dag
Ali on nije ~1kg, vec 2.5kg+...
... i baterija na tom polovnom p3 traje najverovatnije 3 puta kraće od eee.
Bash sam dosta chitao o HP 2133 ili HP MINI kako bi trebalo konachno da se zove. Meni je ovo vrh. Znam da svaki korisnik ima neke svoje zamisli odnosa prenosivosti i funkcionalnosti ali mislim da bi meni ovo leglo kao 1 na 10 🙂 Na YT ima dosta videa o njemu!
ASUS Eee 4G Surf svuda , ali svuda kosta 22900 dinara. Nije moguce naci jeftinie od toga, jer je to zvanicna cena za srbiju!!! A yi fazoni sa ugovorom su samo zbog toga sto dobijes modem za DZ koji kosta oko 100 *******!!!
Nego sto se ASUS-a tice ima i jedan c2d mini notebook, ali nije iz low cost serije
Take a look:
http://www.laptopmag.com/review/laptops/asus-u2e-a2b.aspx
Said to be priced from 299 to 699 Euro, the Wind laptop will come in a slick white casing, weight about 1 kg and arrive soon in several flavors. Wind machines will be available with either a 8.9" or 10-inch LED-backlit LCD screen with a 1024x600 resolution and will be loaded with Windows XP. Hardware wise, the upcoming notebook, is expected to feature an Intel platform backed by 1GB of DDR2 memory and a 2.5-inch 80GB hard drive. With a battery life said to last for up to 7 hours, the Wind is looking like a worthy competitor for the top spot in the low-cost market. We'll have two please.
There's no difference in price between these two versions because the 12GB model comes preloaded with Windows XP, while the 20GB version is running Linux. Basically Asus has used the money saved by installing an open source operating system to increase the storage. Of course if you really are set on Windows XP, the obvious suggestion would be to buy the Linux machine, then just install XP yourself - assuming that you have a spare copy of XP knocking about that is.
