Crysis Benchmark CPU/GPU [HIGH]
Poz. svima evo ga jos jedan 9600GT rez.
    263.9 KB · Pregleda: 97
GTS 320 by Whiplasher 40.24
GTS 320 by Zdravko 37.06
GTS 640 by Paradigma 37.10
GT by Hector Ruiz 46.90
GT by GoranM 46.39
GT by Del boy 40.90
GT by Jovyland 45.29
GT by Ppredrag 47
GT by Jera 44.75
GT by Nenad22 46.54
GT by Miljko 43.38
GT by Chinaski 43.5
GT by Panzer75 46.24
GT by Lanselot 40.72
GT by Bane87 48,97
GT by P$ycho 44.95
GT by nex999 46.24
GT by Ikandrej 42.57
GT SLI by demios 61.90
9600GT by GX-X 36.03
9600GT by fortes 35.25
9600GT by vojans 33.90
GTS 512 by Placebo 52.56
GTS 512 by Paradigma 50.80
GTX by BOX85 48.67
3850 by GoranM 30.44
3850 by cc13 30.50
3850 by Dandy 31.77
3870 by EM2000 35.88
3870 by spaad 38.99
3870 crossfire by Studiovpc 66.41 Vista OS
3870 by terzazak 36.44
2900pro 256 bit, 512DDR3 by Flight 32.27
2600XT by Dandy 13.41
7950GT by Jera 14.58
8600GTS 256MB by Homer nvfreak 13.31
@GoranM - Svaka chast odmjeni me malo:)
Evo da i ja dam mali doprinos temi.
Procesor @ def
3870 @ 875/1251
    104.1 KB · Pregleda: 97
To je naravno 36.99 fps :)
Malo bolje, taktovi 702/1782/2100, framerate 47.17
Uskoro pada Volt mod i 50fps ;)
    66.7 KB · Pregleda: 52
GT by Hector Ruiz 46.99
GT by GoranM 47.17
GT by Del boy 40.90
GT by Ppredrag 47.09
GT by Jera 44.75
GT by Nenad22 46.73
GT by Miljko 43.38
GT by Chinaski 43.5
GT by Bane87 48,98
GT by P$ycho 44.95
GT by nex999 46.24
GT by psyman 46.8
GTX by BOX85 48.67
3850 by cc13 30.50
3850 by Dandy 31.77
3870 by spaad 38.99
3870 by ivan555 36.99
Pa to ti se ne isplati na tom primerku raditi ! <50mhz ti nece dati puno ! (ako dobijes i 50mhz). Nisi normalan majke mi :) Bolje da menjas kartu i nadjes neku koja ide na 750+ pa onda eventualno da volt-modujes i imas neki takmicarski primerak. No dobro, to je moje misljenje (i savet), a ti ces naravno uraditi kako te impulsi spopadnu, znam da ti tu nema leka :D
Koju da nadjem majke ti??? da necu mozda Palit Sonic? Pa on ima fabricki u BIOS-u podignut napon na 1.1V, sta mislis zasto se svaka "gruva" na 750Mhz. Mojoj je 1.05V, a sa 1.1V ce biti kao svaki Palit Sonic. U ostalom iz istih su pogona. Za 800Mhz treba 1.35V na GPU, a tu moze samo volt mod i "prazna glava" :D
Mem mi radi i na 2100+, pa ako malo dodam "paprike" (citaj napona) bice 2.2Ghz. :D
:wave:
Lemilica i licne su spremne, sad jos samo 100kOhm trimer pa da pocne show! :D
Drmni jednu da ti se ne tresu ruke...:beer::p
E popizdio sam. nabavio sam odlican vrh za lemilicu, jako tanak, neki bas profi. i pokusavam sada na ovaj moj kinez da ga montiram. Ladno nece, veci za 1mm. Aaaaa!!! Puci cu! Moram i to doradjivati. Treba ovde piva :S:
Ima jedan drugar Inno3 iChill, mozda da ga pitam da menjamo, pa onda tu da modujem? Ima bolju mem. default 2000, OC 2200 bez menjanja napona.
mozes novim nibitorom da dignes napon na 1.1V (ima ga u izboru, bar kod mene, ali meni vec jeste na 1.1)
1600x1200, nemam 1680x1050, ne znam koliko je uporedivo
702/1782/2000
    66.8 KB · Pregleda: 88
Ovako trenutno igram krizu:
1024x768
4xAF
0xAA
"cheap very high"
Prosek 54fps
Jeste, sada ce neki reci da je mala rezolucija, ali meni na 19" CRT to ne smeta.
Mali ti je monitor ? :d
1024x768
4xAF
0xAA
"cheap very high"
Prosek 54fps
Oces da ti pozajmim moj CRT 17" pa da igras na 800x600 :d :p, samo dok zavrsis Crysis, pa mi vrnes :smoke:.
Videh da na 16x12 na high imas avg fps 34, jel ti to nije dovoljno, toliko si imao na 12x10 na high sa 3850 256MB.
Jok, nije, malo mi je sve ispod 40fps. Tek na 50+ je OK, mada bi bilo dobro da je 60+
Odrastao sam uz Voodoo i 640x480 i 800x600 (luksuz) rezolucije. Tamo je sve samo klizilooooo...
Meni je i dalje 1024x768 dobra rezolucija. Doduse sve ostalo igram u 1600x1200 sa 4xAF, ali ne smeta mi 1024. :D
Probao sam ja svoj pusti san, 1600x1200 sa 4xAF i cheap very high i dobio prosek od 28fps. Traba tu SLI ili CF, mozda i bude 40+?
3850@810/1100 = 32.28 Fps
    160.8 KB · Pregleda: 69
Posle duze pauze sa novim drajverima CCC 8.3 malo poboljsanje..:)
3870@ 857/1368.....
38.16
    144.3 KB · Pregleda: 78
Evo nesto pa mozda vam pomogne!
Cim dodjem sa posla probavam. Stavio sam jutros 1.2 zakrpu i skinuo 174.53 drajvere, pa da vidimo, a i volt mod u BIOS-u na 1.1V treba da odradim. Nasao sam FDD i kabel, jos samo disketu da nadjem...
Ima da dohvatim tih 50fps!
Lemilicu sam sjeb'o, moram novu da nabavim :-devil-:
Samo napred i opusteno:smash:
Crysis ver. 1.1 i det. 174.16 imaju 46,4fps
Crysis ver. 1.2 i det. 174.53 imaju 46.4fps
Nema dobitka, podesavanja su ista 702/1786/2000, CPU 3.33Ghz
Kako god ovaj Crysis test je njesra i samo dzabe ljudi gube vreme!CPU test u opste nije merodavan cak sta vise i ne reaguje u FPS dal bio Quad Core ili Core 2 Duo situacija je ista!Tj. celokupna igra se tako ponasa tako da se i sam zapitam sta bi sa onom podrskom za 4 jezgra,izgleda da je u opste i nema!Jedini pomak i realna stvar je OC Grafike cime dobijes par frejmica vise i to je to!Sve u svemu bez veze,za mene totalni promasaj!
Pa odavno se već zna da nema uticaja dal' je Quad ili C2D.
