mmarkovic
Jedan DL-DVD
Pa jedan DL je 8.5 .... ili ti 9Gb ne moze na 8.5
Nadam se da ce neko da izbaci jezike, kao sto je ranije bio slucaj sa nekim igrama
pa ce sve ovo spasti na ... nekih 5~6!
Jedan DL-DVD
pa jedan dl je 8.5 .... Ili ti 9gb ne moze na 8.5
nadam se da ce neko da izbaci jezike, kao sto je ranije bio slucaj sa nekim igrama
pa ce sve ovo spasti na ... Nekih 5~6!
ok so i was able to get my hands on far cry 2 today(retail version). I've spent a few hours on the single player already and so far it's pretty good.multiplayer creator takes some time getting used to . like i mentioned in an earlier post, it has a benchmarking tool, and i can safely say the game is optimised fairly well. Im using a HD 4870 gpu, e8400 cpu, 4gb ram...Ultra High Settings (1680x1050) 2xAA -- Average 42fps/highest 62fps
believe it or not the install size is only a mere 3.16 GB. Enemy AI are fairly smart, they can spot you from a good distance, snipers in shrubs up mountains are fairly accurate. they use cover when they need to...i remember setting fire to a small patch of grass near an outpost. 2 minutes later a small group of enemies decided to investigate, while i was hiding on a cliff edge with a rocket launcher waiting for them to arrive. when they came i shot a rocket at them, they saw it coming and tried to leap out of their jeep before it hit. enemies interactions are random, so they dont always do the same thing everytime
Ne, igra toliko zauzima. Nešto više od 3 giga.
http://www.gamespot.com/pages/forums/show_msgs.php?topic_id=26643002
driving can be heavy if you choose to do it that way. most of your missions you get are not that far from where you received them. I've only done a few missions so far but when i had to drive there i encountered many enemies along the way who would try and run me off the road or fire at me. you even get patrols. The game is 50km of terrain, you have to expect alot of driving. You can take a bus to instantly get to certain regions of the map, but the area im contained in only has 4 locations where the bus can drop you off so it cant take you where-ever you want
Ne žurite.
Jedan od link gde u system requirements pise da treba 12gb na hdd,i to iz ubisoft
http://shop.ubi.com/Prod_ExtDesc.asp?catalogid=750&id=35
U Amerikama izlazi 21.10,a u Europi 24.10
Ako se ne varam u svetu je izašao zajedno sa Crysis Wars, a kod nas ne.Da ali opet i za crysis je pisalo da ce trebati 12gb slobodnog prostora, pa je bila nekih 6,7 gb ili tako nešto(kad se instalira jel).
Druže, bolje se drži onog što ti piše u potpisuAko se ne varam u svetu je izašao zajedno sa Crysis Wars, a kod nas ne.
Mi nismo svet![]()
Mi nismo svet![]()
Ne lupaj.![]()
Druže, bolje se drži onog što ti piše u potpisu![]()
Far Cry 2 is fulll game
Dunia is new game engine with high compress supports. Worlds.dat(2.5gb) is equally when uncompress to 7.5gb of textures
Some of you have been asking about the copy protection used in Far Cry 2. Here's a summary of how it will work:
* You have 5 activations on 3 separate PCs.
* Uninstalling the game "refunds" an activation. This process is called "revoke", so as long as you complete proper uninstall you will be able to install the game an unlimited number of times on 3 systems.
* You can upgrade your computer as many time as you want (using our revoke system).
* Ubisoft is committed to the support of our games, and additional activations can be provided.
We'll keep an eye out for any other major questions on this matter and update this sticky accordingly.
Uh, kako ce da prste banovi ovde izgleda...
Prica se da igra bolje radi pod DX10 (cudno, dok sam ne vidim, ne verujem)...
NVIDIA can use the DX10.1 effects in Far Cry 2
Zbog cega ?
Il sam ja to propustio obrisane postove, bice da je tako.
Ovakve postove cuvaj za onu "Skalamerije i naklapanje" sobu. Nemojte i ovde da zapocinjete ATI vs NDA plox.
