IntelBurnTest
illidan
Nenadmašan
CPU & Cooler
amd 5800x3d, ek nucleus cr240 dark, phanteks t30
Matična ploča
asus rog strix b550-i gaming
RAM
g.skill trident z neo 32gb cl16
GPU
nvidia rtx 4070super founders edition
Storage
samsung 980 pro 1tb, wd black sn770 2tb
Zvuk
ifi zen dac v2, presonus eris 3.5, akg k712 pro balanced, fiio ft1 balanced
PSU
corsair sf750 platinum
Kućište
lian li a4 h2o
Monitor
asus vg27aql1a
Miš & tastatura
mchose l7 pro, kbd.fans tofu65 raw alu, cream soda switches, gmk serika 2 keycaps
Pristup internetu
  1. Optički internet
Kod:
IntelBurnTest v1.2
by AgentGOD
Homepage: www.ultimate-filez.com
Description:
	    Linpack by Intel(R) is an extremely stressful program that will
put even the most powerful X86/X64 CPU in the world at its knees. Load temp
under Linpack will be up to 22*C higher than the competing software Prime95.
This program will make usage of Linpack easier and more practical.
Benefits of using Linpack:
1. More accurate than Prime95 Small FFTs/Blend.
2. Takes less time to tell if your CPU/RAM is unstable than Prime95 (usually
   something like 8 minutes Linpack vs 40 hours under Prime95).
3. Use the same stress-testing engine that Intel uses to test their products
   before they are packed and put on shelves for sale.
Benefits of using IntelBurnTest:
1. Simplifies usage of Linpack.
2. Direct output of results to the screen.
3. Simplifies the process of selecting a test size to use.
4. Better appearance.
How to test CPU and RAM stability (summarized):
1. It is best to use a 64-bit OS with the 64-bit mode for the most accurate
   test result.
2. Use the most available RAM possible (IntelBurnTest can now do this on
   its own automatically). The more memory it uses, the more accurate.
3. Select the run # (should use at least 5).
4. Start running. Output should look something like this:
	Size   LDA    Align. Time(s)    GFlops   Residual      Residual(norm)
	10000  10000  4      15.979     41.7337  1.012665e-010 3.570760e-002
	10000  10000  4      15.119     44.1087  1.012665e-010 3.570760e-002
	10000  10000  4      15.216     43.8254  1.012665e-010 3.570760e-002
   NOTE: Depending on the memory size selected, the testing size will be
	 different, so the Residual(norm) values will not be the same if you
	 ran this test each time with different amounts of memory selected.
5. Above indicates that the test ran fine so far without instability, but
   below indicates instability (the Residual(norm) values aren't the same
   throughout running the test):
	10000  10000  4      15.245     43.7434  1.525878e-005 5.380399e+003
	10000  10000  4      15.250     43.7303  2.460366e-010 8.675501e-002
	10000  10000  4      15.162     43.9816  1.012665e-010 3.570760e-002
   NOTE: Instability doesn't necessarily have to happen at the beginning, it
	 can happen in the middle, or at the end. It could be just ONE of
	 them that is inconsistent, but that DOES indicate instability. It is
	 highly recommended to use the most free memory possible for the most
	 accurate, and quick test. BSOD or freezing are signs of instability
	 as well.
Credits:
AgentGOD - Coding this program, duh :)
Cronos (from XS) - for the original the memory size equation
WoZZeR999 (from XS) - memory size suggestion
krille (from XS) - for the constructive criticisms
Intel - for Linpack and a Core 2(tm) Quad processor ;)
IntelBurnTest, Copyright © 2008 Ultimate-Filez. Linpack, Copyright © Intel(R) Corporation.
DOWNLOAD
vise o tome na xtremesystems forumu
Sve u svemu ovaj test je zahebao i orthos i prime, pa cak i 2 instance prime-a koje sam pushtao ponekad :p.... Prvi put sam cuo neki zvuk iz kompa koji je ustvari bio zvuk ploce da je proc dostigao max temp dozvoljen u biosu (70C) shto znaci da ga ovaj loodilo soft cepa nenormalno, prime ili orthos nikada nisu uradili :)
U zivotu mi proc nije preshao 70C, kad ono nije vrat nego shija :D....
Malo kasnije kacim shot dok zavrsi ceo test, videce se da je realtemp bolji pokazivac temperature od coretemp-a za one tvrdoglave.... Pre nego sto se komp ugasio real temp je pokazivao 67C a coretemp 77C i cime jovaj dostigao 70C (RT), CT je pokazivao 80C..... Sad je namesten na 75C ;)
Josh jednom, ludacki test......
orthos small fft's prior 9 <63C posle 3 sata... IBT 68C u momentu, 71C posle 3-ceg prolaza... :zgran:
Vdrop sa orthosom sa 1.31V na 1.29V, sa IBT 1.28...
na max stress se brojevi nisu slagali, na medium i min je sve ok.
Max stress ima dosta odstupanja, dok sto kaze gx-x na min i medium je ok sve...
Znaci prc od stable, a prime i orthos prolazili po 12-13h..... :S:.....
Toliko o stabilnosti....
