi" ...
