illidan
- Bike Camper -
- amd 5800x3d, cm atmos 240 - phanteks t30
- asus rog strix b550-i gaming
- g.skill trident z neo 32gb cl16 3600
- nvidia rtx 4070super founders edition
- samsung 980 pro 1tb, wd black sn770 2tb
- Zvuk
- ifi zen dac v2 - fosi audio za3 - kef q350, fiio ft1, all balanced
- corsair sf750 platinum
- lian li a4 h2o
- Monitor
- gigabyte mo27q28g
- Miš & tastatura
- g-wolves hts plus pro 8k, kbd.fans tofu65 raw alu - cream soda switches - gmk serika 2 keycaps
- Optički internet
Kod:
IntelBurnTest v1.2
by AgentGOD
Homepage: www.ultimate-filez.com
Description:
Linpack by Intel(R) is an extremely stressful program that will
put even the most powerful X86/X64 CPU in the world at its knees. Load temp
under Linpack will be up to 22*C higher than the competing software Prime95.
This program will make usage of Linpack easier and more practical.
Benefits of using Linpack:
1. More accurate than Prime95 Small FFTs/Blend.
2. Takes less time to tell if your CPU/RAM is unstable than Prime95 (usually
something like 8 minutes Linpack vs 40 hours under Prime95).
3. Use the same stress-testing engine that Intel uses to test their products
before they are packed and put on shelves for sale.
Benefits of using IntelBurnTest:
1. Simplifies usage of Linpack.
2. Direct output of results to the screen.
3. Simplifies the process of selecting a test size to use.
4. Better appearance.
How to test CPU and RAM stability (summarized):
1. It is best to use a 64-bit OS with the 64-bit mode for the most accurate
test result.
2. Use the most available RAM possible (IntelBurnTest can now do this on
its own automatically). The more memory it uses, the more accurate.
3. Select the run # (should use at least 5).
4. Start running. Output should look something like this:
Size LDA Align. Time(s) GFlops Residual Residual(norm)
10000 10000 4 15.979 41.7337 1.012665e-010 3.570760e-002
10000 10000 4 15.119 44.1087 1.012665e-010 3.570760e-002
10000 10000 4 15.216 43.8254 1.012665e-010 3.570760e-002
NOTE: Depending on the memory size selected, the testing size will be
different, so the Residual(norm) values will not be the same if you
ran this test each time with different amounts of memory selected.
5. Above indicates that the test ran fine so far without instability, but
below indicates instability (the Residual(norm) values aren't the same
throughout running the test):
10000 10000 4 15.245 43.7434 1.525878e-005 5.380399e+003
10000 10000 4 15.250 43.7303 2.460366e-010 8.675501e-002
10000 10000 4 15.162 43.9816 1.012665e-010 3.570760e-002
NOTE: Instability doesn't necessarily have to happen at the beginning, it
can happen in the middle, or at the end. It could be just ONE of
them that is inconsistent, but that DOES indicate instability. It is
highly recommended to use the most free memory possible for the most
accurate, and quick test. BSOD or freezing are signs of instability
as well.
Credits:
AgentGOD - Coding this program, duh :)
Cronos (from XS) - for the original the memory size equation
WoZZeR999 (from XS) - memory size suggestion
krille (from XS) - for the constructive criticisms
Intel - for Linpack and a Core 2(tm) Quad processor ;)
IntelBurnTest, Copyright © 2008 Ultimate-Filez. Linpack, Copyright © Intel(R) Corporation.
DOWNLOAD
vise o tome na xtremesystems forumu