Max stress test
    363.4 KB · Pregleda: 319
Kad mislish da ce se u realnoj upotrebi desiti toliko opterecenje CPUa?;)
@ garson
Ako pricamo o testu stabilnosti, merodavno je ono sta kaze stress program nalik ovome ili prime-u 95....
Moze i moj proc da vozi igre i radi svaki dan @ 4Ghz sa 1.325V ali mu za prolaz od par sati prime-a treba 1.375V..... :S:
Stvar je licnog afiniteta da li ce ti komp biti 101% stable ili ce to biti prividno ;)
@ garson
Nekoliko sati prime-a je sasvim dovoljno (kao shto kazesh), ovaj test je cisto izivljavanje. Recimo, vazilo je pravilo da ako je CPU orthos ili prime stabilan ~12 sati ili cak 24h onda je 100% stabilan, ali ko ti garantuje da ce biti stabilan posle 40h?:) I shta, onda je nestabilan?:p
I koliko uopshte ovaj program treba da radi da bi neko rekao da je CPU 101% stabilan?:)
I put:
oko 1600mb rama
10 ponavljanja
trajalo oko 20min
II put:
povecao voltazu cpu-a za 1 stepen
oko 1600mb rama
20 ponavljanja
trajalo oko 35-40min ukupno
    205.6 KB · Pregleda: 146
    232.9 KB · Pregleda: 125
Ovako ja testiram stabilnost za 24/7
Sto se stabilnosti tice, meni je dosta da Stress Prime 2004 odradi jednu Blend test rundu na prioritetu 10 :D
    145.8 KB · Pregleda: 148
E ovo je ludnica koliko zagreva proc! Koji prime, ovo FTV!! :D
Da li je procesor 100% stabilan ili ne to nikad ne mozes znati, mozes samo da se nadas i ocekujes stabilan rad. Ali ako postoji makar jedan program koji pronalazi gresku (a da ta greska nije proizvod nekih buggova u samom programu), onda cpu nije stabilan na tom setup-u.
Ako znas da je na nekom testu pao, a ti to ignorises, pa posle kad radis nesto bitno ti se spuca komp :)
Stvar izbora.
Stvar izbora.
Da, ali posle koliko vremena program pronalazi greshku? Sta, treba da vrtim ovaj test 3 dana?
Meni program totalno nije merodavan. Na max testu (izbor 1) mi se nista ne slaze (proc je na 3GHz). A ovako mi je konfa rock stable...
aj sad da pocnemo da kopamo nejgove probleme sa konfom po benchu :p
salu na stranu, stabilnost nije subjektivna, vec egzaktna stvar. Rock Stable ima jedno i samo jedno znacenje ! :smash:
E sad da li je nekom dovoljno stabilno i to sto nije, to je druga prica i nema veze sa ovom temom ! ;)
Odradih ja kod sebe test.
CPU je na 3GHz sa default naponom i zalman je radio na ~750-800rpm(max rpm je oko 1600), a u sobi je pakleno jer nemam klimu(znaci preko 30c).
Orthos blend prioritet 9 - 72c max, a t se krece oko 68 najcesce.
Orthos small fft prioritet 9 - 75c max.
IBT small - 74c max, a obicno se krece oko 70-tak.
IBT medium - 78c max i to u par trenutaka, a krece se oko 74c.
IBT maximum - 83c max i to u samo jednom trenutku, 82c u par, a t se kretala oko 78-80c.
Znaci za oko 8-10c vise greje nego Orthos.
IntelBurnTest - The Changelog
by AgentGOD
v1.3
- Added automatic error-detection feature (choose at the beginning)
- Added elapsed time at the end
- Added updated 32-bit and 64-bit Intel(R) Linpack binaries from Intel(R)
________________________________________________________________
http://www.ultimate-filez.com/files/IntelBurnTest.zip
Da kucnem o drvo... Sa ovim nijednu... Raspitujem se nesto o X1950, i nista vise.
U obicnom radu mi komp radi, u igrama ne dolazi do iskakanja na desktop. Enkoding videa radi super
Tu si u pravu.
Samo meni cak ni kad mi je kom na 2,4GHz ne prolazi na max. Tj. ne slaze se... A to je OC od 10%... A CPU se zagreje ko furuna. 65c k'o od sale...
Da li se jos nekom desava da program puca, ako ima vise od 2GB rama, probano na 2 masine puca i sa 3 i 4GB, pod WIN XP
@CooLa:
pa mozda nije do CPU-a vec do NB-a, memorije, neceg treceg...
Koja je svrha programa kad nikom na max ne ispada dobar rez. Nek proba neko na defaultu!
pazi, ne viidm zasto bi ti uopste koristio intel burn test na AMD-u :) Niko nigde nije rekao (kolko ja znam) da je to test I ZA AMD. Ja sam malko povisio napon memoriji i prolazi mi na max.
Da li je iko pokusao da startuje program sa vise od 2GB rama? Puca i na Visti.
Ja sam pokrenuo sa 4Gb i na visti i na xp-u, na max stress testu se isti raspada :), mislim na loshe rezultate, sam test kao test ne puca, dok na medium prolazi bez problema :D
Updated to v1.4
* Fixed a bug with percentage display that resulted in displaying 0% instead of the actual
pass rate
* Removed redundant prompt at the beginning asking if user wants to run the program
* Added customize option for selecting the stress level
DOWNLOAD
