AMD Phenom 45nm
Pa po Fudovim vestima možda se pojavi već ka 65nm čip: http://www.fudzilla.com/index.php?option=com_content&task=view&id=9112&Itemid=1
Meni ovo i dalje nema smisla ali šta ga znaš? Možda je to "prepolovljeni" Phenom x4, a i objasnlo bi zašto nigde nema ni reči o njima.
Ovo je ipak izvesnije:
http://www.xbitlabs.com/news/cpu/di...Planned_for_September_Launch_Say_Sources.html
Instead of three AMD Phenom X2 chips (as reported on Tuesday), the world’s second largest maker of x86 microprocessors plans to release one AMD Athlon X2 6500 microprocessor based on the K10 micro-architecture in early September. The chip will operate at 2.30GHz, feature 1MB of L2 cache [512KB per core], 2MB L3 cache as well as dual-channel DDR2 memory controller. The new product will have thermal design power of 95W, hence, should be compatible with the vast majority of AM2+ mainboards.
Ovde kazu da ce biti BE varijanta (ako je uopste kuma u pitanju).
http://www.amdzone.com/index.php/news/cpus/41-cpus/10290-new-black-editions-9950-goes-125w
AMD will also introduce the new AMD Athlon™ X2 6500 Black Edition (product details & positioning available on September 1, with price announcement). The highest performance dual core we have ever offered – at a great price and it is also unlocked!
Takodje je jako interesantno da AMD novi 9950 BE stavlja u 125W thermal envelope (regularan je 140W), sto znaci da se proizvodnja sve vise optimizuje.
http://www.foxconnchannel.com/Product/Motherboard/Digitallife08/index_A79A-S.htm
Jedan lik je dao link ka sajtu Foxconn i gore pri vrhu stoji logo Phenom FX,tako da ce verovatno biti Phenom FX-a,samo na kojim brzinama pitanje je... ovih 4.0ghz deluje suvise dobro da bi bilo istinito.
A jel ti verujes da bih ja mogao sledece godine da pretrcim 100m za 8 sec ? :d
4.0 Ghz, stock, su nerealna za K10 arhitekturu, kao sto rekoh, mozda moze 3.0 - 3.4 uz neki smanjeni TDP i poboljsan proces.
Ne verujemo da može 8s, ali navijamo i nadamo se da bude bar 10s. ;)
Interesantno je, kao što je Jerry[NS] naveo, da se pojavila oznaka Phenom FX u supported CPU listi kod par proizvođača ploča. Sumnjam da bi AMD davao takav naziv procesoru koji planira da prodaje za 200-300 dolara, jer zna se za kakve procesore je rezervisan FX sufiks. S obzirom da je za novembar najavljen 45nm model na 2.6-2.8 GHz, deluje sasvim moguće da se neki 3.0+ GHz model sa FX oznakom pojavi do kraja godine.
Izgleda da ce se 45nm AMD procesori ipak pojaviti u Q1-2009...
The first desktop processors from AMD made using 45nm process technology will be AMD Phenom X4 chips clocked at 2.80GHz and 3.00GHz, sources familiar with AMD’s plans said.
Surprisingly, but the 45nm process technology will not allow AMD to reduce power consumption of its quad-core AMD Phenom X4 process considerably and the new chips are projected to have 125W thermal design power (TDP), inline with today’s higher-end Phenom X4 chips. Still, the new microprocessors will definitely have better performance-per-watt ratio compared to predecessors.
http://www.xbitlabs.com/news/cpu/di...Set_to_Arrive_on_the_8th_of_January_2009.html
12 sec i bicu srecan :)
Nisam nigde rekao da ce izaci phenom FX na 4.0ghz,nego da su ga najavili pod tim imenom,a na koliko ce raditi ostaje da vidimo,verovatno 3.0ghz ili tako nesto.
Pa ako se uzme u obzir xbitov odnos prema AMD-u, ova vest nije ni tako loša. Još kad bi Intel štucnuo kod Nehalema, da da AMD-u malo predaha.:D
Moguće da su pogrešno interpretirali to što su čuli/saznali.
Poznato je da su najavljena 2 sporija 45nm modela (frekvencije negde između 2.4 i 2.8 GHz) u Q4, a neposredno potom početkom Q1 2009. još 2 modela na višim frekvencijama. Ako izuzmemo tvrdnju xbita da će ono biti prvi 45nm Phenomi, vest se uklapa.
http://www.slashgear.com/amd-q4-200...ad-core-phenoms-coming-0415317.php#more-15317
Isto, pre bi se reklo, samo sto ima 3 jezgra vise.
Jeste ali ipak manje nego Yorkfield na istim frekvencijama i to sve sa integrisanim memorijskim kontrolerom. Nije loše ako ovo bude htelo da radi.
Htedoh reći ako uspeju da postignu 3GHz u ovoj godini u okviru TDP-a 125W.
Zasto da ne, to je 45nm proces. Kada u 65nm postizu 125W na 2.6 Ghz, sto to ne bi bio slucaj sa 45nm na 3.0 Ghz.
125W na 3 GHz ne bi trebalo da bude problem, to nije nikakvo veliko dostignuce...
...sto se da videti na primeru Intelovih 130W za njihov prvi native quadcore+IMC+HT_like_QPI... sa sve HighK ;)
Ovo je bilo onako "profesorski"! :d :smoke: Salu na stranu, Nehalem ima nesto vise kesa, a verovatno i tranzistora. Moze se reci da im je potrosnja vrlo slicna.
Nema potrebe da zapocinjes flejm - ovo je thread o AMD-u koliko vidim u naslovu topica. Ja samo kazem da verujem u AMD-ove najave oko potrosnje i da ove specifikacije ne bi trebalo da budu nedostizne iako ih neki clanovi dovode u sumnju sto je, sva je prilika, posledica loseg imidza koji je Phenom od pocetka stekao kao veliki potrosac (nepovoljan watt/performance odnos...)
Nehalem ce u svakom slucaju imati znacajno povoljniji watt/performance (3.2 GHz + veci IPC uz spomenuti TDP) odnos u poredjenju sa 45nm Phenomima, a pitanje je da li ce AMD moci po tom pitanju da parira Xeon 74xx seriji sa 6-jezgara - enivej trziste valorizuje napore i jednih i drugih, a rezultate vidimo svakog dana.
Po metodi Borisa Koljičickog (tako se valjda zvaše) za očekivati bi bilo da AMD prelaskom na 45nm isprva radi na istim učestalostima kao u 65nm, a da se skok dogodi tek nakon 6 meseci kad usavrše proizvodni proces. Tako je makar do sada bilo kada je AMD u pitanju.
ded, ded, kakav flame, pa lepo sam stavio ;) na kraju recenice
.... što bi trebalo značiti da će desktop verzije procesora sigurno imati nešto veći clock :)
Više verujem onoj prvoj vesti da će početne frekvencije biti 2,7GHz.
To da će većina čipova iz prve serije moći da se OC na 3,6GHz, u to baš i neverujem.
